Old Dec 08, 2012, 09:56 AM
2Doggs is online now
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Hey Hills, you haven't got a pair of power door mirrors and an A/C compressor for a '97 Chevy Venture have you?
2Doggs is online now Find More Posts by 2Doggs
Old Dec 08, 2012, 10:36 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Right or left mirror??
mhills51 is offline Find More Posts by mhills51
Old Dec 08, 2012, 12:04 PM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
Right.... too much English driving! (where you learn to get real close on double-parked streets)
Old Dec 08, 2012, 04:32 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Originally Posted by eagle777 View Post
Hey Evl, just received the parts. If you still wanted to know, the Tarot tail has the conventional button. (TL50073)
Thanks for the pic. Looks like I'll be swapping of my HK metal tail assembly for this one. Hope the shaft etc are interchangable
evltoy is offline Find More Posts by evltoy
Old Dec 08, 2012, 04:35 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Here you go http://www.partsgeek.com/gbproducts/...FU6mPAodLBAAYA
Old Dec 08, 2012, 04:45 PM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
Not a bad price! Might go for the two-tone look then, black on one side and painted on the other!
Old Dec 08, 2012, 07:21 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I installed the tail today. Unfortunately, the mount for the control arm is about 2mm closer to the tail rotor shaft compared to the old tail case. The Align and Tarot control arms I have make the slider bind when near the center position. I'm not sure what to do about it.
eagle777 is offline Find More Posts by eagle777
Old Dec 08, 2012, 07:48 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
What do you mean by center? I had to screw in my tail control shaft about five turns and mine worked when I changed from the align plastic tail to the tarot metal for the airwolf. I also had to loosen my tail boom and slide it forward about 1-2mm for proper belt tension. Sorry I got it. What slider are you using?
Old Dec 08, 2012, 08:15 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I've tried both the plastic align and the aluminum Tarot arms. The Align doesn't bind as much as it has a sloppier fit. In this position, the slider binds the most. At either end, it doesn't bind. The red line describes the distance I was talking about. With this Tarot case, it seems about 2mm shorter distance than the Align or HK ones.
Old Dec 08, 2012, 09:30 PM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
That's odd! You wouldn't think a single-sided arm would bind, since the slider is free to rotate.
The plastic link looks like it's upside down though! (maybe you took the other end off the servo)
Old Dec 08, 2012, 09:57 PM
eagle777 is offline
Closed Account
Joined Aug 2007
As the slider reaches the center of the tail rotor, the arm pushes the slider ball back more to the rear of the heli, pressing against the rear of the inside of the arm (which is locked in a vertical position). The slider ball can tip a bit normally, but this arm is making it tip too much.
Old Dec 08, 2012, 11:03 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Something is really messed up with your bearings there in the pic, I don't think it is assembled right.
Old Dec 08, 2012, 11:25 PM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
I see what you're saying now - the arm is effectively too long, so at the centre of travel the linkage ball is capsized to the point where it binds against the arm. If you had a photo in side view, it would show the slider at quite an angle to the vertical.
Maybe you could find another ball link that works, or even grind down the base of a ball link to prevent the binding.
Odd (and very annoying) that there should be a whole 2mm of difference in the tail casings!
Old Dec 08, 2012, 11:43 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Heh, I flew it once today and both bearings fell apart. Luckily it just stripped the small auto gear. I didn't want to mention that cuz I thought it was unrelated to the arm length issue that I found when I first started building it last night. Probably. Ugh. I still have my Align TT assembly that just needs gears. Maybe I'll just get a gear tomorrow and re-install that. I'm not impressed with Tarot so far. I didn't really want to go back to the Align plastic tail case just for its looks.
Old Dec 08, 2012, 11:54 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I was going to say from the pic the belt is pulling the shaft to close and that was what was throwing off the slider. If it's not one thing it's another!
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 08:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
