Old Oct 21, 2009, 11:36 AM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Autozone happened to carry the CRC Di-Electric silicone-based grease for about $9 per 3.3 oz. bottle, enough to lube thousands of thrust bearings, no other well-known stores had silicone-based grease, was glad that Autozone had this stuff so I bought a can of it. It has its own applicator (not needle-precise, but precise enough for thrust bearings), and is 100% petroleum-free. It's approved for use on o-rings, rubber parts, flashlights, batteries, motors, electrical contacts, etc.
Do you heli fanatics use grease on other areas of your heli other than the thrust bearings? For example, main rotor bearings, tail bushings, swash, etc...
ChrisWNY is offline Find More Posts by ChrisWNY
Old Oct 21, 2009, 11:47 AM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
My heli has shipped, now i just have to wait for the motor, and servos to come in stock.
Twister773 is offline Find More Posts by Twister773
Old Oct 21, 2009, 08:25 PM
Private Pilot
Twister773's Avatar
Joined Jul 2009
Think these would work good or no
http://www.hobbypartz.com/4ptopromgmeg.html
Old Oct 21, 2009, 08:49 PM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
If the torque rating is accurate, that is 84 lbs./inch of torque at 6V, which is definitely high torque for a servo. The price is great on them. The only drawback is that they are a little slow, 0.13 sec/60 at 6V, and 0.17 sec/60 at 4.8V, though that should be sufficient for sport flying. I would consider a faster servo for the tail, otherwise, they should do the job.
Old Oct 22, 2009, 09:19 AM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
Those servos are a little too long...I tried to install hitech HS225bb servos and the servos were too long and the backs of the servos were touching and even with spacers they were too long....http://www.bphobbies.com/view.asp?id...83&pid=S505368
skizziks is offline Find More Posts by skizziks
Old Oct 22, 2009, 09:36 AM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
skizziks -
Good catch on that one, I overlooked the dimensions of the servo. The TowerPro MG930 Digitals work well in a 500 frame, they fit into the frame without the need for spacers. They don't have quite as much torque as some of the more expensive brands, but they are fast and strong enough for both tail and cyclic control for basic 3D and sport flying.
To get an idea of dimensions for servos that will fit comfortably without modification within the HK-500GT frame, here are the measurements on the TowerPro MG930 digital servo, use this as a baseline then try to visualize the size difference when using a larger servo. The MG930's fit into the 500GT frame with about 1mm to spare around the entire outer perimeter of the servo, and there is a ~4mm gap between the 2 front cyclic servos without the use of spacers...
36.2mm x 15.2mm x 28.7mm
Old Oct 22, 2009, 10:45 AM
Private Pilot
Twister773's Avatar
Joined Jul 2009
Thanks for the info guys. I think ill get the 930s when hc has them again
Old Oct 22, 2009, 11:24 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Originally Posted by rcnewb
st200 -
I noticed the same thing with my HK-500GT. Had a test flight today, the tail is virtually unmovable when the head speed comes up to where it should. .
All helis do that to some extent unless you put the Chinese weight mod on the tail blades.
That's why tail servos that perform well not only need to be fast but also stronger than people realize.
I did the chinese weight mod on my EXI 500 CF version so my Futaba 9257 can perform better. Although the HK500 is more like the EXI 500 plastic version, They share pretty much the same charactoristics in the tail.
I've got Chinese weight mods in my 450's my 500 and my TT e550. They so make s difference in the force of the tail and thus helps to speed the servos up quite a bit.
Melnic is offline Find More Posts by Melnic
Old Oct 23, 2009, 01:18 AM
wrugen is offline
Find More Posts by wrugen
Joined Feb 2006
So.I'm a new guy.
What is this mod?
wrugen is offline Find More Posts by wrugen
Old Oct 23, 2009, 02:52 AM
Old coot is offline
Find More Posts by Old coot
Old coot's Avatar
Joined Mar 2009
Originally Posted by wrugen
So.I'm a new guy.
What is this mod?
http://www.mycoolheli.com/chineseweightmod.html
Here` a link to one way of doing it. Do a search for chinese weight mod an you`ll find more.
Old coot is offline Find More Posts by Old coot
Old Oct 23, 2009, 03:15 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Mel,
if it is like the tail on my (non-thrust washered tail clone) then the is different - this was the tail binding because the centrifugal/centripedal force is over-powering the bearings at high speeds, not due to tennis-racket affect.
Mike.
MikeHRC is online now Find More Posts by MikeHRC
Old Oct 23, 2009, 07:03 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I started my build last night and everything is going well. I was surprised to find that there wasn't one piece of paper or parts labeled. No bid deal really, I just downloaded the TRex manual and it is close enough. I was a bit disappointed that there were no washers provided for places that obviously needed them, like the landing gear brackets. I also found a couple missing screws, like one of the set screws for the flybar paddles etc. The tail seems ok but I won't know until I spin it up. Where are you guys mounting your electrics? For now I am putting the esc on one side, the RX on the other and the gyro on top behind the main shaft. Once I get it dialed in and working my plan is to install my KDS Flymentor. Fortunately there seems to be plenty of room for it.
I ended up using these servos for the cyclic,
http://www.rcdude.com/servlet/the-11...l-Servo/Detail
They fit but just barely, The 2 side servos actually touch in the middle but still mount securely. I went with the actual Align tail servo as I couldn't find anything close to the size in Hyperion. After seeing how it mounts, I now realize I could have gone with a larger one with no problem.
techspy is offline Find More Posts by techspy
Old Oct 23, 2009, 07:04 AM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Melnic - I'm aware of the Chinese weight mod and definitely considered it as a secondary fix for my 500GT if the Align part doesn't completely resolve the issue. I am in agreement with MikeHRC on the bearings causing the binding at a certain threshold of centrifugal/centripetal force, even the strongest of servos would have a major issue moving the tail rotor at high RPMs, or it would draw so many amps that my 7-Amp BEC might fry as a result. I do like the Chinese weight mod, it makes sense, and I may use it on this heli depending on the servo amp draw characteristics in flight.
Old Oct 23, 2009, 07:13 AM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Techspy -
Yes, if you're looking at the T-Rex 500 manual, they do recommend washers on the stabilizer and tail fin, etc., but a little CA will do the job also. I nabbed some washers from a salvaged HK-450 that I demolished last year and used them where needed.
As for mounting the electronics, check the T-Rex 500 manual and some of my photos. I mounted the ESC and BEC on the left side of the heli, and the Rx on the rear, which was one of the recommended mountings within the T-Rex manual. My Gyro is mounted on the top of the boom housing, many others will recommend against this but I'm not too concerned about a $20 Gyro getting shredded in a crash. Most of my wires are routed through the inside the frame to the back where the Rx is located. Number of servo extensions used: 0.
Old Oct 23, 2009, 09:22 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
OK, now I gotcha. If the bearings are the cause then I can see how it can affect it. Maybe lighter tail blades will help? Seems the chinese weight mod will help some but the tennis raquet affect is LESS around center and more as you push out. You might want to try the mod to see how much it helps. I did mine up w/ washers on the 500. I'll try to post what I used.
There is that Hiem Joint (spelling) guy who sells something better but it's like $20.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
