Temperance MI (Toledo OH area)
Joined Apr 2007
Here`s a couple of picts Boomer. Hope you can tell what`s what. I took the wing off to help cut slots for the NLG mount plates. I made 1 for each side, then cut slots. As you can see the steering servo is mounted in a recess I cut on the rt. aft side of the NLG well. The MLG was easy, just had to drill 2 new screw holes thru the metal Fly Fly Mt. plate. Hope this helps. The Old big nosed Chief
Those are the Eflite 15-25 electric retracts? Thanks for posting the pictures. What do you think of the durability?
Latest blog entry: The Gas Turbine Engine (with images)
Hi Beak, sorry to ask again but what weights are you flying at and what's your landing surface in your experience with the 15-25 Eflite's? Thanks a ton.
Joined Apr 2007
Eddie I`m flying at 6lbs 10oz I have flown off grass and hard surface. The grass was short ( about 1 1/2 in) The hard surface has been smooth to rather rough. With the exception of spring airs these are one of the sturdiest gear sets out there. Hope that helps. Here`s a pict from E-Jets Int. Me and my Hun are on the Rt. Big nose under the hat, tail # 913 on the Hun. Beak
Nice field!
Latest blog entry: I really like this video:
I went ahead and bought some 15-25 size Eflite gear, let's hope they hold up with my 8s and glassed foam airframe! The plus side is I plan to only fly off pavement. |
Joined Nov 2005
Will ~4.5pds give good scale flight or is it really underpowered? TIA |
Well,I was the other guy flying with him in that picture...mine went down hard Saturday.Total loss of airframe but all electronics survived...My receiver battery went dead in a turn and it plowed in really hard...oh well,it happens!Joe
Latest blog entry: 14 years and going strong!
Rochester, New York
Joined Jan 2006
TIA,
With my F-4 Phantom and my F-86 I had a flying weight of between 4 1/2 and 5 pounds. Here is the setup I used. Motor - Ammo 1800Kv EDF - FlyFly housing with the midi fan 5 blade rotor ESC - Castle Phoenix 80A with the CCBEC Rx - Spektrum AR7000 Tx - DX7 Li-Po - Enerland 30C 6S1P 4550mAh Watt meter results @ WOT = 65A / 23.4V / 1300W So, I'm getting about 290+/- watts per pound which gives just about 6-8 minutes of flying time with good throttle management. The flight speed is just right for me; not slow at all, but not a speed demon either. If your thrust is about 1:1, you should not have any problems. I still suggest that you hook up a watt meter and see what results you get. This is a good way to be sure of your power system. |
| Thread Tools | |
| Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· | Prop-er | Electric Ducted Fan Jet Talk | 71 | Feb 16, 2009 02:57 PM |
| Build Log - contest - Micro EDF30 F100 Super Sabre | metroidrc | Indoor and Micro Models | 119 | Feb 19, 2008 05:50 PM |
| F-100 Super Sabre | lebardemelon | Pusher Prop Jet Models | 5 | Apr 20, 2005 08:34 AM |
| F-100 Super Sabre | Tim H. | Electric Ducted Fan Jet Talk | 22 | Apr 28, 2002 08:26 AM |
| F-100 Super Sabre | Ed Couch | Electric Ducted Fan Jet Talk | 6 | Dec 30, 2001 10:12 AM |
