Old Nov 18, 2012, 11:06 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Here it is from amain, You can use the part number to find it else where. http://www.amainhobbies.com/product_...inion-Gear-11T
maybe it's time to look at a new motor. Most guys have found the align 500mx to be equal or better than the scorpion 1600. I have not seen anyone talking about any better motors right now.
For speed with a 12t and full battery no load your looking at 3665, but the calculator I use take into those factors. Under load you could see 3200 and that is what the Align 500pro manual list as well.
mhills51 is offline Find More Posts by mhills51
Old Nov 18, 2012, 11:52 PM
kdean is offline
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
I have a scorpion 3226-1600 ready to install with a cc ice 75, but i'm waiting for the 500tt to get here. I'm gunna put the slant gears in it and hope for the best. Thanks for the link, i'm gunna pick one up just incase of insane head speed.
kdean is offline Find More Posts by kdean
Old Nov 19, 2012, 01:42 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by mhills51 View Post
Sorry I don't use governor, but I thought with a governor your expose to keep a flat curve? like 85,85,85 that's what we use to set a few years ago. You listed 70,85,100 I would think this would really screw up the gov.
My current ESC doesn't have one but the YEP80A I have coming does. I would of course adjust the throttle curve accordingly once it's installed.
by 70-85-100 I mean 70% at zero degrees, 85% at +/- 5.5 degrees and 100 at +/- 11 degrees.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 19, 2012, 09:33 AM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
This is going to be great. As soon as ther out im Buying.
http://www.youtube.com/watch?feature...&v=KZtdMapbL1s
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Nov 19, 2012, 11:04 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I've not seen the Trex 500 Pro manual, but all their other manuals seem to show headspeed right at the start of the battery.
For example, you would need 4.2v per cell, and 100% of the motor rpm with no reduction for any load to get 3665 with a 12t / 132t setup.
Realistically, even at zero pitch, you will only get about 90% of the theoretical motor rpm, and that will drop under load at high or low collective, or with tail inputs, especially right tail. So I would estimate zero pitch HS ranging from 3150 at the start of the battery to 2900 at the end, if using a flat 100% throttle curve, and loaded headspeed to be about 2800 dropping to 2600.
Maybe I just use crappy battery packs, but my flight data logs seem to show a loaded voltage per cell of about 4v dropping to 3.7v.
2Doggs is offline Find More Posts by 2Doggs
Old Nov 19, 2012, 04:16 PM
Mannyman535 is offline
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
this has probably mentioned before but my tail bobs up and down, i cant seem to find out why
HK GT500 heli (1 min 26 sec)
Mannyman535 is offline Find More Posts by Mannyman535
Old Nov 19, 2012, 04:28 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Sorry for the off topic guys...
Do you still get buddy codes from an item from HK when you use the discounted offer window? ie when you leave the item page open log enough you get the discount window
evltoy is offline Find More Posts by evltoy
Old Nov 19, 2012, 04:36 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
edit// totally read that wrong..... YES you get the code as long as it is a eligible item lol
you dont get a code to share if you use a buddy code to buy the item.
3d astronaut is offline Find More Posts by 3d astronaut
Old Nov 19, 2012, 04:40 PM
Joined Sep 2011
http://youtu.be/9phMZBgWn8s
That ones out of my league but I found some info. Hope it helps!
http://rc.runryder.com/helicopter/t602656p1/
http://rc.runryder.com/helicopter/t571362p1/
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Thank you for clearing that up for me.
Old Nov 19, 2012, 05:13 PM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
assuming you checked the main shaft already, it could be imballanced tail blades/grips, maybe the tail shaft itself is not true. Also check for bad bearings in the tail section, starting at the boom case and working your way back to the tail case and grips.
If its fbl, then lower the elev gyro gain....
Old Nov 19, 2012, 05:23 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Mine did that on my HK and the airwolf. Both turned out to be play in the swash. Could be excessive play in the links as well.
Old Nov 19, 2012, 05:26 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
If its a belt check for missing teeth, belt tension and no kinks
Old Nov 19, 2012, 05:44 PM
edf flyer
Joined Feb 2009
Thanks for the help I will try all of your suggestions
Old Nov 19, 2012, 07:03 PM
Need More PURPLE !!
Joined Aug 2012
Well....I learned today that there is a diff. in 450 motor pinions..Needed 3.5 mm and bought 3mm. That was a waste of 8 bucks. ha...( anybody need 3mm ? )
On the bright side of things I am now doing and holding inverted flights now between 10-15 seconds with a few Pirouettes included on my 500 and 600 helis. Next i just need to bring all my newly learned tricks closer to the ground. ( dirt naps need not apply)
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
