Old Apr 27, 2010, 07:17 AM
befetti is offline
Find More Posts by befetti
Joined Jun 2009
Remarkable
False Economy:
Reading this thread from start to finish and my own experience, has provided some insight on some of the cheaper clones. The initial purchase of the various parts, testing, experimentation, assembly, disassembly, and then ordering of some TRex parts to get one of the clones into a similar shape as an original TRex helicopter, has made me realise that buying cheap clones may be a false economy.
Thanks to everyone for this insight.
befetti is offline Find More Posts by befetti
Last edited by befetti; May 05, 2012 at 12:43 AM. Reason: A private message received; "Please review your post".
Old Apr 27, 2010, 07:45 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
First off you should always disassemble any helicopter and reassemble to check for proper loctite. This is also when you can check for any ?? parts that may come up. Second the trex comes in parts in the first place and must be put together from the ground up. Third even the mighty trex has had problems. I had my trex swash come apart in flight
mhills51 is offline Find More Posts by mhills51
Old Apr 27, 2010, 09:44 AM
markos51 is offline
Find More Posts by markos51
Joined Jan 2010
Thanks for your help.
I will reverse gyro channel in dx6i.
About mg930 it is not a tail servo so with spartan 760 gyro when it is under presure (Throtle punch or turn with full speed ) can not lock.
Do not forget that it is acheap servo .
Before i had ds520 and there was agreat difference.
For blade 400 do you know if i can set eflrg110hl gyro in ds mode with stock blade 400 servo or with mks ds470 ?
Thanks again
Originally Posted by SlopeKing View Post
Set servo reverse for that channel.
Also, MG930 is fine for tail if: Gyro in DS mode, with long (10-15mm) servo horn and the throws right down.
markos51 is offline Find More Posts by markos51
Old Apr 27, 2010, 11:23 AM
Jon h2 is offline
Find More Posts by Jon h2
United States, MI, Royal Oak
Joined Dec 2003
Originally Posted by befetti View Post
Everyone!
By the time that you have read this thread, then done testing, experimentation, and assembly and disassembly, you could have bought 3 TRex Helicopters. Unless you are unemployed, these clones are a waste of time which equals your money! Furthermore, have any of your children lost an eye yet due to bits flying off these helis???
[or am I the only one to have done Economics 101?]
"Astounded"
First post to come and bash? troll anyone?
Actually, I have spent less than half what I would have on a T-Rex 500.
I love this helicopter. It flies every bit as well as an Align. There are a few small problems, but nothing too difficult.
Jon h2 is offline Find More Posts by Jon h2
Old Apr 27, 2010, 02:48 PM
SlopeKing is offline
Find More Posts by SlopeKing
Auckland, New Zealand
Joined Apr 2002
Everyone!
"Astounded"
I am not sure whether to facepalm or lol... troll away little spoiled child.
SlopeKing is offline Find More Posts by SlopeKing
Old Apr 27, 2010, 03:31 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I have 2 and I am not up to the cost of a Trex yet haha. After putting 50-60 flights on mine I would never in my right mind buy a Trex. Its cheaper to buy a clone and upgrade a few things. Most of the things you upgrade like spindles, shafts, bearings, etc.....you will be buying eventually with a Trex anyway. The grip bolts and plastic tail case were the only problems with mine.
Brian
Tumbler is offline Find More Posts by Tumbler
Old Apr 27, 2010, 03:52 PM
dkennedy35 is offline
Find More Posts by dkennedy35
dkennedy35's Avatar
NE Arkansas
Joined Apr 2007
If it flew perfectly, for ever, what fun is that? Besides, this is a leaning experiance for me.
Lets see what I have spent extra... New Align Metal Tail ~$100, main shaft $10, one way bearing ~$10. Helicopter $67. Sounds pretty cheap to me. I didn't need to spend the extra money on the fancy tail, but what the hey, I had a $100 burning a hole in my pocket.
Sounds like befetti has been eating some sour grapes.
dkennedy35 is offline Find More Posts by dkennedy35
Old Apr 27, 2010, 05:55 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
YES!!! my 500 has been moved from backorder to reserved.
Old Apr 27, 2010, 06:36 PM
Phos is offline
Find More Posts by Phos
Australia, SA, Para Hills
Joined Oct 2006
Thanks again
You can't use the stock gyro in ds mode with the stock tail servo. While the servo is digital, the pulse timing isn't compatible with the gyro in digital mode and the servo will burn out. Not sure about the ds470.
Phos is offline Find More Posts by Phos
Old Apr 27, 2010, 07:07 PM
Joined Apr 2002
And theyre sold out instantly... HK obviously cant be THAT awful at making helis XD
Old Apr 27, 2010, 07:32 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I think a lot of people are getting these for their first or step up from coax helis. They don't understand that the set ups are not that easy and a lot of problems I have seen in the threads have been set up or electric. I was one of the first people with the HK450 and posted most of the manual of the SA for everyone. If this heli has no manual, I can easily see the same.
Old Apr 27, 2010, 07:34 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
I mean just look at my Hoss. It was not even a full heli. I use to call it the franken hoss. lol! Made up from several differant 450 models.
Old Apr 27, 2010, 07:37 PM
Joined Apr 2002
Mine is my first-ever heli (planes for 8 years), so I'm just as new to this as them, a little research and some sim time is not that evil.
Old Apr 27, 2010, 07:54 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
How True that is!! I find that a small coax or 180q or mad dog 300. Helps keep the real flying experience up as well. I always have a problem with nerves and flying them in front of people really helps a lot.
Old Apr 27, 2010, 07:56 PM
Joined Apr 2002
I am not sure I perceive the meaning of this post?
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
