Old Nov 30, 2010, 05:28 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Yup, those super UGLY panel lines that FlyFly dumps on us. I filled them with spackle on my Sabre but opted not to on the Hun. Wish I had filled them. Painting with all those deep grooves is a pain, and I suspect that when I get to the decals they'll be a real PITA. If you still have the option, I'd fill them with light spackle. It's easy to do, get it wet and just smear it on with your hand. The surplus sands off readily with a damp sponge sanding block. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Dec 05, 2010, 09:13 AM
Lars N is offline
Find More Posts by Lars N
Lars N's Avatar
Norway, Akershus, As
Joined Apr 2007
What engine and ESP from hobbyking do you redommand for this model?
Lars N is offline Find More Posts by Lars N
Old Dec 08, 2010, 06:30 PM
Duke58 is online now
Find More Posts by Duke58
Whispers to the Wind
Duke58's Avatar
Hayward, CA
Joined Apr 2001
Q!
OK , spent the last day or so fitting the fuselage sides and making sure that everything is just right for the join, mix up some slow cure epoxy, get all the parts ready and start spreading the epoxy . You guessed it , the damn stuff starts to kick before I'm done had to finish off the after section with medium CA ,,,working fast !
I installed a door for the receiver in the back of the battery bay onto the duct and put a solid piece where the front gear was for a catapult hook , also reinforced the front to back fuselage joint ( it looked like a point that wanted to break) I plan on installing the fan and going for a full power run up tomorrow.
Earl
Duke58 is online now Find More Posts by Duke58
Old Dec 08, 2010, 07:38 PM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Hi!
I am using on large surfaces and did use on the F100 Mitopur glue. Mitopur is a one component, moisture curing PU (polyurethane) adhesive. You just spread it on one surface, stick it together and watch how it cures.
And it is very cheap, a bottle of 500ml is only 10€.
Pisaneli is offline Find More Posts by Pisaneli
Old Dec 08, 2010, 09:26 PM
Duke58's Avatar
Hayward, CA
Joined Apr 2001
Originally Posted by Pisaneli View Post
Hi!
That sounds like something we have here , the glue foams up and expands , right ? I like it but you can not control how it expands , I used some of it to fill where I replaced the gear holes with blocks of foam. You no doubt have products that we here in the " Peoples Republic of California " will never see
Earl
Old Dec 08, 2010, 10:56 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Earl
LOL!
Sorry, just thought that a bit hilarious
AceMigKiller is online now Find More Posts by AceMigKiller
Old Dec 09, 2010, 05:57 AM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
....."the damn stuff starts to kick before I'm done ".....
Sounds like you mixed it in a pot or mixing cup. That starts to heat and will cure at a much faster rate. I use a flat surace when mixing epoxy leaving it in a big puddle and it won't heat like that. If you use a mixing cup for large quantities have something cold to sit it in like ice water. Tex.
Old Dec 09, 2010, 07:08 AM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Earl
Yeah, that's the one. I used it almost everywhere. It is great for repairing and bonds almost everything. I just have to wipe the excess when the glue cures. I glued all large surfaces on F100.
This works both ways. I bet you have products we will never see.
Old Dec 09, 2010, 07:50 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
The Turnigy 36-56 here 1200KV motor with the 7 blade haoye in the kit with the HK 8s ESC here (best 15 dollars I've spent) gives me these numbers.
64oz thrust on 6s 40 amps
72oz thrust on 7s 52 amps
92oz thrust on 8s 63 amps
I like this set up because you can fly this thing off a 2200 mah 6s or 2 small 3s 2200's in parallel all to 8s if you want.
On 8s the motor stays cool but I'd still use a heat sink, I don't trust ANYONES inrunner heat distribution
I flew mine off the 6s2200 battery yesterday but with a sickle rotor which gave a little less thrust than the Hoaye but only 32 amps vs 40 and it still flew with good authority. Didn't have to nurse it up and flight time was good I can see around same flight times with the Haoye fan but flying even faster.
I did the 2 inch cheater hole mod and it seems to wake it up a lilttle
erh7771 is offline Find More Posts by erh7771
Old Dec 09, 2010, 07:42 PM
Duke58's Avatar
Hayward, CA
Joined Apr 2001
Got the wing mounted today and run up the fan for a few minutes, looks like I'm getting about 1100-1200 watts at close to 80amps, that's with lead wire running all over the table through my watt meter , it sounds better hooked up direct. The Wemo fan sounds like a better way to go , I'll have to see how it flies first. With a little rigging and a canopy it could get airborne Sunday. I'll get it on the scale in the morning . ,,,,,,,,,,,,Drop Tanks or Slick???
Earl
btw Tex , I did exactly that, and yes , I do know better
Old Dec 09, 2010, 09:38 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Looking good! I'd fly it slick first then add tanks and see if you can accept the performance reduction. It looks great with the add on tanks, etc, though.
Eddie P is offline Find More Posts by Eddie P
Old Dec 10, 2010, 01:30 PM
Duke58's Avatar
Hayward, CA
Joined Apr 2001
Don't need no stinken cheater hole!!
A little tape and some spackle.............it could work!!
Old Dec 10, 2010, 10:03 PM
dccdmd is offline
Find More Posts by dccdmd
dccdmd
dccdmd's Avatar
USA, CA, San Diego
Joined Jul 2008
F-100 video
Here's a quick video I made today at Miramar with my snazzy quarter-sized camera taped to my hat... Planning to remove the bombs for some better speed...In this video, I'm not flying WOT but for a few seconds on a 6S 4900mAh lipo. Flight was about 3 1/2 minutes but used only half the packs' capacity...
F100 at Miramar (3 min 28 sec)
dccdmd is offline Find More Posts by dccdmd
Old Dec 11, 2010, 02:52 AM
Vic Arcudi is offline
Find More Posts by Vic Arcudi
B-17 freak
Vic Arcudi's Avatar
NE Italy near Aviano AB
Joined Jan 2004
Great model, whilst not a speed demon she flies very scale & doesn't seem to be struggling to stay up!
Vic Arcudi is offline Find More Posts by Vic Arcudi
Old Feb 13, 2011, 07:44 AM
rccrazee is offline
Find More Posts by rccrazee
Airshow Joe
rccrazee's Avatar
N.W. Detroit Suburbs
Joined Feb 2009
I have recently acquired one of these kits and would like to know what your I should be using for the EPO version. Any thoughts?
rccrazee is offline Find More Posts by rccrazee
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
