Old Dec 04, 2012, 10:47 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Originally Posted by mhills51 View Post
My only thought is your running a lot of weight. I would lower your pinion back down to a 12t. The stock always tries to push the highest gear to push the best numbers. If you over load the motor it will make things way off, it maybe just a mater of over gearing. I have set up many 500's with many different motors. The total stock set up will not like throttle under 80% because of power issues. If your governor is trying to work under 80 that could add to this issue.
Also 500L motor comes down pretty hot. I thought that was normal, the guy I fly with flies pretty soft 3D, but his 600 L type motor is really warm after a flight.
Thanks mhills, that sounds like my problem. Get rid of the gov, go 12T and I should get a few 2600mah packs also.
eagle777 is offline Find More Posts by eagle777
Old Dec 04, 2012, 10:49 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Just looked at your set up and I would think your way over geared. Someone using 2600 packs maybe could get away with it.
Do you think I should I go with 12T, and no governor with the 500L motor and 2600 packs Open to making my helis fly better for sure! Or just tell me how to set this 500 up, I'll do it. I'm kind of operating on my own for the most part when it comes to the finer points of setting up a 3D 500.
Old Dec 04, 2012, 10:51 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I would keep everything you have! Start with the 12 and see how it works!
mhills51 is offline Find More Posts by mhills51
Old Dec 04, 2012, 10:52 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
nothing to say
evltoy is offline Find More Posts by evltoy
Old Dec 04, 2012, 10:56 PM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Look at the post again. I got the pictures on it this time.
I forgot to attach them before I hit post. Anyway, there it is.
Moonbeam is offline Find More Posts by Moonbeam
Old Dec 04, 2012, 10:59 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
My HK500 with the 12t and clone 500l was a great flying machine. Smooth and graceful in the air.
Old Dec 04, 2012, 11:01 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Originally Posted by evltoy View Post
nothing to say
Heh, It's like everything I know is wrong after looking at some graphs! It's more interesting than flying airplanes though.
Old Dec 04, 2012, 11:05 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
It looks like a http://www.leaderhobby.com/ 500
Old Dec 04, 2012, 11:14 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Yep.. a leaderhobby quality. Be very careful with that head. Also dont forget to be some stickers on the flybar paddles to cover those holes
Old Dec 04, 2012, 11:16 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Sound like what I was getting in normal mode. what are your Th curves without the gov on?
Without governor it's 0-35-55-70-80-90-100 in normal mode and 100-90-80-72.5-80-90-100 in idle up. Tail holds perfectly even in a hard climb. Hover is between 80% and 85% throttle.
Set it to 85% flat throttle curve with the governor and the tail would kick on a hard climb.
I was thinking the same. Gov would be like running a flat curve which would provide a more constent HS.
I'm pretty sure I know exactly what's going on, the governor is lagging behind the change in pitch. It only happens if you instantly bang the stick from hover to full climb. If you soften it a bit it doesn't happen. Unlike an FBL governor an ESC governor can't see collective changes as they happen, it can only react after the fact when the RPM drops.
Another odd thing is that the head runs about 100-150rpm slower with the YEP 80A than it did with the Plush 60A. I calibrated the throttle multiple times to be sure that wasn't the problem. It just seems to run the motor slightly slower than the Plush did. On the other hand the batteries don't get as warm either.
With active freewheel mode on the motor will spin up and when it reaches midstick it'll slow down for an instant before speeding up again. This only happens once as it spins up, is this normal? This does not happen with freewheel mode off.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Dec 04, 2012, 11:18 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
The whole point of a governor is that it won't lag behind the pitch
Old Dec 04, 2012, 11:22 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Motor may not like 85% curve at full pitch which may bog the motor and giving the tail kick
run the gov at 90% and see what happens
Old Dec 04, 2012, 11:32 PM
Moonbeam is offline
Moonbeam's Avatar
Joined Mar 2004
Looks "close" but not exact. I saw an EXI one that looks like this too (particularly the flybar). The difference between the Leaderhobby and mine are that where theirs is carbon fiber, mines aluminum. And where they have aluminum, I have plastic.
It's looking like in order to make this one safe and useable, I would end up spending the same as I would buying a better kit. Kinda think I have a fancy paper weight here.
Old Dec 04, 2012, 11:36 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
The body and most parts would be "ok" to start off with. The questionable parts like plastic head should be replaced.
To me it looks like a few clone brands have made up your heli which is nothing new here.
Old Dec 04, 2012, 11:43 PM
Joined Dec 2011
The thing is though, the tail is perfect without the governor. It's only with the governor enabled that I get problems.
90% sort of defeats the purpose of running a governor in the first place as there's insufficient room to keep the headspeed constant. Might as well just drop a pinion and run an ungoverened flat 100%.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
