Im in the same boat.
For x-mas i will be getting a new dx8..Only im torn on the model that will come along with it. The KDS 550 or the new Devil 480. : (Devil swings 360mm blades on 6s, That would be awsome ) Would love it even more if align would put out a 480 size. At this time I can only pick one says my wife and x-mas bonus check So I'm leaning KDS 550 at this time. But not by much. ha
It's debatable I guess! I have always seen the 550 as nothing more than a 600 with power before the 12 cells came out and cost is just about the same between the 550 and 600 as well as physical size. At the field if it don't say 600 or 550 on the side no buddy right away can tell the difference. Then you have the 520's, but again other than about $20 in blades the cost of electronic and all are equal.
The 500/425/X4 is a true class of it's own with cheaper electronics. Blades from $20 to $59. Battery packs from $22-$40 because the 500 only needs a 20c rating. I use 25c in the pro and 20c in the 500e and have never puffed a pack. The 500 is big enough for respect, but not to big to take with you. I am getting larger because I have fallen to peer pressure lol! and I like the challenge of building something different. I am keeping both my 500's. |
Latest blog entry: Logo build
Not deriding the 500, I have two of them, one in the Airwolf and the other Scorpion powered and flybarless. Both are excellent and I can't see either being sold any time soon. I also have a 550 and a 600, the 550 FBL from HK and an HK 600GT in an MD500 fuselage. Each serves its own purpose and all great at what they do.
The hardest helicopters on batteries are the 450 and the 6 cell 600. The big selling point of the 500 was you could use two 450 packs and it was much more easier on packs than a 600. Remember the 500 came out when 25c packs were about the highest you could get. I run my 500pro at 3000 hard rpms with the 500mx motor. I use three align 2600 25c packs. Two with over 100 charges each and one smashed
but still going strong. On my regular 500 I have the same two 20c packs that I have been using for years. A turnigy over three years old and a blue lipo over two. People talking about the 500 being hard on packs. Most of these people are just getting into the hobby and have most likely been told by some hobby store trying to sell them a $80 battery. I have puffed my share of packs, but all 450 and 250 so I am not doing anything special.![]() It all comes down to voltage vs amps. If you look the 500 from align comes with a 60amp speedcontrol. The 450 a 35amp, but the 500 used twice the volts. That means basically just going by their numbers the 450 actually pulls 10amps more than the 500. There is more to it than that, but I am just trying to make it simple. http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html This is my first pack and is still going strong with zero puffing. I even killed it once forgetting It was not charged. If you read it even says great for Trex 500 |
Joined Dec 2011
Thanks for that, I know you definitely need to read between the lines with a lot of HK reviews, though you do see the odd sensible person posting, like Beenflying. I'm tending towards the 500 then. Just wish HK would do a belt FBL version, but the only time I do my tail in these days is when I crash, so maybe I could go for the TT one. Any recommendations for cheapish servos and motor? (see, even though she goes for a posh Japanese sewing machine, I still have that ghetto instinct!)
Joined Dec 2011
EDIT: didn't notice these are too big to fit in a 500. Look like a good option for a 550 or 600 though. http://www.hobbyking.com/hobbyking/s...tal_Servo.html These are relabeled Henges, again haven't used but their micro servos are good for their price range so I imagine these are too. http://www.hobbyking.com/hobbyking/s...3kg_0_11s.html These are also decent servos, they are relabeled Towerpros. http://www.hobbyking.com/hobbyking/s...g_0_14sec.html These are what I'm using on my FBL 500, they've worked flawlessly so far. Beenflying has been using these since last year. They have about 0.3mm play in the output shaft but it's not enough to affect flight performance (Emax servos have this even worse and it doesn't affect them either). Some people have fixed this by putting a little glue or sillicone or similar in the recess for the ball bearing but I'd recommend just leaving it as is because it would be very easy to mess it up. They are relabled Blue Arrow servos. The best thing about them is that they don't have pots that can wear out. http://www.hobbyking.com/hobbyking/s...dProduct=14828 I've been using this tail servo (the case has been updated, it looks nicer than the picture) http://www.hobbyking.com/hobbyking/s...dProduct=14831 And this motor. http://www.hobbyking.com/hobbyking/s...dProduct=26502 Has anyone ever tried using red locktite to glue in two headless screws into the motor screw holes and then using nylock nuts to secure it on the motor mount from above? I was thinking it would prevent you from accidentally stripping the holes in your motor. I had this happen earlier for no apparent reason, screw wasn't even crossthredded. Thankfully with the orientation I eventually needed the motor in that hole wasn't needed. |
@Atomic Skull - will the 500 take a standard sized servo for the tail? The 500TT FBL looks to use a 450 Pro type tail servo position rather than a boom mount. Those Mi ones have a great spec, though. I also like the look of the Heli Drive motor, and HK have the sense to stock it in the US warehouse too which helps. |
Joined Dec 2011
HK doesn't sell exact replacement frames for that kit and they don't sell exact replacements for the rotor head and tail parts either. Which is a shame because they're higher quality than the Skya parts that HK sells. GogoRC frame installed. I don't think I like the metal bottom plate as much as the CF one so I'm going to order a second frame set and put that one on the CF bottom plate for my main 500 and use this frame and the metal bottom plate in the FB backup I'm building (it's mostly leftover parts from my main) |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
