Old Dec 04, 2012, 05:57 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Or you can set up your normal for 0, 85, 85, 85 and idle up 85, 85, 85, 85, 85 and so on, Or can you not do that with the newer governors?
mhills51 is offline Find More Posts by mhills51
Old Dec 04, 2012, 06:15 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Originally Posted by whitehedr View Post
oops, yes I did mean FBL.
RWW
I'm doing a conversion as we speak. HK500CMT with RJX FBL head & ZYX FBL gyro
evltoy is offline Find More Posts by evltoy
Old Dec 04, 2012, 07:38 PM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
You can, but I don't think I will be using the governor because it causes a nasty tail kick when you punch the collective hard.
Atomic Skull is online now Find More Posts by Atomic Skull
Old Dec 04, 2012, 08:04 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
hmm. sounds more like a gyro gain or pitch setup issue.
then again I have yet to mess with gov on ESC's
Old Dec 04, 2012, 08:54 PM
Joined Dec 2011
No, it's perfect without the governor enabled. Tail stays like it's held in a vice on a hard climb. With the governor enabled though it kicks out about 10 degees and then comes back as the as the governor tries to keep the headspeed constant. The problem seems to be that the governor isn't aware of pitch changes, it can only react to RPM changes after the fact. The governor in the Robird would probably not have this problem, but I'd need a single line RX for that.
Old Dec 04, 2012, 09:15 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
You should get far less kick with a governor than without. That is one of the pluses of using a governor.
Old Dec 04, 2012, 09:52 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Sound like what I was getting in normal mode. what are your Th curves without the gov on?
I was thinking the same. Gov would be like running a flat curve which would provide a more constent HS.
Maybe the motor is bogging down as its not setup in its sweet spot when in gov mode???
Old Dec 04, 2012, 09:58 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Originally Posted by eagle777 View Post
So yeah, about 2600 governed. Flies well for me. 2900 sounds a bit fast, especially with weights flying out of the blades and such
Doh, sorry Ridge racer. this (posted earlier) graph is with the Align 500L motor and a 14T pinion. I installed it some time ago. I couldn't achieve 2600RPM with a 13T and good overhead, according to the CC software.
I'm not sure if I have too much cyclic or my batteries are weak, or poor collective management, hence the drop in rotor speed. Any opinions? Probably some of all the above.
Too many helis to keep track of.
eagle777 is offline Find More Posts by eagle777
Old Dec 04, 2012, 10:13 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
eagle777....More than likely a combination of things. What is your setup again? For reference I have a Hobbymate HB3650 1700kv motor, 13t pinion, Hobbyking YEP80 ESC, and Nanotech 35c 6s2650mah packs. No puffing on the packs or bogging. For now I lowered my throttle curve so that at 0 pitch I should be about 2700rpm and only a 5% increase with higher pitch.
ridge_racer is offline Find More Posts by ridge_racer
Old Dec 04, 2012, 10:22 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I have the ICE 75, Align 500L w/14T, Blue Lipo 30C 3300 6S, 100% TC (governed).
Old Dec 04, 2012, 10:29 PM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Need a Heli Detective!!
Hey Gang,
A member of my flying club gave me this heli frame. He said it was a Hobby King clone of an Align 500, BUT after looking at ALL the Hobby King 500 series heli frames, this doesn't look like any of them. at best it looks like a combo of some of the GT and CMT, but the skids look nothing like any of the HK 500's and there's a lot that seems "changed". Unless this is an older one?
The main rotor head is almost all plastic, the tail rotor section is all plastic, then main rotor gears are white nylon. The top, sides and bottom of the main frame (as well as the tail boom), are all aluminum as are the tail fins. It's a belt drive tail rotor as opposed to torque tube style. The motor is actually an Align brand. That's all I have. Trying to decide if it's worth building up or not.
I'm new into helis, with experience only in the Blade CX2, Scout and MSR (which is a blast!!). I was hoping to hop up to a Blade 450 3D, although 3D is not my goal. I'm a scale guy who loves to build replicas, and since this 500 "landed in my lap", I'm looking to make either Airwolf or a Hughes 500E. I wanted to do an Apache, but doing the geared 45 degree tail looks like more opportunity for failure.
So, if anyone can help point me in the right direction, or knows what the hell this thing is in my basement shop, I'll send you a Christmas card!!!
Moonbeam is offline Find More Posts by Moonbeam
Old Dec 04, 2012, 10:33 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Looks liek the guy has replaced all the faulty HK parts with other brands. put some pics up and we might be able to tell you what you have.
Just becasue Blade and other brands put 3D in the title... it doesnt mean you cant fly it normal & in some cases doesnt mean it is 3D capable. The lable 3D is a way to suck newbie to thinking its the "best" heli.
Old Dec 04, 2012, 10:35 PM
eagle777 is offline
Closed Account
Joined Aug 2007
All mine are a mix of HK, Align, some EXI...No pedigree on these things Yeah, post a pic.
Old Dec 04, 2012, 10:38 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
My only thought is your running a lot of weight. I would lower your pinion back down to a 12t. The stock always tries to push the highest gear to push the best numbers. If you over load the motor it will make things way off, it maybe just a mater of over gearing. I have set up many 500's with many different motors. The total stock set up will not like throttle under 80% because of power issues. If your governor is trying to work under 80 that could add to this issue.
Old Dec 04, 2012, 10:41 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Just looked at your set up and I would think your way over geared. Someone using 2600 packs maybe could get away with it.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
