I am using spring metalgear coreless servos on my pro. I tested one of the cyclic servos and it tested out at 0.11 speed. They are $25 at RC711 and I am trying their .06 on the tail for $26
Latest blog entry: Logo build
Joined Jan 2011
I doubt they will update the 600gt. Think its still based on the one before the esp came out. Now if they came out with a pro clone at the same 150 price tag,that would be a deal. The ehirobo one is just too much at 300 even going with the cheapest possible electrics
Joined Jan 2011
Anyone have an answer to this for me? Wanna try and get this motor ordered soon as i can since it will be coming from across the pond. o they have 600 size servos mhills? If so might try them if the solar servos crap out. Got a question for anyone using a governor mode with the castle ice ESC's. Lets say I'm running the 1800kv motor on 13t pinion on 6s with the hk500. As people would know the throttle curves have to be lowered a lot to not overspeed the head. That's easy. There in lies my question. If running the castle esc, could you set the governor to the desired HS, and keep 100% throttle curves? If so, would there be a difference between doing it that way, and doing it by lowering throttle curves. The whole reason for my question is I'm trying to save 30 bucks. Can get a turnigy 600 1000kv for 36. I'd need like a 10t pinion on 8s to keep the HS reasonable. I can't find a 10t 0.8mod pinion though. So if I go with that one, i'll either have to lower my throttle curve to keep it under control, OR use the castle governor. I know the best choice would be to obviously choose a better motor, but under the circumstances, which of those 2 would be the best option. Turnigy does make an 880kv for which I can use like a 12 or 13t pinion which is easily found, but that motor is 60.
Hey under governor will the helicopter not speed all the way up without the blades on? I have mine set for 85, but when I start it up it acts just like I have throttle curves set. Mine radio under normal is 0, 85, 85, 85, 85 and the CC is set for low gov.
Also I am not to sure about the spring servos. One under start up just went full negative just like a bad 930. At least the one that did it I never liked from the git go. You couldn't move it easily with your hands. Felt like it was binding or something from day one unlike the other two. |
Joined Jan 2011
Hmmm, no idea to either of your questions. I've never used a governor before so it's gonna be a new experience for me. I don't think it should matter if the blades are on or not. Is there not a place to set a specific HS? When I was looking at the stuff for the ice 100 you put in like a specific number and your gearing ratio
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
