Old Nov 09, 2012, 12:28 AM
Mannyman535 is online now
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
Originally Posted by PeterVRC View Post
I would head for 7S at least. And pref 8S.
I just got a DPS 10blade 1000kv for it, to run as 8S and then 10S.
Thanks. I will look into getting one.
Mannyman535 is online now Find More Posts by Mannyman535
Old Nov 09, 2012, 01:29 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Lander specs are usually correct, so....
On 8S it will beat the 6S version still (and most typical 6S CS12's). But it still has the leeway to move up to 9S or 10S.
I am awaiting an ESC, seeeing they have none in stock....
http://www.hobbyking.com/hobbyking/s...watt_10s_.html
1st Pref: - Def prefer this one. Might wait.....
http://www.hobbyking.com/hobbyking/s...ler_OPTO_.html
2nd Pref:
http://www.hobbyking.com/hobbyking/s...hless_ESC.html
3rd Pref:
PeterVRC is offline Find More Posts by PeterVRC
Old Nov 28, 2012, 08:55 AM
Don Vanhook is offline
Find More Posts by Don Vanhook
Joined Dec 2009
flyfly F-100 build
Has anyone in the group put together the FlyFly F-100. I just purchased to plane and the instruction sheet is much to be desired. I know with my experience I can get it together, however would like some info from others who have completed the F-100 and flying it now. Thanks.
Don Vanhook is offline Find More Posts by Don Vanhook
Old Nov 28, 2012, 11:29 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
I think that almost everyone on this thread built is and flies/flew it... To me, the main thing to worry about: this plane is nose heavy to be on the right CG. Make sure you have a good opening for the battery to go as far back as possible--you may need to carve some foam to make room, and start thinking about what will you use as weight in the tail. Different people used different techniques. Just search this forum (or browse through the pictures)
ysolomon is offline Find More Posts by ysolomon
Old Dec 02, 2012, 10:31 AM
rudeboy579 is offline
Find More Posts by rudeboy579
" EMBRACE THE DARK SIDE '
rudeboy579's Avatar
Joined Nov 2011
i'm with yoram,yhe c.g is crucial with this bird,i followed what yoram sugested and added weight to the rear of the bird,earlier in the thread yoram have various pics of the builds and they really help,good luck with the buildpost some pics
rudeboy579 is offline Find More Posts by rudeboy579
Old Dec 12, 2012, 12:54 AM
edf flyer
Joined Feb 2009
I'm looking for some retracts for this bird. I prefer to have it come with the struts already.
Any ideas?
Old Dec 12, 2012, 07:08 AM
Rangerfan is online now
Find More Posts by Rangerfan
Rangerfan's Avatar
United States, TX, Grapevine
Joined Jul 2012
Any ideas?
Eflite, 25-46 size. Excellent.
Rangerfan is online now Find More Posts by Rangerfan
Site Sponsor
Old Dec 12, 2012, 03:38 PM
edf flyer
Joined Feb 2009
Thanks. But I wanted something that has struts. Like some Rc lander
Old Dec 12, 2012, 07:30 PM
Rangerfan's Avatar
Joined Jul 2012
They do include struts. 4mm struts that you cut to the desired length. I'm guessing you want shock absorption struts or oleos? May check hobby king.
Site Sponsor
Old Dec 12, 2012, 08:48 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
I would go with the E-Flite 25-46 and robart 650 all around.
Old Dec 12, 2012, 10:27 PM
PeterVRC is offline
Joined Nov 2006
Something out of this series of oleos from HobbyKing will work out... and CHEAP!! Excellent quality!
I have heaps, but have not worked out which specifically for the F-100 yet.
Offset mains, but twin wheel nose.
http://www.hobbyking.com/hobbyking/s...Class_1pc.html
Old Dec 16, 2012, 10:50 PM
gen3v8 is offline
Find More Posts by gen3v8
gen3v8's Avatar
Australia, NSW, Sydney
Joined Dec 2011
Well I finally read this whole thread So i wont be waisting anyones time.I have had the kit and parts for at least a month and will start the build in 5days"HOLIDAYS".
The power unit will be http://www.hobbyking.com/hobbyking/s...dproduct=24755
wich has been tested in a ff mirage.
gen3v8 is offline Find More Posts by gen3v8
Old Dec 16, 2012, 11:44 PM
PeterVRC is offline
Joined Nov 2006
How did that unit go?
And sound? Ref to a CS12??
Old Dec 17, 2012, 04:04 AM
gen3v8 is offline
gen3v8's Avatar
Joined Dec 2011
Are you asking me..Iknow the result
Old Dec 17, 2012, 04:31 AM
PeterVRC is offline
Joined Nov 2006
lol, that was an odd reply.....
How does the Mercury sound?
I saw a video of one in a Sabre (I think) and it sounded like a sewing machine!! The throttle response was so crisp, and there was no real fan noise (no leaf blower, but also "no whoosh") thus why it just sounded like some electric motor revving up and winding down!
It just seemed that the whole Mercury "metallic perfection" was too perfect, to even create a good jet-like sound.
But maybe you found it diffrent than that? Hopefully!
Plus what cells did you use it on, and how did it go.... speed, thrust, power?
I would ALMOST get one.....
That Mercury seems very light for what it is! So that is a good point of it.
I got this:
But have not run it yet.. still need some stuff for it.
Intended for the F-100 on 8, 9 or 10S... undecided. Though I have a lot of suited 5S batteries to pair up for 10S use.... but that might be overkill !! I really wanted a good 8S version of it, probably 1200kv.... but they have not done one yet.
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
