Old Nov 29, 2012, 08:09 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Originally Posted by stingeragents View Post
Did that one guy ever show back up? The one with all the questions,lol
which one?
I'm asking alot of question atm...
evltoy is offline Find More Posts by evltoy
Old Nov 29, 2012, 08:19 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Yeah, that's why I went with 16mm (~15.5mm). IIRC, I wasn't getting enough collective with the ZYX recommended 14 - 14.5mm. Also, when I was using the TGY 930 servos, at 14.5mm the link ball would hit the servo case very early in the throw. I've just stuck with 16mm from then on.
eagle777 is offline Find More Posts by eagle777
Old Nov 29, 2012, 08:20 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Haha, I thought you dropped out for good. Still have any helis?
Old Nov 29, 2012, 08:22 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
thanks eagle for clearing that up.
I'm having a really dumb day today.. search for a 500Cf manual when I alrewady have one... it the manaul I build me 500Fb with!!!
What got me was I didnt know that the servo ball lengths were the same between FB & FBL.
Old Nov 29, 2012, 08:32 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Now I'm wondering what my actual pitch angles are. I'll have to check again. They fly well, but I set travels up once using a pitch gauge, make sure nothing is binding, then forget about it if it works well.
Old Nov 29, 2012, 10:05 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
I just put a set of Pro tail grips part # H50119B and I'm having a weird problem. When the slider moves all the way toward the tailbox it's possible for the pitch control links to turn inside out and lock the slider. This is being caused by the arms on the grips being 1mm shorter than the arms on the ESP grips. Is this normal for the Pro grips or is it just a problem with using the Pro grips on an ESP tail?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 29, 2012, 10:09 PM
2Doggs is online now
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I had the same thing on my 450, with a longer than standard tail rotor shaft. Since it's in the direction with main rotor torque, just set the gyro right limit to prevent the links going over centre. You don't need that much right pitch unless you really want to equalise piro speed in autos....
2Doggs is online now Find More Posts by 2Doggs
Old Nov 30, 2012, 01:08 AM
Joined Dec 2011
Figured out the problem, the 500 Pro links that came with the slider are a few mm shorter than the ESP links. Switched the links and it's fine now. Shorter links didn't cause problems on the ESP tail grips but the combination of slightly shorter links and slightly shorter pitch control arms on the Pro grips stacked up and caused it to be able to lock.
Anyway, all I need now is a tailcase and I can build a second 500 out of leftover parts.
Old Dec 02, 2012, 07:32 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Originally Posted by Black_heart View Post
OK is it me asking to much or is no one looking for used 500 sized Trex clone helis?
http://www.rcgroups.com/forums/showthread.php?t=1773909
Black heart: Here is a link for you to compare. Just dont want ya to think we were being hard core with ya. This link will show what a decent 500 sells for nowdays.
http://rc.runryder.com/helicopter/t718599p1/
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Dec 02, 2012, 07:58 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I will do one better than that, http://www.flying-hobby.com/shop/tre...on-p-7951.html $425 and brand new!
mhills51 is offline Find More Posts by mhills51
Old Dec 02, 2012, 08:53 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
you guys can stop now because I well drive that peace of sh^& into the ground before I sell it as cheap as you want me to!!!!
Black_heart is offline Find More Posts by Black_heart
Old Dec 02, 2012, 09:20 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
wow. so even you believe its not worth the price you wanted by saying its a POS..
Old Dec 02, 2012, 09:27 PM
Texas NewB
Joined Dec 2011
NO i dont but all you guys think it is!
Old Dec 02, 2012, 09:28 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Fair enough
Old Dec 02, 2012, 09:32 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Had a blast flying my 500esp like I do on the sim today. Finally started inverted circuits and inverted piros etc. I was in the middle of an on axis roll when bam........the tip weight blew out of one of my blades. Second time this has happened with a set of Target Hobbies carbon blades. I have the HB3650 1700Kv motor on 6s with a 13t pinion. idle up 1 throttle curve is 95,90,90,90,95. I think the YEP80 esc is looking at anything 90 and above is =100 throttle. I notice an rpm increase from 85-90 when going from normal to idle up at mid stick. My first 500 build guys so please don't kill me. What should I be shooting for in regards to head speed for great power in 3d? I'm think I should just lower idle up across the board by 5% or lower mid stick only by 5%.
ridge_racer is offline Find More Posts by ridge_racer
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
