Old Jul 26, 2012, 01:23 AM
kdean is offline
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
I just got an Ice75 for my 500, and a Ice100 for my 600. Both now have the cc bec pro installed, and now i need to upgrade the servos and motor. The 500 will soon have a micro beast fbl unit, and the 600 has a spartan quark installed. I dont mean to brag, but this expensive stuff better make my helis more reliable....
kdean is offline Find More Posts by kdean
Old Jul 26, 2012, 07:40 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
low end of the high end or best bang for the buck is still the align 510, 610 on ebay for all three at once or grandrc also parts out kits and sells them in a open 3 pack for less.
mhills51 is offline Find More Posts by mhills51
Old Jul 26, 2012, 09:27 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by mhills51 View Post
It does have what is called startup power on the programmer that I have not played with yet. I have it set to auto 1-32%. I have CC on my 450's and I got a used one that had not been updated for a while. I tried running it in soft start and it gave me the same kind of blip in power on the new 450mx motor before updating it. So perhaps this startup power takes care of that.
Which governor are you using ? Gov Store or normal? With Normal governor you will get a "kick" each time you power up - when the motor has reached max revs, it is the ESC confirming this, in normal gov the ESC measures the power of the batteries (and hence sets max HS) each power up. So you will always get (for example depending on Throttle curves) 80% of possible HS for that battery.
With Gov Store, you set it to measure max HS with one of your weak batteries, the ESC then remembers this and then you would get 80% of that figure irrelevant of which battery is used - and it is VERY consistent
MikeHRC is offline Find More Posts by MikeHRC
Old Jul 26, 2012, 10:00 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I'm not using a gov. Just reg curves.
Old Jul 26, 2012, 10:41 AM
91awdTalon is offline
Find More Posts by 91awdTalon
Wisconsin
Joined Aug 2005
Got the new servo on the tail. Spool up, no more bad wag, then the tt tail drive gears decided to get mangled somehow. Unreal... I feel like I should have just gotten the belt drive model. I'm not touching this thing until monday after I get back from a canoe trip, maybe I'll have a little more patience.
91awdTalon is offline Find More Posts by 91awdTalon
Old Jul 26, 2012, 01:47 PM
darkseacret is offline
Find More Posts by darkseacret
Wilmington, N.C.
Have fun on your canoe trip listen carefully for banjos .
darkseacret is offline Find More Posts by darkseacret
Old Jul 26, 2012, 01:52 PM
LiQuid*Xion is offline
Find More Posts by LiQuid*Xion
KoOl BrEeZe
Joined Feb 2012
Are you useing align t.t gears ? Hope so. Any clone t.t gears are very soft and strip easy. Ease into idle up 1 and 2..A sudden Burst From low rpm's will even strip align gears.
LiQuid*Xion is offline Find More Posts by LiQuid*Xion
Old Jul 26, 2012, 01:53 PM
KoOl BrEeZe
Joined Feb 2012
lol...deleverance..All time great movie . Now " squeal Like a pig" ha
Old Jul 27, 2012, 12:27 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I just got a YEP 100 for my second 500 and another 45A for my FB 450, so all helis will have governors I can also use the 100A ESC for a pylon racer next year if god forbid that something happens to my sweet HK500GT.
I shouldn't have sold my Typhoon 500, and will use the ExceedRC motor <shrug>. And a few canopies each for 450 and 500. I had all the stuff for a 6S 450 power system in my cart, but will hold off for a while since I bought like $150 of 40C 3S 2200s, well just last week, heh.
I think the hesitation during spool up in the YEP is intrinsic, and is no problem for me. I take off at around 1500 RPM, and it hasn't caused a problem.
I'd like to be RCG plus something. What is RCG plus?
eagle777 is offline Find More Posts by eagle777
Old Jul 27, 2012, 04:34 PM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Tail vibes cont...
So, after trying different things with the tt, even adding a third tt bearing, i still got the vibes. Then i put on some old align cf tail blades (white w/black strip) even though one is a bit soft around the center due to crash damage, and no more bad vibe. There is still some vibe while the heli is on the ground, but once i picked it up, it smoothed out. Maybe its the weight of the plastic blades causing extra strain on the grips or something, but all i know is that i'm not using plastic tail blades on the 500 anymore.
Time to load up a hk cart, and wait a while for processing/shipping...
Old Jul 27, 2012, 05:03 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Its not the tail Blade that is the problem... remember you crashed them . Nothing wrong with plastic blade grips either, just sometimes they just need to be balanced just light any other tail blade you get in CF or glass.
evltoy is offline Find More Posts by evltoy
Old Jul 27, 2012, 06:26 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
The yep will not work at 2% and I didn't take my programming board with me to the field Got back home and the only thing I had to change was from 2% back to auto startup power.
In 2% it would just start to turn and then complete stop with the controller beeping.
Old Jul 27, 2012, 06:38 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
wooohooo! I just won 3x DS510's for $86
Looks like my HK500 project is now complete
Old Jul 27, 2012, 06:46 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I was bidding against you lol! I stopped at about $62.79
Old Jul 27, 2012, 06:53 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Sorry about that, mhills51. My YEP is definitely using 2% and I know a lot of people on HeliFreak are using 2%, also. What motor are you using?
beenflying is offline Find More Posts by beenflying
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
