Old Dec 06, 2012, 11:38 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by evltoy View Post
How did you manage to strip the screw in the first place?
Are you talking about stripping the Hex head of the screw or the thread?
The hole in the motor that the screw goes into. It just stripped from multiple cycles of being tightened and untightened.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Dec 06, 2012, 11:40 PM
Moonbeam is online now
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Originally Posted by ridge_racer View Post
If you need a metal head I have a new flybared head I don't need since my heli is FBL. Send me a PM if interested...
Thanks for the suggestions folks! True I do have a lot of good help here, but you can never disregard the many great opinions and advise one can find on RCG. These forums are a "Godsend", and have helped me with this hobby more times than I can count.
Like Eagle777 basically says, it seems this situation is a "hit & miss" type. I might get away with being cheap (but not at the expense of safety!), or I will end up spending what I would on a good new/used heli.
What I really need to do is decide just how soon I want to get it in the air. If I can't resist any longer, I should probably by a Blade 450. If I can hold myself back, then I can pick & peck at this one a few dollars at a time til it's done.
Ridge_racer, PM sent.
Moonbeam is online now Find More Posts by Moonbeam
Old Dec 07, 2012, 10:12 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Will do beenflying
I will be getting few YEP for the 500's, 550 and thinking to add one to the 450 too.
As I have a budget per month for this hobby I have to wait till next week or so to buy. I just hope they are still around by then.
On the topic of the YEP.. I did read somewhere that people are putting heat sinks on them. Is this a must?
I have 4 YEPs and none have any heatsinks - all stay cool
Buddy codes have a life - best checking that they won't finish before you can buy
MikeHRC is offline Find More Posts by MikeHRC
Old Dec 07, 2012, 10:25 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
will the program card for the YEP from HK work with the himodel?
thanks for the heads up on the 45A YEP. I may rethink and get another plush.
Yes the prog cards are interchangeable.
The 45 is the same size as the 100, big for a 45 but still usable a nd a bargain for what they cost
Old Dec 07, 2012, 11:17 AM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Originally Posted by MikeHRC View Post
The 45 is the same size as the 100, big for a 45 but still usable and a bargain for what they cost
That surprised the heck out of me when my 100 arrived. Mind I've always been told it's not how big it is it's what you do with it.
Excellent controllers for the price.
Paul 1968 is offline Find More Posts by Paul 1968
Old Dec 07, 2012, 04:46 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
YEP. I just bought 3. 2 for the 500's + 1 for the 550
Thanks for the info in the prog crads. That is very good to know
evltoy is offline Find More Posts by evltoy
Old Dec 07, 2012, 06:09 PM
Joined Dec 2011
Found out the cause of the yaw, it was the new battery. I'm pretty sure than the old 3S's I've been doubling up are sagging under load. With the new battery more torque gets dumped into the helicopter on a hard climb and it cause the yaw. With the old batteries this doesn't happen. so I need to drop 1 pinion and rework my throttle curve. It also looks like I can set the gain 5% higher with the new batteries without causing problems with piro stops for some reason. Maybe the momentary load was causing a voltage sag that messed with stop behavior.
Old Dec 07, 2012, 09:16 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Hey Evl, just received the parts. If you still wanted to know, the Tarot tail has the conventional button. (TL50073)
eagle777 is offline Find More Posts by eagle777
Joined Dec 2011
Button?
BTW I always secure the bearings in the Tarot sideplates with the green anaerobic retaining compound. The bearings are a bit looser fitting than the real Align tail. Not actually loose in the holes but they aren't an interference fit like with the Align tail. There' supposed to be a shim on the long side of the tailshaft to keep the pully from moving side to side in the tailcase.
Old Dec 07, 2012, 09:20 PM
eagle777 is offline
Closed Account
Joined Aug 2007
To lock the tail and keep it from rotating. I dunno. The round raised feature that is part of the tail assembly that fits into the hole in the side of the tail boom.
I'll put some Locktite on the bearings now that you mention it. There is no side play at all in the shaft. No shims included either..
Old Dec 07, 2012, 09:27 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Might look a little closer. My tarot came with a shim, but I didn't see it until latter. It didn't mater because I used the align pulley and it didn't need it, but after playing with the tarot pulley I saw the shim.
mhills51 is offline Find More Posts by mhills51
Old Dec 07, 2012, 09:38 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Ohh, OK.
I had to get up, look for a shim, find it, and measure it. There is a 0.011" shim on the short end of the shaft. The aluminum pulley part is cruddy at the ends, and I'll replace that with an Align part.
Edit, I keep hearing about the quality of Tarot parts, but have had issues with screws that break off at the head in the tail grip and other stuff. For example, with the new tail, the aluminum pulley is not something I'd expect even from XHeli/EXI. It could be cut off with an razor, but it is pretty sloppy. I hope the Align shaft will not have any play. You still get what you pay for.
Mhills, would you know what MG sets are are available for the SM-3481M? Did you buy them at one time?
Old Dec 07, 2012, 11:06 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Ohh, OK.
I have them, Is there something you need? I will just send it to you. I had a bad one from the get go and they just sent me a new servo. I can send you the gears if you need them.
Old Dec 07, 2012, 11:26 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Hey, thanks! I was just wondering if they were a clone of a well known brand and model that I could get gears for in the U.S.
I was just looking for spares. I haven't taken one apart yet, and was hoping to get a supplier for a few spare sets, and you're about the only person I know that has purchased them.
Old Dec 07, 2012, 11:39 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Have not seen any, but if you need some just look me up. Trying to teach my kids that just because we have no money does not mean you can't help they guy down the street.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
