With the CG in front of rear landing gear,mine had a hard time rotating on takeoff.I lowered the rear 2 gears on mine ,setting a better angle of attack and this helped alot on take offs.I have a grass field so it needed all the help it could.Your mods are awsum btw!Watching and enjoying your build.
Joe
Latest blog entry: 14 years and going strong!
I imagine that flaps would help for take-off, but looking at the gear mounts it appears as though the extra ply used that now makes the gear sit higher than the surface of the wing was an afterthought when they realized the gear were not strong enough. My gear will sit lower in the wing, I'm guessing yours is stock? So I will have a better AOA on take-off. I might have room to extend the nose strut, I'll look at it when I get her on her legs. |
My buddy sure does a nice job of shooting video (I think). That's just a way of saying I finally got to maiden mine today and it even came home in one piece.
![]() Now if I just type the link right the video will be here |
Latest blog entry: Hobby King "SIX" hexa
Nice flight! Congratulations.
The landing gear looked great coming down |
Latest blog entry: I really like this video:
Bill, did it feel to you like the CG moved back when you dropped the gear? It kinda looked like the tail squatted down a bit when you dropped them. Great flight, it looks real smooth and scale like, not flightly like some of my smaller 70mm jets. It also looked like you could have even slowed her down more once you entered ground effect.
Great flight overall! Thanks for posting |
I don't think the cg moved back when the gear came down. It should stay pretty close to the same in either position. The mains go in and out sideways, the nose gear comes forward when going down. Ordinarily I'd think that would make it more nose heavy but since the steering servo moves an inch or so to the rear when down they could cancel each other out? I think the reason it balloned a little was from a wind gust that came through about the time I dropped the gear. It really wasn't what you call and ideal day for test flights. Wind was about 12-15 while it was flying but really close to down the chute. ESE on an west to east runway. Mine is probably just a touch tail heavy to "recommended" settings too. I set it to balance on my thumb tips so that I could still see the marks made in the suggested setting. (probably 1/8-3/16" behind recommended). Makes the flying stabs a little more sensitive but that makes it easier to flare on landing and rotate on take off. (I shoulda went to low rate elevator when landing).
Just as a note. If you have the Fly Fly retracts and you run into a stripped tube like I did, EJF now has them in stock. http://www.ejf.com/index.php?main_pa...roducts_id=862
I went ahead and ordered a few to keep for spares. |
Retracts for the Fly Fly F-100
I'm getting ready to push the button and order one of these but wanted to get some feedback on the retracts people are using.... Fly Fly electric or air, HET air, or spring air? This would be my first 90mm EDF.
I have seen some of the issues with the FF electrics, has the problem been resolved with these? Great thread, thank you all for the great info.
I have the HK servoless retracts and they work very good.I hope we have a decent weekend comming up,I changed out the bad Hacker ,and thanks to Probro Andy,I have a ARC 36-55-1.5 in there,I went from 900 watts on 7s to 1500 watts on 6s,and thats with worn out batteries...Should be even more fun to fly around.Not going at all for speed,just good thrust.
Joe
Joined Mar 2005
See Post 11 Tony |
| Thread Tools | |
| Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· | Prop-er | Electric Ducted Fan Jet Talk | 71 | Feb 16, 2009 02:57 PM |
| Build Log - contest - Micro EDF30 F100 Super Sabre | metroidrc | Indoor and Micro Models | 119 | Feb 19, 2008 05:50 PM |
| F-100 Super Sabre | lebardemelon | Pusher Prop Jet Models | 5 | Apr 20, 2005 08:34 AM |
| F-100 Super Sabre | Tim H. | Electric Ducted Fan Jet Talk | 22 | Apr 28, 2002 08:26 AM |
| F-100 Super Sabre | Ed Couch | Electric Ducted Fan Jet Talk | 6 | Dec 30, 2001 10:12 AM |
