Old Mar 18, 2010, 01:28 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Well I asked him to help again and he is doing so. Youa re right, he was not very helpful before. Funny you should ask about registering with a new screen name.....Looks like i had an older account from years ago i forgot all about, so when I signed up recently it may have caused a problem because I have 2 accounts. hopefully I can clsoe one and that will solve the problem.
Originally Posted by ChrisWNY View Post
Sheesh, that is odd - I wonder if someone spoofed your IP or email and wreaked havoc in their forums, I have had an account there for over a year now but really have only watched the videos and haven't posted. Will it allow you to register a new screen name, or are you blocked immediately just by entering the site? Sometimes message forums will automatically block traffic from "blacklisted" IP's, and this software can often be faulty which can result in what you are experiencing. The fact that the admin was a real jerk in his response obviously isn't helping. Sounds like that admin doesn't give a #@%! about his own message forum...
I guess my first post will be directed within the complaints area of their forum, letting them know that their forum software is blocking legit users...
Tumbler is online now Find More Posts by Tumbler
Old Mar 18, 2010, 01:33 PM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Originally Posted by mccheli View Post
How this electronic package for the HK500GT? I'd like to keep it low budget.
mccheli - that link is resulting in a "404 Page Not Found" error, please double-check the link and re-post. If you check the first page of this thread and follow the link to Melnic's EXI 500 thread, you should find a lot of helpful information on selecting the right electronics for your HK-500GT.
ChrisWNY is offline Find More Posts by ChrisWNY
Old Mar 18, 2010, 05:21 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Originally Posted by rowdyjoe View Post
Servo creep?
RJ
I'll poke my head up over the wall here. I think the servo creep is nothing more than the result of the gyro not being set for zero stick properly while also having the gyro in HH mode while on the ground. AVCS just keeps moving the servo slowly in response to what it things is very slow rotation of the heli. Proof is too switch to Rate mode and see if the creep stops.
Try doing the 'three mode changes' in 3 seconds to reset the gyros learned center point again...
PLMS is offline Find More Posts by PLMS
Old Mar 18, 2010, 05:39 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Originally Posted by mlinder View Post
Martin,
Thanks for your help.
I did what you suggested. I unplugged the single wire plug and plugged in a servo. When I adjust the gain, the servo indeed moves. So the Rx appears fine.
So I guess the gyro is messed up? I just got it about two weeks ago. I hope Hobbypartz will replace it - but I don't have the package anymore.
Mark
To clarify. When you had the servo plugged in, did the servo swing from end to end when you changed modes ?
If it stays at one end of its travel and just moves a bit at that end then you are not actually changing modes with the TX. I assumed you used a servo that had the arm centered on it before you used it too.
One very handy gadget I use when helping mates setup their gyros is my 'servo tester'. This eliminates the TX so you can prove the gyro is behaving first.
With the gyro gain input plugged into the tester, the gyro should indicate HH Mode at one side of center on the knob, and Rate Mode at the other. Obviously the gyros other cable needs to be plugged into the model or another tester to receive power and a rudder input also.
Old Mar 18, 2010, 06:32 PM
mlinder is offline
Find More Posts by mlinder
Santee, CA
Joined Jul 2006
PLMS,
I would have replied sooner to you and Tumbler and others who have given me input on this gyro thing, but work got it the way
Anyway, I tried the servo test again that you suggested and indeed the servo swings when I change modes. So based on that, and the fact Tumbler says his HH light stays on too tells me its a "feature" of this gyro
I just got back from a test hover and a little FF. I set the gain to 92 and actually got a little wag in it. I feel better now, I think. It would appear the electronics in this gyro just may be a bit diffferent than others. After all, I guess the HH/rate mode percentage is just a relative number, right?
I am going to put this issue to rest for now. Now, I gotta get the blades to track properly. I have an Align main shaft and feathering shaft in there, but I can't get the blades to track. Granted, they are the stock blades, but they balanced well. I will say that, even with Align dampeners in there, the blade grip assembly wobbles in there, as if the HK head block recess where the dampeners seat was machined a few thou too big, allowing some slopy movementp. I ordered an align head block which hopefully will fix this. Anyone else have this problem?
Thanks again to all who have chimed in on the gyro issue!
Mark
mlinder is offline Find More Posts by mlinder
Old Mar 19, 2010, 07:24 AM
T-spin is offline
Find More Posts by T-spin
Joined Mar 2005
Mark
Yes I have the same problem. Can't keep it in track. Changed all the shafts, dampers, next the blades and links. Have them on order now should be next week.
Tony
T-spin is offline Find More Posts by T-spin
Old Mar 20, 2010, 11:21 AM
Jon h2 is online now
Find More Posts by Jon h2
United States, MI, Royal Oak
Joined Dec 2003
First flight was this morning. This heli is very nice! I am pretty impressed with the Hobbyking 401B gyro. It is tracking perfectly and no vibrations. Head speed is high with the Typhoon motor and 12T pinion, I have not tach'ed it yet though.
It appears that there is one bad cell in my Zippy 6S 2650 pack. It was way down on power and my charger now only sees 5S... One cell is .3 volts below the others. The other Zippy pack is fine.
I will be putting the battery in an ammo case and sticking in the driveway in the event it blows!
Jon h2 is online now Find More Posts by Jon h2
Old Mar 20, 2010, 12:21 PM
mlinder is offline
Santee, CA
Joined Jul 2006
Jon, I have the very same problem with a brand new Turnigy 3000 6s pack. Charged it once, voltage was fine, Hovered using that pack. No problems. The next day - charger won't charge it as one cell reads 1 volt!
Too costly to send back to Hobby King. What can I do with this pack (besides drowning it in salt water)?
Mark
Old Mar 20, 2010, 12:28 PM
daybyter is offline
Find More Posts by daybyter
Bundesrepublik Deutschland, Rheinland-Pfalz, Kaiserslautern
Joined Apr 2007
Check the joints, where the cables connect to the cells. Maybe there's some shortcut between 2 cells.
daybyter is offline Find More Posts by daybyter
Old Mar 20, 2010, 12:41 PM
mlinder is offline
Santee, CA
Joined Jul 2006
Hmmm,
I have to cut into the pack to do this, right? (I foresee a "Kaboom" moment coming!)
Mark
Old Mar 20, 2010, 01:26 PM
daybyter is offline
Joined Apr 2007
Just open the shrinking tube a bit. Be careful _not_ to cut into the cells!
Old Mar 20, 2010, 01:50 PM
mlinder is offline
Santee, CA
Joined Jul 2006
I guess I have nothing to lose.
If you see or hear about a mushroom cloud over southern California this afternoon.....
It's me
Mark
Old Mar 20, 2010, 02:11 PM
daybyter is offline
Joined Apr 2007
Well, if you get to the point, where you are not so sure what to do...just stop...
Maybe you have comrade, who is familiar with battery soldering etc?
Old Mar 20, 2010, 02:43 PM
mlinder is offline
Santee, CA
Joined Jul 2006
Yeah,
I will have to find someone knowledgel on this stuff. i'm just not comfortable with it. I just don't know anyone with such skill and knowledge. I took the shrink wrap off and exposed the circuit board that has the plug leads and the balance wires attached to it. I haven't the guts to pry the circuit board off the peek underneath.
Mark
Old Mar 20, 2010, 11:19 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Mark,
If you can see the circuit board and the balance wires are securely soldered, you have a bad cell. If you have access to a voltmeter with probes and you want to make sure, you can touch them to the individual solder points on the circuit board in the same order that they're in the balance plug. Two wires that are next to each other in the balance plug should give you one cell's worth of voltage. Any two adjacent wires that don't get 3.0-4.2V indicates a bad cell.
murdnunoc is offline Find More Posts by murdnunoc
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
