Old Apr 15, 2012, 10:19 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice ...any of you guys try a Jet Fan 90mm in one of these ,i have one in my Tams F-16 and it is awsome on 8s and easy on the batts (5000mah) they sound very nice and run super smooth. and german quality and the price is good too .i've got 3 of them ...so i need to build or get a another 90mm jet ...been thinking alot about this one .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Apr 16, 2012, 10:23 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Originally Posted by Dionysus View Post
...anyway have some pictures for all the HUN drivers here! Especially for those that have to much to do and don't have time to finish their Huns!
Blamo! Right in the gut! Ha ha ha Awesome Hun Luke, thanks so much for re igniting this thread and getting more guys (like me among others) to finish their Huns.
I've got a Version 1 JF90 fan that I'll be running in my F-100 along with a spare CS90 rotor. My plan is to fly both rotors within a few weeks of the maiden. Probably maiden the model with the JF90 because I know it's going to be real simple to set up smooth and get some initial flights and data, and then after I get it dialed in I'd like to fly the CS 12 blade rotor. When I get two minutes to spare and can get to my workshop I'll be on track to actually finish this jet and hopefully get some data for you. Better yet, how 'bout you buy one of these and finish it up so you can keep me motivated I've sucked poor Luke's free time dry in all the pictures and videos he's made for us in the name of classic Century Series fighters being brought back to life.
Eddie P is offline Find More Posts by Eddie P
Old Apr 17, 2012, 01:30 AM
heliclown is offline
Find More Posts by heliclown
Australia, NSW, Hillsborough
Joined Feb 2008
Dionysus
Hey Luke, i quickly run her up today (static)These numbers are " in the airframe",CS 12 blade fan" as is" ie ..(unbalanced as yet.
Het 700-68-1400, CC100 ESC. 8S (6+2) 4500 45-90C NanoTech.
3.14 Kg thrust(6.9 lbs) Data log details:-
26.5 Volts
117 Amps
3118.6 Watts
31,604 RPM ( i am assuming motor is 4 pole)
Kv under load=1188 kv
Can you tell me your numbers please mate?
Steve
heliclown is offline Find More Posts by heliclown
Old Apr 17, 2012, 01:37 AM
Joined Feb 2008
Dionysus -PS
Luke
Forgot to ask,Are you running a thrust tube? if so what diameter?
My Figures are stock exhaust(no thrust tube,as yet)
Cheers
Steve
Old Apr 17, 2012, 06:16 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
C of G FF F-100
I have been flying over 35 flights so far with the center of gravity located 280mm from the LE. With the cockpit blinged out at 150g my 840g 6S 5800mah Zippy 30C battery is pushed all the way to the back of the battery cave.
For those building 8S it would be helpful to move the fan farther back to keep the C of G right. It wouldn't be hard to do in the building stages. My total flying weight is 4kg (8.8 pounds for non-metric types) with the drop tanks but it flies as if it was lighter.
Cheers Eric
4stripes is online now Find More Posts by 4stripes
Old Apr 17, 2012, 08:20 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
26.5 Volts
117 Amps
3118.6 Watts
Steve
Your avg cell voltage is dipping below 3.5 (3.3 per cell) or you might have a popped or lazy cell in the pack.
erh7771 is online now Find More Posts by erh7771
Old Apr 17, 2012, 09:12 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
eddie P, you wont be disapointed with the jetfan, and im here to tell you the amps will be WAY less for the same performance over the cs90. and it sounds just as good
corsair nut is online now Find More Posts by corsair nut
Old Apr 17, 2012, 10:13 AM
Joined Nov 2005
For the Watts to Watts are we talking about the JF90 needing 25-35% less power for the same static thrust using similar motor mag fields?
If so it sounds like something to look at.
Old Apr 17, 2012, 11:20 AM
tehachapi, CA
Joined Jan 2006
the JF90 only has about 5% more load than a midi fan. i know the CS looks and sounds cool, but so does the JF and it does it at alot less amps. my 9 lbs HET prototype F-20 does a good 140mph and has awesome vert for weighing 9.25lbs....all this on only 2600W on 8s. 5 min flights with lots of hot dogging are the normal for it. and it takes over 1/2 power to stay at a good clip because of the lack of wing LOL
Old Apr 17, 2012, 11:31 AM
Joined Nov 2005
Do you remember the static thrust on 2600 watts?
Also, anyone know the release time of the f20?
Looks like good speed
Old Apr 17, 2012, 11:48 AM
Dionysus is offline
Find More Posts by Dionysus
Dionysus's Avatar
McQueeney TX
Joined Oct 2005
26.5 Volts
117 Amps
3118.6 Watts
Steve
Steve, Those # look about right for the 1400kv motor. Here is my data log for a flight, it shows some motor run ups and then the take off, then after take off I throttle back and keep the rest of the flight around 60 amps. This was the short test hop when the combination was new. I never bothered to check the # on any following flights.
Luke
Cheers
Steve
No thrust tube, works great as is for me plus I have the larger elevator servo's suck into the fuse, actually protruding into the tail pipe, so a thrust tube would not work that well on mine.
Dionysus is offline Find More Posts by Dionysus
Old Apr 17, 2012, 03:14 PM
Joined Feb 2008
Dionysus
Any thrust figures Luke? And what brand Lipo ?
Mine does look like a dud compared to yours(voltage drop wise)My cells are new(1 flight only
\ Cheers Steve
Old Apr 17, 2012, 04:13 PM
Eddie P is offline
Official Boat Bum
Eddie P's Avatar
Joined Mar 2000
That would explain it- your cells being new and not broken in. What a lot of people suggest for new packs is 5 cycles at 1C going to 2C by the 5th cycle to "break in" packs. After 5 cycles you should be good to fly and expect full pack voltage and performance under load. I would not do any more full power runs with those packs until you give them 4 more cycles under a lot less load. Then have at them.
It's not such a big deal with packs being used as "sport" packs on low amp applications. Our poor packs put up with extreme abuse in high amp draw setups so break in has become the norm in EDF.
Old Apr 17, 2012, 04:17 PM
Joined Feb 2008
Eddie P
Thanks for the good advise, will do that and see if they sustain a bit better. I hope i haven't stuffed them already?
thanks
Steve
Old Apr 17, 2012, 04:53 PM
Joined Feb 2008
EddieP
So i run it at 4-5 amps(1C) and gradually build up to 9 amps, by the 5th run?Have i got that right?
Thanks Steve
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
