Old Dec 11, 2011, 05:20 AM
MADISONMaster is offline
Find More Posts by MADISONMaster
MADISONMaster's Avatar
France, Burgandy, Dijon
Joined Jun 2010
weight and trust ?
Originally Posted by kc135boomer View Post
Posted this on the other F-100 thread. You can hand launch it with a 6S setup and here is the proof...
http://www.youtube.com/watch?v=uXG-y6f_uBY
hello !
what was the weight of the plane?
you have an idea of ​​the trust?
Thank's
MADISONMaster
MADISONMaster is offline Find More Posts by MADISONMaster
Old Dec 11, 2011, 06:42 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by MADISONMaster View Post
hello !
Thank's
MADISONMaster
Prolly around 6lbs of thrust easy
Its a small setup. 6S 4000mAh pack. Medusa fan and HET Typhoon 600-37 motor. Its no P3 F-16 or Squall that runs 100+ but its scale looking.
erh7771 is online now Find More Posts by erh7771
Old Dec 11, 2011, 09:49 PM
kc135boomer is offline
Find More Posts by kc135boomer
"Jesters" KC-135 Demo Team
kc135boomer's Avatar
United States, MI, Manchester
Joined Sep 2005
Same setup for me as erh7771. I am getting 75-80 mph with it.
kc135boomer is offline Find More Posts by kc135boomer
Old Dec 12, 2011, 08:05 AM
Joined Nov 2005
I should've put quotes around mine, that's not my set up...
I have a TACON 40mm x 74mm 2000kv care motor in one of the Haoye 6 blade shrouds with a Fly Fly 6 blade rotor...2000watts easy around 7.5plds of get gone.
I would love to get a video of mine but it has to be going 100 straight
Old Jan 18, 2012, 01:48 PM
silent_guru is offline
Find More Posts by silent_guru
Hold my Beer and watch this!
silent_guru's Avatar
USA, MA, Brockton
Joined Sep 2007
I bought this motor from HK for my f-100:
S3674-1660 Brushless Inrunner (1660kv)
http://www.hobbyking.com/hobbyking/s...dProduct=15234
Opinions? Any one else have one?
silent_guru is offline Find More Posts by silent_guru
Old Jan 18, 2012, 05:16 PM
Joined Nov 2005
Fly Fly F100\ CS 12 blade 90mm\ 7s (2 min 2 sec)
Joined Nov 2005
Posted you a reply in the Wingspan100 thread.
Were did you get your F100 from?
Regards
Old Jan 18, 2012, 07:23 PM
USA, MA, Brockton
Joined Sep 2007
Regards
I bought it from the HobbyKing USA warehouse, A Christmas present to myself
Old Jan 24, 2012, 07:11 PM
Eddie P is online now
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Wow you guys had some serious chat going on. Who's still building?
I picked up my build again, a few weeks ago. Feeling sick right now but I'll get going on it again next week. I've done some cutting - I cut out about 2.75" from the forward fuse to make it look like a single seater in profile. I also bought a Keith Sparks canopy for a single seater. I'm having a lot of fun with it. I'm ready to start glassing. (I bought a EPS version to glass it. Now that I have seen EPO for myself not sure if I'd do it again!!)
The fuse shortening required a little bit of foam inserts to make the forward section as wide and tall as the fuse is normally at the wing. But it was pretty easy to do. I have a lot Pink Corning foam from the hardward store - enough to fabricate shims like this mod needed for years to come Right now I still have to mount my nose gear module (removable) and then I'll be ready to glass the fuse - wings and tail surfaces are ready to go too.
Eddie P is online now Find More Posts by Eddie P
Old Jan 25, 2012, 02:01 PM
Joined Nov 2005
Originally Posted by Eddie P View Post
Wow you guys had some serious chat going on. Who's still building?....
I was supposed to be scaling mine out with AB lights, head lights fueling probe, front and main gear doors, cockpit lights and some better scale dragging gear but you know how it is... once you get it up in the air.
Thinking about doing a 12s 1100kv rc lander or putting one of my older fans on 7s with it to get around 10lbs of thrust either way. This is a big foamy, worth pushing it to it's limits.
The CS 12blade is a lil too quite for me in this fuse cause the exhaust walls don't flex.
Old Jan 25, 2012, 09:25 PM
Official Boat Bum
Eddie P's Avatar
Joined Mar 2000
Great, thanks.
Hey, has anyone glued in their horizontal stabs permanent and just made this thing with elevators? I like the flying stab "idea" but I don't really care for the attachment method. I've made a mod or two to improve it, but I'm hesitating about the strength and precision of it as a flight control still.
Old Jan 26, 2012, 12:21 PM
Duke58 is offline
Find More Posts by Duke58
Whispers to the Wind
Duke58's Avatar
Hayward, CA
Joined Apr 2001
Great, thanks.
I thought about that when I built mine and I'm glad that I went with the all moving setup, you really need all that surface area back there , I wanted to have lots of throw and dial it back as needed , ended up using it all. I opened up the plastic insert a bit to allow for more travel and used a long cap screw instead of the provided part , also put in fishing weights to balance them ,
and do grind a flat spot on the shaft.
Been bashing this plane for over a year now without any problems back there .
Earl
Duke58 is offline Find More Posts by Duke58
Old Jan 26, 2012, 04:54 PM
Dionysus is online now
Find More Posts by Dionysus
Dionysus's Avatar
McQueeney TX
Joined Oct 2005
I'm still building, some people that have been following this thread a little longer know that I scaled out one in Vietnam green and brown and it turned out really nice, well it lasted 30 seconds when my brand new JR 9 channel radio decided early on in the flight that it should completely unbound. I had nothing to do but watch it fly off and into the ground.
So I've gotten over it and I'm already well on my way with #2! It will be silver this time with some yellow lightening bolts down the side with a Futaba radio.
Dionysus is online now Find More Posts by Dionysus
Old Jan 26, 2012, 05:11 PM
Joined Nov 2005
Wow makes me want to finish scaling mine out...got some other projects going on though
Old Jan 26, 2012, 05:12 PM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Nice. I need to pick one of these up down the road.
mike2663 is online now Find More Posts by mike2663
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
