Yes the Ely Q uses the exact same head as the old Gazaur Mars 480. I had one and the problem it has is the flybar go's threw a large ball in a cage. That ball has to slide up and down the cage under force. Gazaur made a special lube just for it, but it only helps so much.
Latest blog entry: Logo build
South London United Kingdom
Joined Jun 2003
Hi All
Got a puzzle I hope you can help me with. Flying a 500GT. Started out on a 5s pack, and flew fine for a long time. I decided to try it with a 6s pack, and then the fun started. First of all, I had the whole tail unit turning on the boom, increased torque I presume. Followed by all sorts of tail related issues, all now solved. The model has not been crashed, but had some hard landings. Anyway, tail is now ok, but the blade tracking has gone off the scale, and in the hover the whole machine is leaning to the right. Not just the blade disc but the whole body. If I straighten it up, it moves to the left, as you would expect. Got me stumped on both, any ideas? Cheers BL |
Or a cheaper fix on the arms are the align plastic they don't flex. The HK's flex bad and will even go out of shape after a while. The lean sounds more like a weight issues.
Joined Jun 2003
Hi all
Thanks for the thoughts. Are the 'lower mixing arms' the ones attached to the washout block? Never had any problem before, but could the increased headspeed be a factor? Mhills Not sure what weight issue it could be. Only thing I have changed is to rotate the tail servo a little to get the rod straighter. Surely that can't be enough. Ironically, I thought h/s might be an issue. The only reason I am trying it in its current setup is to get a ballpark figure for battery consumption, before I change to a 12t pinion. Ho hum. BL |
It's the washout control arms that warped on there own on my HK500 http://www.amainhobbies.com/product_...ut-Control-Arm
I know a lot of people like to put the speedcontrol under the battery, but I like putting it on the right side. This tends to balance better with the elevator and tail servos both hanging off the left. |
Joined Jun 2003
Hi mhills
Looking at these http://www.helisfromdevon.co.uk/hfdc...product_id=243 Got 500 bits from them before, seem good quality, plus free shipping and UK based so couple of days delivery. Going out tomorrow with the old 5s pack, will see if it's h/s related. Weight Elevator servo - lhs esc + tail servo - rhs What puzzles me is nothing has changed, apart from the battery, since I last flew it. The story continues BL |
Problem with those and every clone metal ones comes to play between the bearings and the arms and on these a tad amount of play is too much. That is why after purchasing about everyone's metal mixing arms and then getting the align 500e kit. I would go with the align plastic.
This may sound dumb, but is your canopy tweaked and it just looks like the thing is flying sideways? |
Joined Dec 2011
I use a 3cm wide strip of typing paper smeared in wood glue (yes wood glue, it works) and wrapped three quarters of the way around the boom so the slot remains exposed to stop it from moving. You can use a heat gun to cure it fast so there's no waiting. It's also easy to remove if you get it on something by mistake. The edges of the slot need to be bent up with needle nose pliers about 0.3 mm to properly engage the key in the boom holder with this method.
Note also that it is normal for a flybarred helicopter to lean left (slightly) and drift left (slightly) at hover because of the tail rotor pushing against torque. (FBL units will compensate for lean, they still drift left however) |
Joined Dec 2011
Helio 500 and Helios 500. The bottom one is meant for precision flying rather than 3D according to the product page (note the triple bearing supported mainshaft) Clubheli was going to become a US distributor for Gootch and even had the Helios V3 for a while but nothing ever came of it. The "Black King" 450 tail they make is still pretty much the best belt drive tail available on a Trex 450. It's actually from the Helios V3, which is basically an improved 450 SE V2 frame but with a tail belt pulley on the main gear and various other improvements. (most of the parts are aren't compatible with Align) ![]() ![]() ![]()
Joined Jun 2003
mhills
Many thanks for your help. Following your advice I have fitted Align plastic washout arms. Weather has prevented a proper test, but a quick up/down in the car park looks promising. Tracking still out a little, but nowhere near as excessive and easily adjusted. Still puzzled about one thing, perhaps I could pick your brains a little more? Before I fitted the new arms, I went out for a quick test with the old 5s batteries. Result, good as gold. Fitted the 6s and had all sorts of problems. At one stage I heard a sound like an outboard motor. My guess is that one of the blades was so far out it was stalling. Needless to say, I cut that session short. I am using a 1700Kv motor, 13t pinion and a flat 70% throttle curve. Readyheli calculator says h/s on the 5s pack is 1875, and on 6s is 2250. Both of these sound to me to be on the low side anyway, but only 400 rpm apart. I find it difficult to imagine this small change making such a big difference to the model. Any thoughts? Can't help thinking there is another problem somewhere. Your advice on the arms was spot on. Any ideas what else could be causing me problems? Cheers BL |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
