Mark/Brian -
I think we need to figure out how you are handling your Gyro programming. It seems to me that you guys are using the GEAR channel EPA values to set gain in rate and HH modes. I may be wrong here (and I'm sure I'll be corrected), but I thought you had to be in the NEGATIVE range (-25% for example, within the DX7) to be in rate mode if you're using the GEAR channel EPA mode to set gain, so the higher the negative value, the higher the gain in RATE mode. It's definitely mind boggling why the various Radio manufacturers couldn't all agree on a standard regarding how to deal with Gyro gain adjustment from the radio. You have to use some obscure math formula to figure out "true" gain with Spektrum, the gain setting within a Futaba radio is "true" gain, no math necessary. |
I am using the gear channel yes. I don;t use rate mode other than just to get everything set up mechanically. I had it at -50% in rate mode for setting it up and have never touched it. I have it at +90 in HH mode.
yeah and why is expo for futaba negative and positive for jr haha. I have a gyro gain setting on my tx. Does anyone use that or do you all just use the gear channel and travel adjustment?
I have noticed that it seems like everytime I fly mine I need more and more left rudder trim. Whats that all about. I had 16 clicks of left trim in it now. I just adjusted the linkage to compensate. It was originally perfect when I first set it up. It has about 30 flights since and now the nose wants to go right all the time.
RJ |
Bundesrepublik Deutschland, Rheinland-Pfalz, Kaiserslautern
Joined Apr 2007
There could be other reasons for this, like a belt slowly getting longer and longer. If you have gyro drift, check if it's only in the first minutes of a flight. If so, check the trim setting at the end of the flight and adjust the linkages, so you have zero trim then.
The trim change sems to be consistent throughout the whole flight. I am using an Align belt which is sooooo much betetr than the stock belt as far as kleeping its tension, but that's not to say it could not be quite as tight as it used to be. Hard to tell because it, seems like it is perfect....not a difference I can measure for example.
Some servos (especially on the tail) must be "trimmed" to prevent them from moving on their own. It's done with sub-trim and you adjust it until the servo stops moving on it's own (it creeps).
I recommend you go to the "Helifreak" forum and do a search for "servo creep". There are excellent instructions there that will walk you through the steps to adjust it out. RJ |
RJ,
The instructions for my gyro warn specifically against using subtrim though. I would love to research on helifreak, however a week after I joined I got banned and have contacted the administrator who said they don;t show me on the banned list and if its not right there is nothing I can do. The guy was a real jerk! Hi, That IP is not banned. 64.12.117.5 is not banned. I am not sure what is going on with AOL, but unfortunately there is nothing I can do about it. Thank you, Will On Feb 10, 2010, at 4:11 PM, Tumbler @ HeliFreak wrote: > > The following message was sent to you via the HeliFreak Contact Us form by Tumbler ( mailto:bdicinti@aol.com ). > > -------------------------------- > > I was not given a reason for being banned? I don't even think I have 3 posts, non of which were offensive or anything, so not sure why I would be banned. Please let me kow. > > Thanks, > > Brian > Brian Quote:
Sheesh, that is odd - I wonder if someone spoofed your IP or email and wreaked havoc in their forums, I have had an account there for over a year now but really have only watched the videos and haven't posted. Will it allow you to register a new screen name, or are you blocked immediately just by entering the site? Sometimes message forums will automatically block traffic from "blacklisted" IP's, and this software can often be faulty which can result in what you are experiencing. The fact that the admin was a real jerk in his response obviously isn't helping. Sounds like that admin doesn't give a #@%! about his own message forum...
I guess my first post will be directed within the complaints area of their forum, letting them know that their forum software is blocking legit users... [EDIT] Brian - I created a new thread within the website help area of helifreak letting them know that a legit user has been banned (I provided your screen name) for no apparent reason and that their admin, "Will", didn't exactly seem willing to help. Hopefully they'll check into it further for you and fix the issue. |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
