Old Oct 13, 2009, 11:05 AM
Dannyrevs is offline
Find More Posts by Dannyrevs
Pile it in!
Dannyrevs's Avatar
Kalamazoo Mi
Joined Sep 2009
Prop selection
Hey guys just need a question cleared up. I have a Easystar and am going brushless.
Do i need to buy a Pusher prop? I see alot of guys run APC 6x4 but they never say if they run pusher specific props or not.
What throws me off is Multiplex puts out a power pack kit for the easystar and minimag.
The Minimag is a puller set up and the Easystar is a pusher set up. Yet you only get one prop with the powerpack which is supposed to be universal for both i guess.
Please clear up my prop issue
Much appreciated later...
Dannyrevs is offline Find More Posts by Dannyrevs
Old Oct 13, 2009, 12:55 PM
Warningshot is offline
Find More Posts by Warningshot
Freedom Isn't Free
Warningshot's Avatar
SE Okla
Joined Mar 2006
Pusher props are not required. Prop numbers face forward.
Warningshot is offline Find More Posts by Warningshot
Old Oct 13, 2009, 01:12 PM
Carlson77 is offline
Find More Posts by Carlson77
Carlson77's Avatar
Peoria, IL
Joined Aug 2008
That's right! Make sure it spins the right direction too With brushless you can easily change the direction by swapping any of motor 2 leads.
Carlson77 is offline Find More Posts by Carlson77
Old Oct 13, 2009, 01:17 PM
foamnpacktape is offline
Find More Posts by foamnpacktape
Build it, don't buy it
foamnpacktape's Avatar
Calgary, AB, Canada
Joined Apr 2008
Almost always.
Pusher props are generally only needed when a motor turns only one direction such as a IC engine or a brushed, timed motor, and also when one wants counter rotating twins.
Brushless motors don't really care which direction they turn, thus no need for a pusher. Just mount the prop with the same side facing forward as it would were it a tractor. In most cases this will be with the prop number forward, but not always as it is not a universal standard to label them this way.
foam.
foamnpacktape is offline Find More Posts by foamnpacktape
Old Oct 13, 2009, 04:24 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
FYI, APC props have the numbers facing FORWARD (non pushers).
Also, the prop included with the power pack is total crap. The APC 5x5 isn't very effecient, and an APC 5x4 or 6x4 would outperform it
Also, go with an APC 6x4E for your easy star
Xpress.. is offline Find More Posts by Xpress..
Old Feb 20, 2010, 12:32 PM
Pile it in!
Dannyrevs's Avatar
Kalamazoo Mi
Joined Sep 2009
Well i got the power pack and ive been using the 5x5 that came with it. I am now going to try to experiment with new props now that i have bought a watt meter.
Prop selection for MAX 001 6:1 gear drive...help!! foss1997 Parkflyers 2 Jan 05, 2002 12:28 AM
Prop selection for Graupner 480 Race?? DaJudge Power Systems 5 Oct 04, 2001 03:53 PM
Prop selection? Superbike High Performance 5 Aug 04, 2001 08:58 PM
Tipsy Nipper, Prop selection for S400 2:1 gearing? Red Baron 47 Power Systems 5 Aug 01, 2001 07:38 PM
prop selection for geared T-52 radix2 Foamies (Kits) 12 Jul 06, 2001 03:42 PM
