Old Nov 26, 2012, 04:16 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
I played around with the Rjx FBL head last night. WOW! I'm very impress with the quality and looks of this kit. The kit comes with everything other then linkages which I was surprised about.
In my kit I had the following
Feathering Shaft & bolts
Hard quality dampeners (Black)
Thrust bearings
Smooth Bearings in Main grips
And everything in the product pics.
Question time:
Did anyone use the Align feathering shaft sleeve with the RJX head?
What lengths were your linkages from the main grips to swash?
Are the servo linkages lengths to swash still the same as an Align FBL head?
evltoy is offline Find More Posts by evltoy
Old Nov 27, 2012, 12:06 AM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
double post
Atomic Skull is online now Find More Posts by Atomic Skull
Old Nov 27, 2012, 12:08 AM
Joined Dec 2011
Thrust bearings
Question time:
I used the shaft sleeve and it works fine. My grip to swash links are 54mm measured on a set of ball link gizmos attached to my calipers (measured from center of link hole) I'm using the upper hole and a standard shaft.
I found that the RJX balls are slightly oversized compared to standard so I had to ream the upper links to keep them from being too stiff. An alternative would be to replace them with standard balls. Swashplate link balls will fit the hole but are are slightly too long, the neck of the ball link should be 2mm from the arm to the ball.
I have my link balls set to 17.5mm which is the closest I can get to 16.5 as specified in the manual. The link lengths will be shorter than the Align FBL because the RJX head is a bit lower. What I did was set collective to 0 degrees and then adjusted the swash till the swashlocker arms were perfectly square. Just hold a small screwdriver or something in front of the three screws till they all line up. Then take the head off and put a leveler on it and get the swash leveled and you are done.
Old Nov 27, 2012, 11:45 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
evltoy & mhills, thanks for the advice about balancing. My link lengths for the 2nd 500:
Servo: 16mm
Servo -> swash: 50mm
Swash -> head: 54mm
Might give a average for evl.
eagle777 is offline Find More Posts by eagle777
Old Nov 28, 2012, 01:04 AM
eagle777 is offline
Closed Account
Joined Aug 2007
I found working the RJX grip links around bit will loosen them up. They will be perfect in a dozen flights or less. I don't like using the reamer any more, it accelerates the link wear.
Old Nov 28, 2012, 09:05 AM
mhills51 is online now
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
+1 I agree how much is too much?
mhills51 is online now Find More Posts by mhills51
Old Nov 28, 2012, 03:40 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
You guys seen this....http://www.ebay.com/itm/300814999408...84.m1423.l2649
Pretty cool.
Available in 450 size as well.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Nov 28, 2012, 03:46 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Atomic Skull &eagle777 - thanks for the linkage info. This will help me out alot with a good ball park to play in.
I have to agree with that too. My current 500FB had firm links at the start in the head and now after 150-155 flights its now loose and ready for replacement.
Old Nov 28, 2012, 03:53 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Pretty cool.
Yeah I saw that on the flying hobby site last night. I'm not keen on that style of landing gear... maybe good on a goblin, but not sure on a T-rex that is an ol' style design.
http://www.flying-hobby.com/shop/tre...t-p-10559.html
Its like putting chrome/metal trims on a 2010 plastic made car... it just doesnt go well.
I was looking at the KDE tail assimble and thought this would be a big improvement over the old style Align setup.
http://www.flying-hobby.com/shop/kde...ol-p-9740.html
Old Nov 28, 2012, 04:12 PM
Need More PURPLE !!
Joined Aug 2012
I ordered the landing gear for a 450 I have. Not bad at only $12..I think the look will work, only because the frame and tail boom is also carbon fiber. It should all blend nice..Will see ( If not its $12 i usualy blow throwing a turn of dice craps )
Old Nov 28, 2012, 05:51 PM
Joined Dec 2011
Mine were so stiff that I was worried about servo damage.
Old Nov 28, 2012, 05:53 PM
Joined Dec 2011
Pretty cool.
I tried the 540 Sport version and I didn't like them, the shoulder bolts that hold the CF skids to the metal brackets are designed to have slop and allow the skids to move.. I'd rather have the Gorilla gear as they will save your helicopter in a hard landing.
Old Nov 28, 2012, 05:57 PM
Joined Dec 2011
The new Pro style "standard" slider and bellcrank is actually a big improvement over the old ESP design. The plastic cup and moving the ball in closer to the center of the bearing holder greatly reduced the slop compared to the old version.
Old Nov 28, 2012, 06:02 PM
Need More PURPLE !!
Joined Aug 2012
I have the gorilla gear skids on both 500 and 450. Yes they are awsome skids. Good to know info on the slop with the shoulder bolts. Will see if i cant mod it
somehow.
Old Nov 28, 2012, 06:14 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Are you talking about the Align Part #H60186A?
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
