Don't forget to pee first lol!
Latest blog entry: Logo build
Just got back from the field... All I can say is wow! The power on that turnigy typhoon 500 is unreal. I am really impressed with this helicopter. Bummed I only brought one pack for it but I can tell this thing is going to be a blast! Thanks for all the help/info/suggestions in this thread.
Latest blog entry: Wltoys V929 Quad Copter (Blade mqx...
Joined Dec 2011
I just installed an Align metal hub tail drive gear (these are for the 500 Pro but work fine with the 500) and one way bearing shaft. Also replaced the tail drive gear and pully as the Tarot one wobbles slightly, the Align one does too but to a lesser extent. Main gear still wobbled a bit so I tried replacing it with one of the Tarot spares I bought. First thing I noticed was that the screws seemed to stop more solidly when they bottomed out when installing it (i.e. harder plastic) in the one way bearing case with the spare than they did with the one that came in the kit. All wobble is now gone. Either Tarot ships cheaper gears with their kits than they sell as spares or they recently improved their maingears.
All up and down play in the maingear is also gone now, I have read that this was also present in the Align gears so it must have been fixed with the new 500 Pro tail gears. Quote:
http://www.hobbyking.com/hobbyking/s...00_Class_.html How does it compare to this motor? http://www.hobbyking.com/hobbyking/s...dProduct=28132 I've found that the 6mm M3 screws HK provides with their 500 size motors are too short to use with the provided washer and spring washer without risk of stripping the threads in the holes (doesn't grab enough threads). I ended up using a 10mm M3 and 1 split washer followed by 2 of the larger washers (spring washer between the washers and the screw head). The screw protrudes out the bottom of the hole by about 1.5mm but doesn't come anywhere near the windings. |
here you go
http://www.xheli.com/exi-500-147.html |
Latest blog entry: NH airshow
A thread with it in there: http://www.rcgroups.com/forums/showthread.php?t=1634193 This new project is growing into a 600 size, with a 3 blade head . I need to get a Gaui mainshaft on board for proper head height...and that requires that 8mm id bearing shaft. I'd like to get a ready-made part like the origional HK500 part is, otherwise it's either drill and hope I can do that straight, or find some 8mm id 10mm od hollow shaft stock and kludge something up
This heli is my new favorite. Just ran another pack through it in the park up the street. I wish I wasnt so sick as I would be out there all day! I need to actually be more cautious. After a minute of flight I hit idle up and rolled it over and brought it about a foot off the ground. While I am glad I am able to do this, my wallet disagrees with this decision
I feel like I am flying helicopters all over again.
Joined Dec 2011
I just received the Pro style bellcrank.
It fits the ESP slider just fine. Also you can tighten the screw without any binding without needed to add an extra washer between the bearings like with the old metal one. The bearings need some green locktite (They are tight fitting enough that they technically don't but I prefer to do this). There was some machining swarf on the metal collar between the two bearings and they shorted me one 3x4.8x0.3 washer (noticed that Tarot does this a lot lately). I had a few extras around so this wasn't a problem, but it was annoying. EDIT: In order to use this with an ESP slider you need to put the plastic collar in upside down (that is with the small end facing up) and then screw the ball link in from below. This is because the Pro slider doesn't have the raised part where the screw hole is for the ball and on an ESP slider it will push the ball down into bottom of the plastic insert and cause binding. I had to ream out the plastic collar slightly on the small end because it would restrict the neck of the ball link and reduced the pitch range slightly in the direction toward the hub. Once I had it working perfectly I glued the collar into the hole to keep it from coming loose. Compared to the standard bellcrank there is now very little slop in the tail. Speaking of those washers, I finally found a higher quality replacement (the Tarot ones often have stamping burrs) http://helidirect.com/sab-washer-a3-...00-p-25711.hdx These are actually better quality than the copper ones Tarot uses (they appear to be stainless steel). It says 5 to a pack but I got 10 in mine. (not sure if this is a mistake or not) It says 3x4x0.5 but they look more like 3x4x0.3 to me (which is the same thickness as the Align ones) I also found these: http://www.infinity-hobby.com/main/p...oducts_id=6714 These are .1 thickness and could be useful for shimming the spaces between bearings to get rid of binding. |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
