Old Feb 14, 2013, 06:32 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by mopetista View Post
thanks - now I know what you mean. I encountered flat head / counter sunk screws on outrunners, and there is no way you can get at them with pliers
You could always drill them out then replace with larger screws...
4stripes is offline Find More Posts by 4stripes
Old Mar 07, 2013, 05:34 PM
savvy is offline
Find More Posts by savvy
Marton, New Zealand
Joined Apr 2005
Well I've decided on a 7S setup.
I was about to order this:
Dr Mad Thrust 1200kv 3700watt 90mm EDF Inrunner 6-8s
http://www.hobbyking.com/hobbyking/s...ion_40mm_.html
And use the 90DPS fan unit because the Mad thrust won't fit into my CS 90mm fan
http://www.hobbyking.com/hobbyking/s...dproduct=28370
However I've just seen this :
Turnigy SK3 Fandrive Brushless EDF Motor - 3968-1500KV (8S 90mm EDF)
http://www.hobbyking.com/hobbyking/s...dproduct=28503
It looks like this might actually fit into my CS90mm unit. What's your thoughts on these two options for 7S? go with the cheap SK3 with CS90mm fan, or go all out with the Madthrust setup.
Help very much appreciated.
savvy is offline Find More Posts by savvy
Old Mar 07, 2013, 05:44 PM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
And another choice-
http://www.hobbyking.com/hobbyking/s...dProduct=17698
mray is offline Find More Posts by mray
Old Mar 07, 2013, 05:56 PM
savvy is offline
Marton, New Zealand
Joined Apr 2005
Originally Posted by mray View Post
I think that one is only rated for 6s though?
Old Mar 07, 2013, 06:16 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Their listed Volts spec is generally irrelevant. eg that will do 7S and even 8S fine. (too high volts/RPM on 8S in a CS12 though).
But that XK is a weaker motor than the Fandrive.
7S in a CS12 you want 1400 - 1500kv
So that Fandrive is a great choice.. and 8mm shaft, which is good too. Grab that and the CS12.... BUT get the CS12 from X-flight!!
I am getting one of those Fandrives - though also well as the two Dr Mads (1200kv and 1620kv). 1200kv for 8S, but 1620kv for 6s, all for CS12.... 1500kv I will use for 7S (or 6S maybe too) in a CS12
The Lander units are far too heavy.
Another possible fan combo is the Lander 12 blade rotor ($14) put into a CS12 housing. I have so many things here I can't remember what fits what for sure! I have to check, but I am pretty sure the Lander fits the CS12. Though I also want to run that up (if it fits ok) and be sure the power levels are ok too - some rotors don't like some housing stators.
But if you get the X-Flight CS12 it is the stronger rotor version anyway, so that would be fine as a whole unit.
Plus the Fandrive fits straight in.
PeterVRC is offline Find More Posts by PeterVRC
Old Mar 07, 2013, 06:39 PM
savvy is offline
Marton, New Zealand
Joined Apr 2005
Thanks very much, have ordered the fandrive and will stick it in the CS90 unit which I've already got.
So many things to do on my Hun but I don't want to start sticking bits together until I have the power system sorted.
Then I have an issue of batteries. Currently have:
Nano Tech 4s 4000mah 35c ~ 70c
Nano Tech 3s 2200mah 35c ~ 70c (x2)
I'm thinking about hooking the 2200's together in parallel to make a 3s 4400, then hooking that up in series to make a 7S 4000. But not sure how dodgy that might be, it seems to work when I plugged it into the watt meter.
Old Mar 07, 2013, 07:11 PM
PeterVRC is offline
Joined Nov 2006
hehe, technically would work fine, so that is ok.. But is getting all a bit clunky.
Luckily the F-100 has tons of room!
I guess that could even give you very flexible CofG placements too!
Old Apr 01, 2013, 03:51 AM
MADISONMaster is offline
Find More Posts by MADISONMaster
MADISONMaster's Avatar
France, Burgandy, Dijon
Joined Jun 2010
ARC 3675-1 with MIDI PRO EXTREME ALLOY 90mm
Originally Posted by Hussler View Post
What power will you use?
The Dionysus F100 is absolutely beautiful !!
Hello Hussler
The engine will be an ARC 3675-1 on 8S 5000 with MIDI PRO EXTREME ALLOY 90mm and Turnigy dlux OPTO HV 6~12S 120A - it done the thrust for 4.4Kg - 2903W -
- weight of my F100 will be approximately 4.7Kg ! - so 136 gr/dm2 and 275W/lbs
I have a paved runway of 270 feets - I hope it 's good !?
MADISONMaster
MADISONMaster is offline Find More Posts by MADISONMaster
Old Apr 01, 2013, 04:20 AM
PeterVRC is offline
Joined Nov 2006
Heavy! But it should actually fly great!
It has tons of lift..... it is a BIG plane for its peer group size..... you have plenty of power .... and you have the space to take-off and land it!! So it should be very good really!
Old Apr 01, 2013, 08:31 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Hello Hussler
MADISONMaster
Open up the cheater a bit and you'll feel every gram of that 4.4kg from the midi
erh7771 is offline Find More Posts by erh7771
Old Apr 01, 2013, 09:22 AM
Joined Jun 2010
Open up the cheater a bit for F100
PeterVRC Heavy! But it should actually fly great!
Thank's all
Yes i open up the cheater like this ....to avoid overheating of the engine and ESC
I do not know the fiability of the ESC TURNIGY 120HV on 8S with 100A ..... I hope it will not burn !
MADISONMaster
Old Apr 01, 2013, 06:23 PM
savvy is offline
Marton, New Zealand
Joined Apr 2005
Regarding the cheater hole. I've been thinking about filling mine up and creating a new cheater just in front of where the real gear doors are. It looks like the current cheater hole is almost filled up once the landing gear is retracted. Filling this area in would also allow for the proper front gear door setup.
I think this would make it look a bit better, the only problem is that if you install an airbrake - deploying it would in theory divert all air away from the cheater.
Not sure I've got the cajones to try this sort of tweaking though as I'm already adding lots of other bits. I guess it would require some serious testing with both options.
Will post some progress pics soon.
Old Apr 01, 2013, 07:45 PM
PeterVRC is offline
Joined Nov 2006
Airbrake down.... unlikely to need a cheater! LOL
The 'wheel blocking' one.... yes, probably on higher power systems - not sure at what crossover power point - but probably not important in lower power setups. Take-off, wheel is down and cheater is fully clear.... in flight the cheater not needed as much.
Old Apr 01, 2013, 07:51 PM
PeterVRC is offline
Joined Nov 2006
Nice ideas Savvy!!!!
Did you hinge the rudder at the radius point of the balsa 'rounding'? Pics are a bit hard to tell, but I think so.
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
