Old Apr 04, 2010, 02:21 PM
kctrading is offline
Find More Posts by kctrading
kctrading's Avatar
Joined Mar 2005
Looks like I will keep the 500GT...printing out the manual as I write this...I found an exp heli pro at our new hobby store in town and he's going to help set this up for me
kctrading is offline Find More Posts by kctrading
Old Apr 05, 2010, 05:00 AM
Manstra is offline
Find More Posts by Manstra
Australia, NSW, Merrylands
Joined Jun 2008
hk401b gyro setup
Guys,
I finally maidened my HK500GT on Thursday. It was very uneventful which was a good surprise. I have a JR PCM9x radio converted to 2.4G and have the 401b gyro. I have the HH\rate lead in ch5 (gear). Can I set up the gain using the on the gyro rather than through the transmitter? I am not sure how to set it through the tx as I have tried setting the throw limits on ch5 but this hasn't seemed to make any difference, hence wanting to set gain on the gyro itself.
Thanks in advance for any advice.
Manstra is offline Find More Posts by Manstra
Old Apr 05, 2010, 07:27 AM
wedgehog is offline
Find More Posts by wedgehog
wedgehog's Avatar
UK
Joined May 2008
No mate you have to do it on the tx. Just plug a spare servo into chan 5 and make sure it is moving as you adjust the throw limits, if it is then the signal must be going out the socket, so then it may be worth examining the plug and lead and solder connections inside the gyro.
wedgehog is offline Find More Posts by wedgehog
Old Apr 05, 2010, 06:06 PM
SlopeKing is offline
Find More Posts by SlopeKing
Auckland, New Zealand
Joined Apr 2002
Replace the flybar paddles, they are easily eroded by loctite, and are quite soft to begin with...
After thinking I'd removed all the loctite I may have dropped on it over the weekend, I came this morning to see ridges on the plastic, when scratching them off, I found myself scratching deeply into the paddle with only my fingernail!, the other paddle which had not had loctite was not much better. These are NOT FRN parts like the tail blades.
SlopeKing is offline Find More Posts by SlopeKing
Old Apr 05, 2010, 06:12 PM
Manstra is offline
Joined Jun 2008
Thanks Wedge, I will give that a try.
Old Apr 06, 2010, 03:57 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
the LHS sold me a Hyperion (Scorpion) 3026-1400kv
What's the link between Hyperion and Scorpion?
RobinBennett is offline Find More Posts by RobinBennett
Old Apr 06, 2010, 05:18 AM
Joined Apr 2002
Apparently the motors are the same units (According to them anyway)
Old Apr 06, 2010, 07:49 AM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
Ive had Hyperion and Scorpion as well. In my opinion they not only dont resemble each other but the performance and durability is heavily in Scorpions favor
snoshoe62 is offline Find More Posts by snoshoe62
Old Apr 06, 2010, 04:48 PM
Joined Apr 2002
re Hyperion vs Scorpion, a quick google brought up this amongst others: http://helifreak.com/showthread.php?t=189076
Old Apr 07, 2010, 08:14 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
I don't know where the original poster in the Helifreak thread got his info, but mfg. data states that both 3026-1400 motors have 10 magnet poles. The Hyperion HS3026-1400 does not have 12 mag poles as he states.
Both 3026-1400 motors have identical specs according to mfg. data. This is true for every single motor size and KV between the brands.
Hyperion also states that they are manufactured in cooperation with Scorpion. Scorpion states that they are not the same. I'd be more inclined to believe Hyperion's statement based on the specs for all motors being identical.
There could still definitely be differences in the motors like can design, balance, shaft material, and bearings that would make one more durable or smoother running than the other. But electrically, the two brands are the same.
murdnunoc is offline Find More Posts by murdnunoc
Old Apr 08, 2010, 10:24 PM
dragon68 is offline
Find More Posts by dragon68
Dragon68
dragon68's Avatar
Malaysia
Joined Dec 2008
Originally Posted by Melnic View Post
The Fitec 9257D that is like $15 shipped from RC-fans88?
I tested this on a 450 this past week and it was crappy. The 450 was great with a JR290G but putting the Fitec on it, make it jitter and not hold well. It was as if the wipers on the pot were not holding down and vibes would make it move around or something. Maybe with a 500, it will be a different story.
Let us know how well it holds and what kind of flying you do with it.
Hi ... facing same issue with Fitec 9257D for my 450 with KDS 800 gyro. I tried set mode DS off performed better with digital on ..btw fitec 9257 analog version performed better than digital 9257D....
dragon68 is offline Find More Posts by dragon68
Old Apr 09, 2010, 10:56 AM
wattnot is offline
Find More Posts by wattnot
Joined May 2009
New stock arrived twelve hours ago. Canopies are now red.
wattnot is offline Find More Posts by wattnot
Old Apr 09, 2010, 10:59 AM
JavaScript is offline
Find More Posts by JavaScript
JavaScript's Avatar
DFW Texas
Joined Feb 2010
Is the red canopy the only change?
I just got mine... would trade the yellow for the red
Assembly has begun.
JavaScript is offline Find More Posts by JavaScript
Old Apr 09, 2010, 11:44 AM
nopistons96 is offline
Find More Posts by nopistons96
who needs pistons?
nopistons96's Avatar
mankato,mn
and they're out.
looks like the head is all alloy now. i was hoping to order one this time around. i guess i'll just have to get on the backorder list. whoever sees one, post some info. hopefully they took some positive criticism and fixed the minor issues this round.
nopistons96 is offline Find More Posts by nopistons96
Old Apr 09, 2010, 12:20 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
All gone now
I agree with jls, I like yellow better, easier to see.
Melnic is offline Find More Posts by Melnic
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
