Old Jan 29, 2010, 02:53 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Tony,
but then what will i use to tape to the flybar and the frame as a flybar lock? hahah. That's what I have been using that antenna tube for. Great idea, thanks!
RCnewb,
I get what you are saying now with the washers to clamp down the servo.
Brian
Originally Posted by T-spin View Post
I cut the radio antenna tube in rings the thickness of the servo tabs. They are just the size to fill the hole. Used small washers on the stock screw,and used the stock backing plate. This pulled the servo up solid. No movement.
Tony
Tumbler is online now Find More Posts by Tumbler
Old Jan 29, 2010, 02:58 PM
Tumbler's Avatar
Joined Feb 2003
I wish I got the EXI CArbon for $140. BEtween the shipping from Hobby City and all the metal upgrades I had to buy for the GT, it cost me just as much. I had to buy the upgrades because plastic broke, not because the metal is nicer and more flashy.
I have had it built for over 2 weeks but only have a few flights on it just because the plastic tail case broke in flight and has taken me that logn to trck down the cause of the problem and order the right parts.
Brian
Originally Posted by mainblades View Post
rcnemb - I looked at the exi full metal version for 140.00. I would go with that one with no upgrades needed and get everything else from hobby king.
My flying style is going to be more 3d so that is why on the trex or the exi.
I know i can make it cheaper but getting everything that is not in stock at hk.
Barry
Old Jan 29, 2010, 03:01 PM
Tumbler's Avatar
Joined Feb 2003
I replaced the feathering and main shaft before even flying. i rolled them on glass and the Align shafts were perfect and ran great. After mine crashed and I replaced the stock tail rotor shaft with Align and now mine runs so much more smoothly. I suspect that the stock one was bent and I replaced with an Align part.
Brian
Originally Posted by techspy View Post
I had a lot of vibration as well. here is what I did.
Removed main shaft and tail shaft, main head and swash, tail head and disconnected the tail via the belt.
Place main shaft in drill press (just like ti was a drill bit) and turn on to see if shaft is bent. Do the same with the tail shaft.
Spin up and test just with motor.
Re-install main shaft and test
Reinstall tail shaft reconnect tail belt and test.
Install tail head and test
Install tail blades and test
Install swash and test
Install head and test
Install main blades and test
I found out I had a slightly bent main shaft and slightly bent tail shaft. Replaced both and smooth as buttah now!
Old Jan 29, 2010, 03:20 PM
ewoodcox is offline
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
What would u all think about this motor?
http://cgi.ebay.com/1X-HOBBYMAT-HB36...item414b0c17d6
Barry
several pages back folks kind of complained. You should use the thread search function on that motor and you can find the comments. One fellow said it vibrated or some such thing.
ewoodcox is offline Find More Posts by ewoodcox
Old Jan 29, 2010, 03:21 PM
Tumbler's Avatar
Joined Feb 2003
Thats the motor I have. Works fine for me as far as I can tell. Runs very smooth. Using 6s and 13t pinion.
Brian
Old Jan 29, 2010, 03:25 PM
Tumbler's Avatar
Joined Feb 2003
Well I hope it fixes it, but I am still waiting on the new aluminum tailcase from Hobby City.
Brian
Originally Posted by MutantGarage View Post
Has that fixed it? I have a 450 that does the same thing, at 4 minutes, the tail starts to come around. I figured it was the 'Mystery 401' gyro and set my transmitter timer to 3:30 and kept flying. Less wear on the LiPos
Old Jan 29, 2010, 04:24 PM
JapanFlyer is offline
Find More Posts by JapanFlyer
Joined Jan 2010
Thanks all for the pointers and advice. The main blades COG, balance, and weight distribution were spot-on out of the box, but did not balance the tail blades at all!! Will take off main blades and watch vibration, then balance tail blades and look again. The vibration is in the boom area, not the main frame.
Didn't notice any vibration on first spin-up without the main blades, however.
If that doesn't resolve the issue, will go through the techspy rebuild plan.
Robin's comment about system resonance was interesting.
Thanks much.... just a little closer.
--Kirt
JapanFlyer is offline Find More Posts by JapanFlyer
Old Jan 29, 2010, 04:25 PM
Tumbler's Avatar
Joined Feb 2003
Yeah I am impressed with the blades. I have had 2 sets of the same blades and they cg and balance to the gram out of the box.
--Kirt
Old Jan 29, 2010, 04:49 PM
Joined Jan 2010
Originally Posted by rcnewb View Post
This is unrelated to the 500GT, but thought this thing was so neat I had to post something for it...
http://ardrone.parrot.com/parrot-ar-...videos/#player
Might be a hint of where R/C could be headed in the future...
I requested a developer set.... but looks like I'm behind thousands of others.
Old Jan 29, 2010, 07:00 PM
T-spin is offline
Find More Posts by T-spin
Joined Mar 2005
Spun mine up without the blades on tonight everything went the right way. Luck . Maybe a fair day next week to try it out.
Tony
T-spin is offline Find More Posts by T-spin
Old Jan 29, 2010, 08:41 PM
fishboy77 is online now
Find More Posts by fishboy77
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
What was the temperature like when your tail case broke? Same thing happened to this guy (although he was just spooling up), but he still likes his HK500.
http://www.helifreak.com/showthread.php?t=184319
fishboy77 is online now Find More Posts by fishboy77
Old Jan 29, 2010, 08:44 PM
Tumbler's Avatar
Joined Feb 2003
30-35
Originally Posted by fishboy77 View Post
what was the temperature like when your tail case broke? Same thing happened to this guy (although he was just spooling up), but he still likes his hk500.
Old Jan 29, 2010, 11:36 PM
Lloyd Robinson
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
30-35
Yeah that probably had something to do with it.
Old Jan 30, 2010, 02:40 AM
markos51 is offline
Find More Posts by markos51
Joined Jan 2010
I would like to ask some help from the forum.
I finished assembling hk 500 gt.
I bind the receiver Ar6110e .
I use for left aileron servo : aileron input , rigth aileron servo :aux input. Throtle input : esc , gyro :rudder input gyro ajust : gear.
Everything works but not rigth servo.
I bind again and check the receiver and servos.OK
If i disconnect both ailerons (all others are connected) turn the receiver on and first plug one aileron it works , then connect the second aileron (receiver is always on) every works fine.
If now turn receiver off and turn on again the same problem.
Bind again but nothing.
It look like if both aileron are connected at the same time rigth can not work.
The dx6 position i bind is factory settings.
I changed to type heli , swash 120 , -60 -60 +60.
Servo, gyro and esc are models hobbyking suggest under the hk500gt page.
Thank you .
Markos
markos51 is offline Find More Posts by markos51
Old Jan 30, 2010, 09:04 AM
vaporboy is offline
Find More Posts by vaporboy
Joined Oct 2007
Just ordered a 500 GT from HC and a day later they announce an upgraded one coming in the next month - typical !!!
vaporboy is offline Find More Posts by vaporboy
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
