Old Dec 13, 2012, 08:22 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Originally Posted by mhills51 View Post
Temperature can do that. Is your speedcontrol under your battery tray and getting too hot?
Heh, that was kind of an 'aha' moment for me. The ESC doesn't seem to get that hot though, and it is stuck to the bottom of the tray with somewhat insulating layers of velcro. I'll sure check it out next time.
eagle777 is offline Find More Posts by eagle777
Old Dec 13, 2012, 08:42 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Just maybe another difference between quality packs and the cheaper ones. I was just trying to figure out why that one cell and that was all I could come up with lol!
mhills51 is offline Find More Posts by mhills51
Old Dec 13, 2012, 10:29 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
I did had my speed under the tray for over 150 flights. What I found was my packs came down warmer than my esc or the same.... around 40-45deg (middle cell).
In the mfg process I doubt they use one batch for each cell number. ie batch 1 is only to be used in a pk as cell one and batch 2 can only be used to cell number 2 in a pack etc..
How mAh are you putting back into your lipos after a flight and are you fast or balance charging?
evltoy is offline Find More Posts by evltoy
Old Dec 13, 2012, 10:34 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I put about half to 65% back in, 1C rate. I have 6 chargers, so am not in a hurry.
Old Dec 13, 2012, 10:44 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I can not balance these cheap HK CF tail blades shown in the pic above. I've spent about 1.5 hrs total statically balancing the tail rotor again, then finding the CG of the blades, then statically balancing the rotor + blades. I put the assembly on the tail, and it vibrates the boom so the tail push rod almost hits the boom. Blindly putting tape & more tape at the CG of either blade to see if the vibration gets better or worse. It is always bad. Shoot. I'll try again with Align plastic blades. The tail rotor bearings are suspect also but don't seem to be sloppy.
The main head and main gear seem to be well balanced. It was just after I changed to the Tarot tail the vibration happened. Tail shaft is new Align.
Old Dec 13, 2012, 10:52 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Tt?
Old Dec 13, 2012, 10:53 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Tt?
This is the new Tarot belt tail case with new never flown bearings. I meant tail rotor shaft
Old Dec 13, 2012, 10:55 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
I still can't figure out how people mount something like a Plush 80A or YEP 80A under the battery tray without it hitting the pinion.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Dec 13, 2012, 10:57 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Oh yes.. thats right, you have the belt.
sorry. hard to keep up with everyones config.
Old Dec 13, 2012, 10:59 PM
Joined Dec 2011
The Robird showed me that even with balanced tail blades the tail vibes go up dramatically when you run the head over 2600 RPM. The problem is that you're overdriving the tail, that's why they changed the tail gearing on the 500 Pro. On my 500 the tail vibes are almost non existent till around 2700 RPM and then the tail vibes shoot up into the red zone.
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
The plush is about the same size as the ecs I had HK SS 70/80A. I fit mine under the tray without any problems.
I guess it all depends on your cable management.
Old Dec 13, 2012, 11:27 PM
Joined Dec 2011
That's not the problem, the problem is that the ESC touches the pinion. Do you have the new style frame with the dropped battery tray or the old style frame?
Old Dec 13, 2012, 11:32 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
I have the GT kit with no battery tray mod.
My Esc is extreamly far from the pinon. I f was close I would have not mounted it there
http://www.rcgroups.com/forums/showa...7&d=1334637963
http://www.rcgroups.com/forums/showa...6&d=1334637963
Old Dec 13, 2012, 11:52 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
I have a hobby wing 80amp under my align 500e battery tray...just lower the esc away from pinion. ( using Velcro as backing of course) and just let the butt of the esc ride over screw tube. ( lack of a better word )
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Dec 13, 2012, 11:56 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
whats that Dejavu*Xion!!! ride that butt in your Avatar?
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
