Old Feb 19, 2013, 03:54 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by Border Lord View Post
Hi AS
Thanks for the thought.
Must admit it's been so long since I built it, I couldn't remember myself.
Anyway, bit the bullet, pulled it down, and you're right. One radial and one thrust.
So, the choice is between plastic grips with one of each, or metal grips with one thrust and two radial.
Sounds like the Pro would be better, what do you think?
Cheers
BL
The old style ESP metal grips also have 1 radial bearing and 1 thrust bearing.
If the grips are working fine no need to replace them.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Feb 19, 2013, 04:15 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I received the HK-752MG's mini cyclic servos yesterday.
http://www.hobbyking.com/hobbyking/s...3kg_0_11s.html
I have to say I really like them. They have excellent torque and seem to center well. I like that they have the metal lower case section, which tightly encases the coreless motor. They also have very little slop for a metal gear servo. At 5.5 volts I'm getting around 0.125s on the CX tester/programmer. All three have tested fine and passed a 30 minute continuous run test.
I'll start a thread with some pictures in the next few days. I pulled one apart, so there will be some pictures of the electronics and gears, which I haven't managed to find online anywhere else.
beenflying is offline Find More Posts by beenflying
Old Feb 20, 2013, 12:24 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I am interested in the servo tester. It it this one? http://www.rchobby-king.com/en/brand...vo-tester.html
Is there any results on the LCD after the test, or do you just listen to it for 30min?
I just planted my newly outfitted AR7200BX 500 this weekend. After flying for a few minutes - Tail in; tipped right once, corrected then full aileron to the right. It wasn't like full aileron, full stick left and roll slowed and the heli uh, flailed. I cut the throttle and it never recovered and landed on its right side. It's the same problem I had one time with the ZYX. Bad on me. Bad luck with Align servos (DS415). These 500 cyclics had been crashed more than once so it's probably my fault. Edit: maybe I'll put the Spring servos on this one. I have to order every Align part on line now (LHS out of business) - torque tube and etc. Which is a bummer.
Maybe I'll look around for Savox cyclic. With the sweet Ti gears. I'm not anything about cheap anymore to tell you the truth. Though I do like non critical cheap airframe parts from HK
Thanks.
eagle777 is offline Find More Posts by eagle777
Old Feb 20, 2013, 01:43 AM
Joined Dec 2011
The Henge and Tarot versions of that servo sell for twice what HK charges btw. I'm not sure if Henge sells the gear sets, I wasn't able to find them anywhere. I have seen gear sets for the MD922 and MD933 so it's surprising that they don't have gear sets for the MD752.
Old Feb 20, 2013, 11:14 AM
Border Lord is offline
Find More Posts by Border Lord
South London United Kingdom
Joined Jun 2003
Thanks for the info
Will rebuild the current ones
Cheers
BL
Border Lord is offline Find More Posts by Border Lord
Old Feb 20, 2013, 01:25 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Is there any results on the LCD after the test, or do you just listen to it for 30min?...
No, it's the CX-3X1000 programmer, that has a built in servo tester.
The automatic cycle mode has no result. Yes, I just run it for 30 minutes on 30% and then check that it's still running smoothly, that the torque is still good (by hand), and that the servo is not too hot.
I'm yet to find a servo that doesn't get very hot, in 5 minutes, using the auto cycle mode at 100%. It's not just a smooth cycle, like stirring the stick on the Tx.
Old Feb 20, 2013, 01:41 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, the HK version is very good value. I'd probably just buy the DS510M or DS515 if it was Tarot's price. BTW, this servo looks like it's a DS510M clone. The gears look the same and on the 500EFL Pro the output shaft is in line when the servo is vertical or horizontal, so the 3 servo pushrods can be the same length (with the HK28013DMG the two front pushrods had to be longer (4 turns)).
No, I can't find any gear sets either. You would have to believe they will become available, especially with Tarot selling them, as well.
The heli is all back together, ready for a test flight. I fitted the HK XL red fins this time. Looks more like a large 450 pro now, which I like. I'm also trying out a set of RJX FBL blades. Incredibly stiff and nicely made. The only pain is you have to use a 1mm spacer.
Old Feb 20, 2013, 02:17 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Test flight completed. It's flying better than ever. I like the RJX blades and no issues with the HK-752MG's either. It feels very responsive, yet super stable.
Old Feb 20, 2013, 05:34 PM
LVflier is online now
Find More Posts by LVflier
United States, PA, Nazareth
Joined Jan 2012
Hex bolts for tail
Hi group
Can anyone tell me where I can find the small hexagonal tail bolts for the 500? I stripped mine and I can only find the longer ones when I search.
I am not lazy I really cant find them
If you have a set you want to sell let me know I might take them.
Thanks for your help!
LVflier is online now Find More Posts by LVflier
Old Feb 20, 2013, 05:52 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
wos will have them. That dude is loaded with parts. ( as you know a good guy to trade with as well )
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Feb 20, 2013, 06:05 PM
Joined Jan 2012
Cool I will reach out to him I was just talking to him in wed.
Old Feb 20, 2013, 11:02 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Thanks beenflying. Sorry for the rant.
Old Feb 21, 2013, 04:04 AM
Joined Dec 2011
With HK carrying so much RJX stuff now it's surprising they haven't started carrying the RJX helicopter kits too.
Old Feb 21, 2013, 07:56 AM
WOS is offline
WOS
Find More Posts by WOS
WOS
United States, IN, Michigan City
Joined Nov 2003
Dude!
Just give me your address. I have a align complete tail unit. Plastic blade grips but will be better than HK. Help out in the shipping department and will send it out to you
WOS is offline Find More Posts by WOS
Old Feb 21, 2013, 07:57 AM
WOS is offline
WOS
WOS
Joined Nov 2003
Thanks man!
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
