I found the timing auto on special functions to be the best don't know about that motor. also auto startup power. Start up speed middle or you will be waiting a long time for spool up. Also don't forget you have to enter each time or your inputs won't take effect. A easy way to know is when your done go back threw the whole menu, don't worry this won't change any set, settings. If your set it, it will show if not it will be back on the last setting. That is one thing that threw me way off.
Latest blog entry: Logo build
Well I was use to not hitting enter until you were finished lol!
I had tried all those settings and found that it jumped and had issues getting the motor started, turning. I knew about the start up power (I think that has to do with the getting the motor started) but had totally missed the auto timing on special functions. I have this on my airwolf and people are always asking what speedcontrol I am using because it starts so smooth and speeds up constant. Zero hesitation and zero jerking.
Joined Dec 2011
Joined Dec 2011
Canada, ON, Muskoka
Joined Jul 2011
Glen Edit: I should have removed the blades when I made the change to the esc, figured it was ok after having just tried at 8%, lesson learned, the hard way. You can't trust cheap(er) Chinese electronics, without safely testing. |
Sorry to hear about the misspah Muskoka1. I'll remember to take off the blades for the next change.
I'm currently on 4% startup power and there is no jerking and miss firing on the blades. Its is very smooth, but I do want it a little slower to spool up so I'll give the 2% a try and see what the outcome is for me. |
That percentage is not for soft start up. New motors with super magnets need initial power just to start moving. I am sure you have seen a heli start up were it just make strange sounds and the blades shake. That is was the startup power is for and I found best in auto.
Startup speed is your slow start mid, and high that you find on most speedcontrols. Here is the video of mine starting up. All set for auto with a Leopard 500l motor with super magnets. No Gov.
With stronger magnet motor if you set the startup power too low and the startup speed to slow you will get that power blip from hell that muskola has experienced. Because the strong motor won't have the power to start spinning and by the time it does the auto slow start will already be at 30-40%
Hope all that makes sense! I played with mine and had some close calls (before it was in the fuse) before just setting it all to auto lol! |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
