Espritmodel.com Heli Air
Old Nov 20, 2012, 10:59 PM
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
ahh... sorry. I just did a quick read and looked at the links.
Have to excuse me as I'm in the middle for writing code and me head is fried from doing it for the last 3hrs.
evltoy is offline Find More Posts by evltoy
Old Nov 21, 2012, 02:47 PM
Joined Dec 2011
Helidirect has the RJX 500 FBL head for less than Hobbyking now, and they carry the silver version as well.
http://helidirect.com/t-rex-500-flyb...de-p-18628.hdx
http://helidirect.com/t-rex-500-flyb...er-p-24229.hdx
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 21, 2012, 02:52 PM
Brb...Doorbell.
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Ya know what im looking for and just cant seem to find. Is the Limited Edition silver "align" 450 fb head. Or did align even come out with this in the 450 size ? Sure would like to find one.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Joined Dec 2011
Originally Posted by eagle777 View Post
Anyone getting tired of hearing about Hostess? I didn't know it was such a deal. Do a lot of people eat Hostess snacks? I haven't for quite a while, and really don't know anyone that admits to it. Probably the nostalgia, but I did see people buying like a $100-200 worth of Twinkes and HoHos and whatever else at the local Hostess store on the news. Heh, we can be so manipulated
I find it ridiculous that they are shutting down a profitable company just to make a stand on ideology. There's no way that "we can't afford to stay in business if were pay our employees decently" can be true with how profitable that company is.
Old Nov 21, 2012, 05:34 PM
Paycheck flyer
mhills51's Avatar
kansas city
Joined Feb 2007
Sometimes you can take the color off with oven cleaner.
mhills51 is offline Find More Posts by mhills51
Latest blog entry: Logo build
Old Nov 21, 2012, 05:58 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I really like the HK RJX head on my 450, and the 500 head looks to have three Jesus bolt hole options, which is handy for setting it as low as it can go.
Like the 450 head, though, it looks like it has really long grip arms. That results to the need to use longer servo arms, which will result in the servo to swash links being even more out of vertical.
Any idea what the distance is from the grip arm linkage ball to the centre of the feathering spindle?
2Doggs is online now Find More Posts by 2Doggs
Old Nov 21, 2012, 08:00 PM
Seattle Area
Joined Aug 2007
I measured about 29mm.
eagle777 is offline Find More Posts by eagle777
Old Nov 21, 2012, 09:07 PM
2Doggs's Avatar
Joined Nov 2009
Thanks!
Old Nov 22, 2012, 07:53 PM
Joined Dec 2011
I have an RJX head on my 500 now and it works perfectly fine with the links set to 19mm out on the servo horns as specified in the manual. In the Robird setup I didn't even have to adjust the collective pitch min/max sliders. +/- 12 degrees was the default 100% on the sliders.
EDIT: Actually this is wrong, the manual specifies 16-16.5 and I have them set to 17.5 which is the closest hole on the servo horns.
Old Nov 22, 2012, 08:30 PM
2Doggs's Avatar
Joined Nov 2009
That's good to know. On my 450, if I set up -12 to +12 and 8 of cyclic, I ran out of servo travel with 13mm arms, and ended up using 15mm arms. So the grip arm/servo arm ratio on the 450 ended up as 22/15 = 1.47, fairly comparable to 29/19 = 1.53.
As a matter of interest, how vertical are the servo to swash links at 50% collective? I gather Align moved the servos slightly further away from the mainshaft on the 500E Pro.
Old Nov 22, 2012, 11:06 PM
Seattle Area
Joined Aug 2007
Here's what I have at ~50% collective at more or less straight on. I understand it is non-optimal, but the head works well for me. I just bought a couple nut drivers for 450 & 500 to stop chewing up the grip nuts with needle nose pliers
Old Nov 22, 2012, 11:17 PM
2Doggs's Avatar
Joined Nov 2009
Serendipitous?
Thanks for posting the pic. The links look to be 2 or 3mm out of vertical, but at least all three are at more or less the same angle - so you'll get a differential pitch of only 3% or so. You get about that much differential from the angled links from the inner swash to the grip arms, but it's in the opposite sense, so everything cancels out, almost as if it was meant to be that way....
Old Nov 22, 2012, 11:28 PM
Seattle Area
Joined Aug 2007
Sorry, I thought you wanted swash to head. I'll attempt to make a measurement or two.
Old Nov 23, 2012, 12:20 AM
Seattle Area
Joined Aug 2007
The main shaft would bisect the horizontal lines, the end of the lines represent the ~center of the ball links. Hope this helps, I've learned a bit from your posts from the past day here. And elsewhere of course.
Last edited by eagle777; Nov 23, 2012 at 12:31 AM. Reason: I wish I had a CAD program to make this to scale.
Old Nov 23, 2012, 12:40 AM
Joined Dec 2011
As far as I know they didn't, the angled links on the Trex 500 were designed that way intentionally. One of Finless Bob's videos explains the reasons why the link geometry is the way it is.
http://video.helifreak.com/?subpath=...ame=geo101.wmv
I was wrong about this, the manual specifies 16-16.5mm and I have the balls on the servo horns at 17.5mm (the closest hole to 16.5mm on the horns that come with the 28013's) I guess I misremembered.
Only thing I don't like about the RJX head is that the swashdriver arms use an oddball sized bearing that's very difficult to find. The only place I've been able to find the 3x7x2.5 flange bearings it uses are from China based sellers on ebay. Replacement arms cost $22 from Helidirect or $10 from Hobbyking. Interestingly the replacement pitch arms are actually cheaper from Helidirect than from Hobbyking.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
