Mel -
I did notice some softness to the dampers. Not sure how the blades could be the cause of the tracking problems, they were balanced and there is virtually no vibration in the heli until head RPMs come up over 65% throttle. At that point, the blades spread out of track and vibration is introduced. I think the symptoms I'm experiencing are indicative of what MikeHRC pointed out earlier in the thread, the non-metal mixing arms aren't holding up at higher RPMs. I checked the washout base, it doesn't appear to be over-sized from what I have observed, though I haven't checked it in any detail. Does anyone know whether or not the "SF Mixing Arm" Align part is metal or plastic? The part I'm referring to is here. |
Cheaper fiberglass blades will flex more and the flex can varry with temperature, RPM and the phase of the moon.
There is flex lengthwise and chordwise on fiberglassblades. Most Fiberglass blades will begoodlengthwise (not as good as CF) but will be able to be twisted more than CF. |
I bought a set of the HK500GT tail grips which arrived recently. I totally dissembled them and put them back together. They have a standard axial bearing as the inner race, and radial bearing as an outer race. This is the same as the T500 arrangement on their tail grip. There are a few small differences:
1/ The GT tial grips have a spacer washer of around .9mm between the inner race half and the grip. 2/ The arms arm 1mm thicker on the GT grips. 3/ The GT grip has a 1mm chamfer between the bearing mount and the start of the blade grip itself. 4/ There was no grease on the radial bearings on both sides. 5/ The grips themselves are machined a littlle too big for the inner axial bearing. The grip dissembles leaving the bearing on the hub not in the grip. All in all they look quite good quality. I will try one out and see how it works. For $11 they seem a better bet than the Align part. http://www.hobbycity.com/hobbycity/s...il_rotor_grip_ |
Jim -
Thanks for the info - feathering shaft is brand new, an Align T-Rex 500 shaft (I bent the stock part earlier in the week when I put my HK-500GT into the ceiling), and I tested it out by rolling it on a flat metal surface, it's perfectly straight. Main shaft spins true, no wobble in the gears. No vibration in the heli when spinning up without the blades attached, and almost no vibration when the blade tracking is spot on at around 1900-2000 RPMs. At lower head speeds, I can get the tracking spot on by linkage adjustment. At higher speeds, the tracking goes way off. Perhaps the blades are the culprit, though I ordered a set of metal mixing arms and a metal washout base (Align parts) - anyone have recommendations for a vendor in the US that sells 425mm C/F main blades real cheap (i.e. around $40 or less)? If I'm gonna get new blades, I'll just go with C/F for the additional rigidity. |
I hear you on that one, the first thing I did after that crash earlier in the week was to re-tighten all ball links on the head, to be honest nothing loosened up. This wasn't a typical crash either, I mean how often does a heli punch upward into a crash (well, I guess it would be similar if a heli was crashed during inverted flight from too much positive pitch). I'm not really sure what is causing the blades to go out of track at varying head speeds. I've ordered c/f blades as well as the metal mixing arms for the head, I will swap off the blades first, if the tracking issues remain, I'll replace the non-metal arms on the head. I'm determined to pin this problem down...
Oxfordshire, UK
Joined Jan 2007
Mike. |
Bad blade tracking
I had this problem on my T-Rex 450V2 a while ago, and it was driving me CRAZY. I couldn't even get the blades to track - every adjustment (even on the "fine" (long) arms) caused the tracking to overshoot. I stripped down the head in desperation, and it turned out the see-saw arms were loose. I removed the bolts, added RED Locktite, and resecured them, and finally I achieved consistent tracking. I couldn't see this without stripping down the head due to the mixing arms obstructing the view. [hope I got the names of the components right].
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
