Old Oct 14, 2012, 08:55 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Originally Posted by sp00fman View Post
Hold a small soldering iron on the screw for a minute. You might be able to unscrew it then.
+1 on that. HK tend to use some white threadlock that is way too strong, and I've always had to use a soldering iron on bolts such as the flybar seesaw and mixing arm pivots. I've not come across threadlock on feathering spindle bolts, but I've also never seen HK use any grease on the thrust bearings.
Since there aren't any plastic parts around the feathering spindle, you can go to town with the soldering iron without the risk of melting plastic. Make sure you have a couple of close fitting hex keys, since the last thing you need is to strip the bolt heads.
If you can't get it apart, you'll still have to deal with it at a later date - unless you crash the heli and need a new head.....
2Doggs is offline Find More Posts by 2Doggs
Old Oct 14, 2012, 02:53 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Ok thanks guys. I will give the soldering iron tip a go.
**update** I just got it separated with the soldering iron. The screws had a generous helping of "white" thread lock. Thanks again for your help
Bravo47 is offline Find More Posts by Bravo47
Old Oct 14, 2012, 04:24 PM
biker dude is offline
Find More Posts by biker dude
Flying high
biker dude's Avatar
Tampa Florida
Joined Nov 2007
I have actually had to hold the soldering iron to the screw while trying to unscrew the tail rotor grips. It seemed like every time I took the soldering iron off it cooled down too much. I finally got it though. It's amazing how they will over do it on some screw points and not even bother on others. SHEESH!
biker dude is offline Find More Posts by biker dude
Old Oct 14, 2012, 08:26 PM
Bravo47 is offline
Australia
Joined Jun 2010
eg: the swash plate ball links :|
On one 500 I built the anti-rotation ball link released during its maiden test hover resulting in an expensive roll over and a big anti-climax.
Old Oct 14, 2012, 10:21 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Yes, it's also easy to strip the threads on the anti-rotation link, so best to use moderate torque and decent threadlock when securing it.
Old Oct 14, 2012, 10:29 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Hey guys had a lot of fun at the scale fun fly. Here are some pics of the 500e airwolf. My wife took the pics. Did I say my wife took the pics lol!
mhills51 is offline Find More Posts by mhills51
Old Oct 15, 2012, 02:33 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Don't use hex keys, they always round off after a few screws. The Dynamite RC hex driver set (the red aluminum handled ones with replaceable bits not the cheap ones with the plastic handles) is inexpensive and actually holds up better than the Align set.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Oct 15, 2012, 05:34 AM
Bravo47 is offline
Australia
Joined Jun 2010
I'm just about due for a new Hex Driver set. Is this the one you are talking about linked below.
Link- http://www.ebay.com/itm/NEW-Dynamite...item460467c5bb
Old Oct 15, 2012, 07:31 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Just get a quality hex set. The ones that come with any kit are throwaways. One of the best 1.5 I have was $1.99 at deal extreme. The ones you are showing are sold at our lhs and don't lock into the handle.
Old Oct 15, 2012, 11:32 AM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
+1, I was just being sloppy referring to hex drivers as hex keys.....
Old Oct 15, 2012, 01:10 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
mhills51....glad you got your wife marginally involved in the hobby...My wife thinks I might be a terrorist with all my random packages from HK...lol
ridge_racer is offline Find More Posts by ridge_racer
Old Oct 15, 2012, 02:59 PM
Bravo47 is offline
Australia
Joined Jun 2010
Sometimes I wonder how a new heli kit can come with bent shafts. This current HK500GT kit I'm building was supplied with a bent shaft on the "tail drive gear set". I was just checking the rotation before fitting the belt when I noticed the gear was moving up and down through the rotation. Luckily I still had the broken CX500 lying about for spares or would have been a frustrating delay in the build.
Mick
Old Oct 15, 2012, 06:15 PM
Joined Dec 2011
No. If those are like the plastic handled ones with the black tips then they will round out fast (the tips look identical) The plastic handled nut drivers I got from them were cheap and seem to hold up reasonable well though.
I mean these ones.
http://www.amainhobbies.com/product_...Metric-Set-Red
These have lasted for months now without loosing their corners. I originally bought a single 1.5 as the second for removing the feathering shaft from my 450 and it held up better than the Align set I had bought. So I went and bought the whole set. I'm pretty sure than the black aluminum handled ones with the colored plastic end caps that Dynamite sells also use the same bits. Those cost $34 instead of $19 but also come with a 3mm driver.
Just to reiterate, avoid the ones with tips like these:
http://www.amainhobbies.com/product_...Hex-Driver-Set
They will round out fast. It's not worth saving $7 over the good set.
Old Oct 15, 2012, 10:39 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I think the align pro slider will work with the plastic tail. Anyone else know?
Old Oct 15, 2012, 10:50 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
I am officially 90% ready to go. The radio is set, the manual servo adjustments are set, gyro gain is set, pitch is set, just need a break in the weather! Rain+wind the last week and a half literally almost every single day. Also waiting on my new canopy but the stock one is fine for the maiden.
3d astronaut is offline Find More Posts by 3d astronaut
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
