Old Oct 12, 2012, 08:17 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Ha... I asked that question exactly right after I filled the "holes" originally reserved for the elevator servos... If you get the CG at 280mm from leading edge at root of wing, then the elevator neutral position is right at the center of the elevator servos. I believe that's exactly what the manual says, too. Mine lifted off the ground very nicely, and didn't require much elevator trimming that way.
ysolomon is offline Find More Posts by ysolomon
Old Oct 12, 2012, 08:55 AM
rudeboy579 is offline
Find More Posts by rudeboy579
" EMBRACE THE DARK SIDE '
rudeboy579's Avatar
Joined Nov 2011
cheers y solomon
my c.g is at 265mm
rudeboy579 is offline Find More Posts by rudeboy579
Old Oct 12, 2012, 11:18 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Several times through this thread it was recommended to move it back to 280mm. I realize it takes tail weight, but I did follow this recommendation, and the takeoff was really sweet. I would really recommend you move it back to 280mm...
Old Oct 12, 2012, 01:17 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
280mm will fly much better than 265mm. You will notice mostly during any banked turns, take off and landing.
Cheers
4stripes is online now Find More Posts by 4stripes
Old Oct 12, 2012, 05:15 PM
rudeboy579's Avatar
Joined Nov 2011
cheers guys
just saved me a scary maiden
280mm it is then
Old Oct 12, 2012, 06:34 PM
rudeboy579's Avatar
Joined Nov 2011
guna have to add weight to the tail like you ysolomon as my esc is just after the battery tray so cannot push it further
Old Oct 12, 2012, 08:45 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
StyroSpray done on the fuselage and rudder today. No doubt--I learned much from my experience with the wings. Three thin coats this time. When I did the wing, I used 10-11 fl oz of the mixture. On the entire fuselage and vertical fin I only used 4 fl oz. As a result, the only "weight gain" was 0.34 lb. No drip marks, and nothing on my hands... So I'm just at 10lb now. I will sand down a little (more on the wings), and then prime it. After priming, I will put this plane back together and re-maiden it, before I spend quality time with air brushes... Note the manual rotisserie I improvised...
Old Oct 12, 2012, 09:57 PM
rush1 is offline
Find More Posts by rush1
rush1's Avatar
United States, CA, Palmdale
Joined Mar 2011
Originally Posted by rudeboy579 View Post
hi guys
where is the neutral position for the elevators? should i go with what the manual says?
cheers
rudy
Thats where I set mine according to the manual and had to add a couple of up clicks but I'm also a little nose heavy
rush1 is offline Find More Posts by rush1
Old Oct 13, 2012, 12:59 AM
rudeboy579's Avatar
Joined Nov 2011
but what was your c.g rush?
Old Oct 13, 2012, 07:58 AM
rush1 is offline
rush1's Avatar
Joined Mar 2011
It;s at 280 from the leading edge
Old Oct 13, 2012, 08:16 AM
rudeboy579's Avatar
Joined Nov 2011
cheers rush,def putting sme weight to her tail.any sugestions where i could or should place them??
cheers
rudy
Old Oct 13, 2012, 08:37 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Rudy,
Check out my elevator servo installation: http://www.rcgroups.com/forums/showt...4#post22389368 that allowed me to carve room for the weight installation http://www.rcgroups.com/forums/showp...postcount=1856, which you want to be as aft as possible. I used steel bars I bought at the local hardware store.
Yoram.
Old Oct 15, 2012, 03:19 PM
rudeboy579's Avatar
Joined Nov 2011
Originally Posted by ysolomon View Post
Rudy,
Yoram.
cheers yoram
will do exactly like you did,how much weight did you end up adding yoram?
cheers
rudy
Old Oct 15, 2012, 03:46 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
At this point it feels like I added less than one pound of StyroSpray to the wing, and less than 0.4lb to the fuselage. However, I sanded the wing a lot, so I would guess that I ended up adding about 1lb in SS overall. I'll let you know once I measure again. I did add the lighting system, though. I still hope to be under (or close to) 10lb AUW.
But if you were asking is how much weight did I add in the tail, then I believe it was 170g total.
Old Oct 15, 2012, 04:35 PM
rudeboy579's Avatar
Joined Nov 2011
cheers
maybe i'm guna wait before spraying her,did you use the lander lighting and afterburner?that's what i'm guna use in mine,sorting that steering wheel hopefully today and i'm gud,i also needed the tail weight too
cheers yoram
rudy
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
