Old Oct 08, 2012, 05:54 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
After struggling to get the bearings off my 500 bevel gear, a while ago, I decided to get one of these:
http://www.rc711.com/shop/500-drive-...er-p-1134.html
It's a must have for the tool kit, if you have a TT tail, and it's only $7.90.
beenflying is offline Find More Posts by beenflying
Old Oct 08, 2012, 09:33 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
A few buddy codes:
YEP 80A ESC
http://www.hobbyking.com/buddy.asp?c...5-71DA88A5AF44
Turnigy HQ 500 Pro canopy
http://www.hobbyking.com/buddy.asp?c...0-A3182CE2A918
Atomic Skull is offline Find More Posts by Atomic Skull
Old Oct 08, 2012, 10:37 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
You didn't order that canopy did you?
mhills51 is offline Find More Posts by mhills51
Old Oct 08, 2012, 11:34 PM
Joined Dec 2011
Yes I did why?
Old Oct 09, 2012, 12:35 AM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
hehehe.. your in trouble now Atomic.... hehehe
evltoy is offline Find More Posts by evltoy
Old Oct 09, 2012, 01:15 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Thanks Mhills and Biker Dude for the tail answers. My CopterX500 hit the dirt a few months ago after a tail rotor grip screw broke, so i guess CopterX suffer the same flaw as the HK500.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Oct 09, 2012, 01:17 AM
Joined Dec 2011
I'm not sure I understand.
Old Oct 09, 2012, 01:24 AM
kdean is offline
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
I think the problem with that canopy is that its for the 'pro' frame, which from my understanding is not as wide as the older 'e' and 'esp' frames.
kdean is offline Find More Posts by kdean
Old Oct 09, 2012, 07:12 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
It also will not hold down. Instead of using a front lip it uses two more body mounts in the front. You can see them from the picture. Just like the 600 or 700pro.
Old Oct 09, 2012, 07:31 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Looks like tarot is at it again. This is a copy of the pro tt tail for $19 not bad for the price and a new set of bearings. They also got a DFC head block, so they are coming out with their own.
http://www.oomodel.com/tarot-500-par...x-p-64057.html
Old Oct 09, 2012, 09:53 AM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
500 pro canopy: According to the comments left by a purchaser it can be used on the hk500e, only the bottom gromets won't be used. Atomic if this is not the canopy you had in mind. ther is a good chance it has not been shipped yet. Change your order.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Last edited by Dejavu*Xion; Oct 09, 2012 at 02:32 PM. Reason: spelling....good not goof.
Old Oct 09, 2012, 11:51 AM
Joined Dec 2011
Someone in the discussion thread said it would fit on an HK500 without modifications. If that won't work then I'll just add the two extra canopy mounts to the frame. The 500 pro frame is only a few mm narrower than the ESP frame but if it's a problem then a heat gun will fix that (same method you use to fix a lopsided canopy)
Originally Posted by Dejavu*Xion View Post
Atomic if this is not the canopy you had in mind. ther is a goof chance it has not been shipped yet. Change your order.
I ordered it deliberately because I like the longer canopy. I think that the stock canopy makes the 500 look squat and would like something more like a 450 Sport canopy. I hate the 450 Pro canopy for the same reason. Whoever designed the 450 Pro and the 500 must have liked the look but to me it looks ugly.
Functionally what is the difference between that and the ESP tail? the differences only look cosmetic to me.
Old Oct 09, 2012, 05:48 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Stiffer more squared end for the TT gears. I think it's lighter as well. All the align model tails are going to this design. As well as ALZRC and now Tarot.
Old Oct 09, 2012, 07:18 PM
biker dude is offline
Find More Posts by biker dude
Flying high
biker dude's Avatar
Tampa Florida
Joined Nov 2007
So I'd flown the 500 and started flying the 450. Then I decided to try to go inverted.
With the 450. And I did.
Does it count if you have to rebuild afterwards?
biker dude is offline Find More Posts by biker dude
Old Oct 09, 2012, 07:25 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Had the same thing last night with the mcpX. Was hovering inverted... lipo started to go low and had no balls to lift out. Blades ended up slowing down and had no option but to land inverted.
Pick it up, chagne lipo and all was good
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
