Atomic Skull - good pick!
This could be the issue I have with my 550 too. Funny thought that I dont have this problem on my 500fbl that I'm currently building and I have the same bell crank on both helis. On my 500fb have the Align Metal Tail Rotor Control Arm Set H60186 (no cup) which has no binding on either plastic or metal tail case. On my 500fbl & 550fb I have the Align Metal Tail Rotor Control Arm Set H60186A (with cup) which has binding in the centre only o the 550. This now all makes sense why with the plastic kit arms have no bindings as it doesnt have the cups |
Sorry guys. nothign to do with helis but I need to show you all this.
First I had a look at the 500fbl that had the cup style bell crack (Align metal control arm) and found that I had 2 shims in place between the bearing and the tail case mount. Then I checked the 550 and found I only had 1 shim in place. I added the copper shim that came with the hk kit and immediately the binding had disappeared. The whole setup is smooth as butter now. Thanks guys for the ideas & help solving the issue. |
Seattle Area
Joined Aug 2007
I had somewhat asked around at the field, but no one has had this problem. Is there someone here that has wrecked a cell that was closest to the velcro & frame? I am wondering if it is chance, or shtty batteries. Edit: Checking 'lipo vibration battery failure' doesn't come up with much. The cell contacting the battery tray would have the most contact vibration I suppose. If you strapped the pack tightly down to the tray, maybe that would have more effect on the plates & structure of the cell. Who knows? I'll treat my new packs the same way I guess
Seattle Area
Joined Aug 2007
I'm pretty committed with the packs, new connectors installed. Hmm, wish me well. Or not ill at least. Fast shipping!
Still need to put the TT on the blue heli, the vibration on the red tail (500 #2) is a bitch still. Edit, excuse the right pointing nose on 500 #1, the left grommet was off Agh. Anyway. carry on. I wish I had a different cheaper cooler funner less work hobby sometimes.Oh, who am I kidding, I just need to get more focused. |
. This hobby is a lot of work and a constant money siphon. I have 4 helis, and it all ways seems to be a constant upkeep. Its rare that I have all four flying perfect. I imagine it to be like taking on a new wife with a bunch of kids. Lol. ..And yet we continue, something to do I suppose.
Joined Dec 2011
Had a tail boom break due to apparent metal fatigue today. Was doing repeated piro stops and noticed the tail rotor was at a 30 degree angle so I landed immediately and saw that it had cracked where the clamp holds the boom and was bent at a 15 degree angle. Didn't hit anything with the tail it just cracked in midair. If it had been a TT I'm pretty sure it would have crashed.
EDIT: I think it was the 10mm screws I was using to hold the boom supports, they had dug pits into the boom and it cracked right at this point. Going to switch back to 8mm screws. Also the tail belt is perfectly fine. |
Seattle Area
Joined Aug 2007
Maybe the mfr installed a bad cell in each pack and somehow they got to the U.S. No idea. I've used a lot of Turnigy Blue 3S and 4S and never had a cell go bad like that. Generally all the cells degrade at the same time. |
Temperature can do that. Is your speedcontrol under your battery tray and getting too hot?
Latest blog entry: Logo build
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
