Go Back   RC Groups > Aircraft - Exotic and Special Interest > Auto Gyros
Old Oct 21, 2009, 10:36 AM   #31
This is my other autogyro!
rotorheid's Avatar
Build complete, test flown, tail heavy, but it blinkin works!
Hi Guys,
I managed to get her completed and test flown, needs a bit of fettling now, adjust the C/G and try again, after my holiday. My taxy leaves for the Airport in 2 hours, then, I'll be offski! real world here I come WooHoo!
Todays happy snaps and a video of the fun and games, I have to put back on the 12x6, pants! The rotor spar cracked in the middle, so now I can make a fitting to hold the two halves together. Cheers and out.
regards to all, Al
http://www.vimeo.com/7182817
  • Name: P1030869.jpg
Description: Fuselage all done weighs in at 900g less battery and rotors. Fuselage all done weighs in at 900g less battery and rotors. 39.9 KB · Views: 20
  • Name: P1030870.jpg
  • Name: P1030871.jpg
Description: Hey Al, you sure you got this right? Hey Al, you sure you got this right? 53.0 KB · Views: 40
  • Name: P1010075b.jpg
Description: Baco-Liner taxys out. Baco-Liner taxys out. 26.7 KB · Views: 26
  • Name: P10100~1c.jpg
Description: Baco-Liner gets airborne, briefly. Baco-Liner gets airborne, briefly. 17.8 KB · Views: 30
rotorheid is offline Find More Posts by rotorheid   Reply With Quote
Old Oct 21, 2009, 10:48 AM   #32
Gustavo Caminos
gustavochacha's Avatar
Congratulation Al!! and also congratulations to my compatriot Baco!!! we are colleagues in foro-aeromodelismo.com in Argentina.
Internationals greetings!!
Gustavo Caminos (CHACHA)
gustavochacha is offline Find More Posts by gustavochacha   Reply With Quote
Old Oct 21, 2009, 10:59 AM   #33
rotorheid's Avatar
Hola! Gustavo
Good to hear from you, thank you, I tried to email Baco to let him know I was undertaking this project, please say Hi and thank him, from me, cheers!
regards Al
Old Oct 21, 2009, 11:27 AM   #34
JochenK's Avatar
Al,
she's flying, which is more than I ever thought she'd do. Congatulations!
Jochen
JochenK is online now Find More Posts by JochenK   Reply With Quote
Old Oct 21, 2009, 12:04 PM   #35
Keep it simple
alfoot's Avatar
Al,
That was great - it reminded me of a kite version I had when I was much younger
Look forward to the next development phase, like Jochen I am astounded that it flew so well.
This has got to be an Inter-Ex 2010 entrant Al.
The other Al
alfoot is offline Find More Posts by alfoot   Reply With Quote
Old Oct 21, 2009, 01:27 PM   #36
can you land on that ?
Interex definite Al. Plan your next years leave now !
arrow5 is offline Find More Posts by arrow5   Reply With Quote
Old Oct 21, 2009, 01:38 PM   #37
Suck it and see
Norfolk Flyer's Avatar
Well done Al. Once you have sorted that CG issue this model will be a show stopper!
It was definitely nose high but really trying to fly despite it.
Good luck and best wishes,
John
Norfolk Flyer is offline Find More Posts by Norfolk Flyer   Reply With Quote
Old Oct 21, 2009, 03:54 PM   #38
jodini's Avatar
That was awesome! Try, try again Al! Yes, hopefully a little lead in the front will get it to cut thru the air. It looked great...spun up good!
jodini is offline Find More Posts by jodini   Reply With Quote
Old Oct 21, 2009, 05:46 PM   #39
Boneswamped's Avatar
Hello Al,
Great job with the build. When you work out the final kinks, I simply must have plans for that thing! I knew you could do it all along my friend.
Regards,
-Mike
P.S after watching the video several times; I think a bit of Dihedral between the rotors would help Roll stability. Same concept a trainer fixed wing with rudder and elevator only uses.
Boneswamped is offline Find More Posts by Boneswamped   Reply With Quote
Old Oct 21, 2009, 06:53 PM   #40
MarioIArguello's Avatar
Make the Rotor head Semirigid or Flex and you got it!
Al,
Just saw the video, have not had time to go over the whole thread and photo build...
Your rotor head is rigid (I think) and roll will take the rotor with the frame in a turn or wind gust, just like on your first test video. If you float the head or make the Center of the rotor head connection to the support semirigid or slightly flexible so that the spinning rotors stabilize themeselves, you will resolve the problem of the aircraft tipping over and taking the rotor along with it. This too could be fixed with lighweight stabilizer and rudder with suffiicient area to compensate for more control pitch and roll, with a rigid rotor mount.
You could mount the center main ball bearing in a rubber inner ring to allow for some dampening. Or float it completely in a gimbal and use two guy wire style springs to center the rotor bar and hold in place.
The durometer of the rubber or spring tension will determine the amount of flex or dampening, you will need to experiment a bit to find that magic point!. Not too tight , not too lose.
Also consider rotor and thrust prop direction, either supporting or counteracting torques involved.
Interesting build, seen photos of similar models in RC magazines but never saw one flying.
MarioIArguello is offline Find More Posts by MarioIArguello   Reply With Quote
Old Oct 21, 2009, 07:15 PM   #41
I don't agree with Mario at all. Helicopter aerodynamics have nothing to do with this design. I'm suggesting dihedral between the two rotors in exactly the same fashion as a rudder/elevator only fixed wing. A flexible mount as Mario is suggesting would result in the rotor flapping up to the max allowable flex angle and staying there as long as lift is being produced by the rotor. Generally speaking, the rotors you made produce nearly the same lift vector as a fixed wing of the same size. There is no flapping, no lead/lag, and no dysymetry of lift(with the exception of a small amount from yaw differential) with this type of design. Enough of my rambling, I'm saying that a few degrees of positive dyhedral between the rotors should make the model much more stable.
-Mike
Old Oct 21, 2009, 07:30 PM   #42
dgoslee's Avatar
Originally Posted by Boneswamped
Hello Al,
Regards,
-Mike
I doubt if dihedral would have any affect. Since the rotors have no inherant angle of attack, a yaw or side slip just wouldn't cause a lift differential.
Dan
dgoslee is offline Find More Posts by dgoslee   Reply With Quote
Old Oct 21, 2009, 07:38 PM   #43
You're right there is no set angle of attack, however, the lift is perpendicular to the rotor. Yaw differential would be minimal do to yaw, but it is in fact mathematically there. So that being said, if there were dihedral between the two there would be Positive static stability built in. Seems like an easy thing to test in any event. One of the cylindrical lifting concepts NASA tested had built in dihedral(what do they know ).
Regards,
-Mike
Old Oct 21, 2009, 07:41 PM   #44
Viva Juan De La Cierva
imsofaman's Avatar
Send a message via AIM to imsofaman Send a message via Yahoo to imsofaman
I think dihedral will be what you are looking for Al. Your lift is being produced by each rolling wing. Just because it is a rolling wing.....does not mean all rules of aerodynamics are just thrown out the window. You cant fly a flat wing with rudder and no ailerons. You need dihedral.....not much, maybe 3 or 4 degrees each side.
1. Add dihedral
2, you are tail heavy.....either add nose weight or move the mast back some.
Just my $.02 cents..............
Dave
imsofaman is offline Find More Posts by imsofaman   Reply With Quote
Old Oct 21, 2009, 07:44 PM   #45
imsofaman's Avatar
Also....you may benefit with your tail feather ABOVE the turbulence of the rolling wing. Like a Mud Duck tail. Otherwise.....you may not have much control..........
Al's Ultimate Raptor meets the "box"... GGoodrum Electric Heli Talk 17 May 17, 2004 04:24 PM
what's your most embarrassing build tool? Dunqun Slope 7 Apr 28, 2004 05:10 PM
Earl Stahl's GEE BEE Sportster build (E-conversion) Arthur_GA Sport Planes 3 Mar 31, 2004 11:06 AM
F/S HYPER DLG - Custom Build, Poly, 2 Channel glider34 Aircraft - Sailplanes (FS/W) 8 Oct 08, 2003 04:07 PM
Did you help me at Al's Hobby Shop in Elmhurst? JoeRC Parkflyers 5 Aug 06, 2003 10:37 PM
Bored? Want to fight?
Join the RCGroups clan!
