Old Aug 07, 2012, 04:32 PM
91awdTalon is offline
Find More Posts by 91awdTalon
Wisconsin
Joined Aug 2005
Well I got ancy (sp?) and took it back outside, I just stood in the shade this time. Adjusted a link one turn and boooom! This baby is purrring. LOL one of my neighbors did an awesome double take at this thing. The wind was blowing stiff, down the street and was making some good noise across the blades.
Thanks again for the help/info in this thread. I'm usually pretty good about getting videos, so stay tuned, I'll have one on here in the next few days.
91awdTalon is offline Find More Posts by 91awdTalon
Old Aug 07, 2012, 06:20 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Boy you guys were right about helifreak. I have been posting over there to kinda stay on topic and went to help a guy in the 450pro thread about his tail gears. He was all talking about gluing the bearings on the gears to keep the spacing right. In my experiance if you use all align the spacing should be just right, but if not I gave him a link to the shims the clones came out with because they know theirs is not all the same. I told him the align fit so tight they should stay were they are and don't need any glue. He said Align told him (who from align would talk to this guy?) that he needed t48 glue for the bearings and I thought for a moment and realized they were talking about gluing the bearings in the bearing holders not on the nylon gears. Anyway he PM's edit your post immediately If I wanted a just build it and fly it answer I wouldn't of posted. I went back to the post and he wrote again about align told him this and that in a email. I am thinking what sales staff is giving this punk the time of day?
Sorry I just had to vent.
mhills51 is offline Find More Posts by mhills51
Old Aug 07, 2012, 06:57 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
There is a lot of BS on the internet and its people like that that start it. You have gone out of your way to help and he burns you. Now dont give him the time of day.
The funny thing is the info get got from the "email" is in the manual. Tells you how much brains he has.
evltoy is offline Find More Posts by evltoy
Old Aug 07, 2012, 08:31 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Hey did you get your charger fixed?
Old Aug 07, 2012, 09:04 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Chargers are ok. It was my power supply that I killed. Thanks to wlee1017 & baddb1 we have so far found one dead component that I need to track & replace down.
I have created a blog if anyone’s interested in following.
http://www.rcgroups.com/forums/showthread.php?t=1706324
Old Aug 07, 2012, 09:27 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Originally Posted by LiQuid*Xion View Post
+ 1 on this...I just had to take apart my whole tail on the 500e to rid those plastic parts.. To much movement and was creating Tail havoc in flight..those cheap plastic tail rudder control rod holders needed to be switched out as well.
OK you guys, point taken...The servo mount is probably the worst ever after looking at it flex on the ground. I'm going to fly it around though.
I'm placing my smallest HK order ever
http://www.hobbyking.com/hobbyking/s...t_H50038_.html
http://www.hobbyking.com/hobbyking/s...t_H50109_.html
Finally in stock!
http://www.hobbyking.com/hobbyking/s..._Receiver.html
I'll use an OrangeRX with a satellite with this heli.
eagle777 is offline Find More Posts by eagle777
Old Aug 07, 2012, 09:55 PM
Wisconsin
Joined Aug 2005
Got a few more hovers/slow ff in today. This thing is a beast! I'm pretty impressed with that cx-1x1000 gyro, holds just as good if not probably better then my 2100t.
Old Aug 07, 2012, 10:01 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Why is it so hard for the clone companies to make decent bevel gears that mesh correctly on the tail shaft of TT 450 Pros.. Grade A Tarot, ALZRC, and some VWINRC spares seem mostly correct. Alot of ebay vendors sell some that don't fit the bearings and don't mesh correctly.
ridge_racer is offline Find More Posts by ridge_racer
Old Aug 07, 2012, 10:21 PM
LiQuid*Xion is offline
Find More Posts by LiQuid*Xion
KoOl BrEeZe
Joined Feb 2012
Finally in stock!
exact same parts i used dave. Mucho better !! So far the only flaw i have found on this 500e.
LiQuid*Xion is offline Find More Posts by LiQuid*Xion
Old Aug 07, 2012, 10:22 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Please correct me if I'm wrong... 1 reason why clones are cheap is that they use the some mould over and over again until it’s totally screwed. Instead of replacing a mould every 100 batch’s they replace every 500 making the last 300 batch's bad. If you get one of the early batch’s you will find that they are ok..
To replace a mould cost money so the less they replace a mould and the more they push out the cheaper the part, but the quality could go either way.
Old Aug 07, 2012, 10:40 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I had heard that also and it makes sense. I haven't had too many problems with the main and auto gears, but never used the smaller high performance bevel tail gears.
Old Aug 07, 2012, 10:50 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
You got me looking at mine and it's as solid as a rock. The only thing that gives is the rubber grommets in the servo. At least the align uses the CF with plastic around the boom instead of the HK GT all plastic. Personally I think the plastic grabs the aluminum boom better.
Old Aug 08, 2012, 07:31 PM
KoOl BrEeZe
Joined Feb 2012
Did you use some plastic shims for your tail servo Boom rod grips ? I did,, And still had a lil play. Just did not want to chance it. Last thing i need is another 500 dirt nap. Think I have had my share in past few months. lol..Anyways the metal ones are rock solid.
Old Aug 08, 2012, 08:55 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Yes I did and they are solid as well. You do need to CA them after you make your adjustments.
Of course it's the little things that make people tend to forget and then blame the product instead of themselves. Like my tarot gyro. It could be something else that made my 450 die that is why I posted that I am just finished using questionable parts. This way I know it was something that shouldn't of happened instead of wondering? was it the $55 gyro? If I use quality things then most likely its something I screwed up lol!
See I probably wouldn't use the metal ones without some kind of Teflon or plastic bushing inside it. I wouldn't want to take the chance of the metal cutting into the metal rod. See were all dammed if we do or dammed if we don't aren't we
Old Aug 08, 2012, 08:58 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Oh by the way my little rant with the guy at HF someone from Japan posted +1 to my post lol!
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
