Old Mar 19, 2012, 03:31 PM
stingeragents is online now
Find More Posts by stingeragents
Joined Jan 2011
gyro was attempted to be delivered today but missed it. Gotta go pick it up in the morning. if I don't have any setup issues should be able to get in the first flight fbl tomorrow
stingeragents is online now Find More Posts by stingeragents
Old Mar 19, 2012, 05:01 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Good luck mate, it seems like you've been waiting forever. Seems like it's about time something went your way with this heli.
Paul 1968 is offline Find More Posts by Paul 1968
Old Mar 19, 2012, 05:37 PM
Joined Jan 2011
Haha. Yea no good luck so far. Ordered the gyro on 5th
Old Mar 19, 2012, 06:20 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I have a 500GT I'd like to get more cycle response in pitch and roll.
So far, I've put the Align CF paddles on, and have 15mm arms on cyclic for 8 or 9 deg of pitch/roll.
Has anyone used a longer flybar or better paddles than the Align carbon fiber ones? I would like to keep my cheap main blades if that makes a difference.
Any other suggestions also. I am hoping a FBL head will make it more responsive, but won't install that on this heli for a couple months.
eagle777 is offline Find More Posts by eagle777
Old Mar 19, 2012, 06:28 PM
broderp is offline
Find More Posts by broderp
Joined Jan 2012
Originally Posted by evltoy View Post
If you heli is 90%+ Align.... Wouldnt you have been better off just buying an Align form day one?
My logic may be off, but say he bought an Align to begin with, he would have probably had the same accidents that caused the parts to be replaced. So why output $400+ for the Align then, have to put $200 in parts into it. Thats $600.
Start out with $250, and then put the $200 into it, only $450.
Thats like $150 saved for spares or parts...but thats just me.
broderp is offline Find More Posts by broderp
Old Mar 19, 2012, 06:36 PM
broderp is offline
Joined Jan 2012
Quck LIPO question:
I just got my Lipo from HobbyPartz.... fast shipping across the USA!
So what do I do with this thing? Charge it first? Discharge then charge it? Cycle it on my charger 3-5 times??? Use it as is until it needs a charge? It's my only battery at the moment. I need to get matching connector for my ESC before i can plug it it.
Also got my new DETRUM GY48V Gyro. Its not like the one on my heli, Its black, not red and it appears the Delay adjustment has been removed. The label is still there, but the opening is sealed. Is this Old or new stock or is mine just defective?
Old Mar 19, 2012, 06:41 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Originally Posted by broderp View Post
Quck LIPO question:
I asked about the GY48V at xheli some months ago, and the red aluminum case is not made any more. I think I got one of the last ones when my next order had a black plastic case.
I don't know why the delay adjustment has a label on it. Maybe you could open it up and see if the adjustment potentiometer is in there. Just poke a hole in the label if so.
Or just poke a hole in the label and look inside.
Old Mar 19, 2012, 07:03 PM
naryan is offline
Find More Posts by naryan
Rotor Addict
naryan's Avatar
United States, VA, Leesburg
Joined Dec 2008
Quck LIPO question:
The general rule of lipo's is to do easy discharges for the first 5-10 cycles and don't go below 50% capacity. Try to avoid ever going below 80% capacity or 3.7v per cell. After flying charge it back to a "storage" charge (~3.86v per cell) and leave it there until you need to charge it again. Charge it as close to when you are going to fly as possible. Avoid leaving it charged or discharged whenever you can. Slowly increase you flight times until your recharge is 2400mah max (80%).
naryan is offline Find More Posts by naryan
Old Mar 19, 2012, 07:17 PM
Joined Jan 2011
Eagle. A longer fly bar will make the heli less responsive. Just increase ail and elev in ur swash mix. My heli is now fully back together minus the rx and fbl system
Old Mar 19, 2012, 07:42 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Decided to invest in another 2 MG930s. One will replace the dodgy elevator servo and the other will be a spare.
I'll give it 3 strikes then they are all out.
Also bought the 1600Kv motor to replace the killer 1800kv motor.
evltoy is offline Find More Posts by evltoy
Old Mar 19, 2012, 07:45 PM
wattflyer is offline
Find More Posts by wattflyer
Vero Beach, Florida
Joined Oct 2008
http://www.rcinthebox.com/tarot-500-...-_p148244.html
Just received the above Tarot 500 Mixing Arm and noted right away how much longer the ball link screw is than the GT 500, the mixing arm also is metal, nice.
While waiting for the above mixing arm order to arrive, I did a little shade tree mechanics to the existing plastic GT arm. I ground down lightly the screw (the head) from the landing gear so its head would fit inside the ball joint. Thus I was able to use the full mixing arm width of the hole to obtain a more solid ball link with the longer bolt. While the landing gear bolt might be of weaker metal, at least it won't pull out of the mixing arm, all's well thru seven flights.
I tighten three nuts on the end of the bolt, then used my vice grips to hold on to the nuts while turning the bolt head against my ginder wheel, once around and the head fits inside the ball link, make sure it spins inside the ball link, the bolt will go the width of the mixing arm, don;t lock it down, let it spin, but no free play, use CA. Cheers!
wattflyer is offline Find More Posts by wattflyer
Old Mar 19, 2012, 08:00 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I ordered these for mine after I already wasted $15 on just upper cheaper arms. They are very nice. I only put the bottoms on. Just couldn't see taking the whole thing apart just for the fancy look... Ok you know I will!
http://www.rcinthebox.com/tarot-500-...-_p148234.html
mhills51 is offline Find More Posts by mhills51
Old Mar 19, 2012, 08:46 PM
broderp is offline
Joined Jan 2012
So I have the newer version. I'll have to see about taking it apart. Maybe the new versions dont have delay adjustment or its done automatically?
Real stupid question, do the wires go facing in or facing out when mounting on the heli?
Old Mar 19, 2012, 08:50 PM
broderp is offline
Joined Jan 2012
Understood, thanks. I suppose the next question is ; Does it come charged full, and should i charge it or just use it as is, so long i d0nt go below 80%?
I finally opened up my charger, and am reading the manual, lol. More $%#@ to learn..... (I bought a THUNDER Dual Power AC680 charger.)
Old Mar 19, 2012, 09:32 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Do you know what your 80% usage voltage and mAh out is?
You may want to do more reseach into this.... vist the charger - lipo section for more info.
No company will send a lipo at full charge.. this is where a lipo can do most damage. All companies usually and should be sending lipos at storage voltage... 3.85v per cell.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
