Australia
Joined Jun 2010
Regards the Red Brick 80amp, Hobbyking support emailed me a programming sheet if any of you want it for your records-
Link- http://www.hobbyking.com/hobbyking/s...2X53414X49.pdf I think my issue is a throttle range issue, but I have not had a chance to investigate it any further yet. If I cant get to a happy place I guess I'll just source another ESC. Mick ps- Thx to those who responded
Got my new slider from Hobbycool. It was in great shape. I had to replace one screw that was out of round, but all the bearings were good. You do have to take it apart and use a toothpick to apply loctite to all the screws like all new parts. There is also hidden cost. You will have to buy a new pitch fork assembly, but you have to on the align as well. Total cost $33 VS $60 that is the unit and fork for either.
Latest blog entry: Logo build
Yes! I had a 500pro slider that I won on ebay that I took apart and used.
Seattle Area
Joined Aug 2007
Not much happening lately. I did put the Tarot tail assembly on the 6S 450SE with some HK tail blades. It has some power, I'll tell you what. I think it goes about 110-120MPH
I also got a few 1300mah 6S that are about the same shape as a 3S 2200mah. http://www.hobbyking.com/hobbyking/s...dProduct=23919On the HK500GT, I had a tail link ball back out (maybe vibration or poor thread lock) and had a minor crash. I replaced a few parts (main shaft, feathering shaft, blades), but it was obvious the frame was bent at the top so I got a CF main frame. Also installing an HB3650 1600kV motor and sticking with a 12T with TIG blades and white CF tail blades. Also will put black nylon sleeves on the servo and ESC wires OT, I spent like 45 minutes dynamically balancing the tail on the 450 and ended up with an ugly piece of blenderm tape on the blade as usual. Any suggestions for a better looking (invisible) piece of tape? Thanks, Dave |
Joined Dec 2011
Joined Dec 2011
Infinity Hobby has the standard Align 500 Pro bellcrank and pitch slider on sale right now. The bellcrank is only a dollar more than the Tarot version.
http://www.infinity-hobby.com/main/p...oducts_id=7502 http://www.infinity-hobby.com/main/p...oducts_id=7553 |
Joined Dec 2011
Seattle Area
Joined Aug 2007
I'd like to just put a bigger motor on this heli myself sometime, even if it means the flight is 3.5 minutes, instead of 5. I haven't seen any motor only mods, only making a 500 into a 550. I just started thinking about it with the OPs post. I haven't looked into it obviously. I should look into that.
Seattle Area
Joined Aug 2007
Say you have the http://www.hobbyking.com/hobbyking/s...dProduct=11186 is about the right kV, but too large in diameter. Will look around more. I think mhills said something about this some time ago.
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
