I agree with Dave. Plugging in a low mAh pack just to test out blade rotation should NOT fry the ESC. The only time that should happen is if you put in too many volts (or had the polarity of the wires crossed). I too have used low mAh packs to do testing (but not full motor runs).
Seems odd that Castle would say that. Pat |
Latest blog entry: Nico Hobbies
Here is the thread I posted to Castle:
http://www.rcgroups.com/forums/showthread.php?t=1227571 |
I agree with Castle's response "IF" you were doing extended motor runs at WOT. But I DON'T think it would happen as you described after only a few seconds.
Only other thing I can think of is to ensure that when you put on the extensions to the ESC, that you wired it correctly (pos to pos and neg to neg). But if it armed correctly, then that probably rules out cross wiring. Pat |
Hey Dio you still out there lurking and waiting for some decent weather? Haven't heard anything about that gorgeous bird in a few days now. |
Latest blog entry: Hobby King "SIX" hexa
I say it was the long battery leads - period.
You have 14" extentions plus the length of the esc and battery wires. Makes for one long wire. In fact anything over 12" total length should have extra capaciters installed. With the larger airplanes and systems there were a lot of failures untill some of us started installing extra caps. The problems have since almost completely disappeared. The extra caps help arrest the ripple current and protect the ESC. if the caps on the esc become polerized or damaged - it takes nothing to fry the rest of the esc. Tam had many problems as did some others with the larger Byron and yellow planes as extended batt leads are a nessecity. After installing caps - there have been no more fried esc's. A lot of people have different views on this and if you do a search - you'll be reading for days. For me - the end results speak volumes. For me - I spend $30 buck at Tam's for a plug and play solution to protect my big dollar planes. Some guys can find the proper caps and wire it themselves for a couple of bucks. I would highly recommend this fix. http://www.tamjets.com/original/prod...roducts_id=431 |
Why dident you get the HET esc to go with the rest? Im good at frying all kinds of electronics and havent done it yet with a het full package |
Here's what I'm running in mine on a HET rotor. http://www.hobbycity.com/hobbycity/s...dproduct=10015 http://www.hobbycity.com/hobbycity/s...idProduct=6526 and I didn't do the capacitors although i have heard the long wires can be a problem. |
I did not buy an HET because I had basically a new CC. Just for giggles I took a brand new Hobby King Turnigy 80A Esc and installed it to see if it would light up and to my surprise. Everything works great! Mind you I will not fly with it but at least I can hear the motor run and set the controls operate. I just love the Fly Fly electric retracts! What a great purchase!
Your 100 looks badass, I wish you much luck! |
Mike |
| Thread Tools | |
| Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· | Prop-er | Electric Ducted Fan Jet Talk | 71 | Feb 16, 2009 02:57 PM |
| Build Log - contest - Micro EDF30 F100 Super Sabre | metroidrc | Indoor and Micro Models | 119 | Feb 19, 2008 05:50 PM |
| F-100 Super Sabre | lebardemelon | Pusher Prop Jet Models | 5 | Apr 20, 2005 08:34 AM |
| F-100 Super Sabre | Tim H. | Electric Ducted Fan Jet Talk | 22 | Apr 28, 2002 08:26 AM |
| F-100 Super Sabre | Ed Couch | Electric Ducted Fan Jet Talk | 6 | Dec 30, 2001 10:12 AM |
