I bought the Styro Spray from the original manufacturer in Houston, Industrial Polymers (http://www.industrialpolymers.com/pr...st/styrospray/). You are right, it couldn't be more than 4lb in those two containers together, and I haven't used half of it... I did two coats, but they are pretty thick. I think I'm making them too thick. Either way, it is not all the added styrospray. Rudder servo, lighting system (including controllers), etc. I'm thinking that I may have added 1lb with the SS1000, and probably have another lb ahead of me...
How many bottles of each paint did you use? |
hi all!
ok so i have been lazy on the build but getting a bit done everyday,i just glued the retracts reinforcements in the wings and waiting,esc is glued in place along with the receiver and battery tray,elevator blocks and servos also glued in place,have to connect and glue the aileron servos, then next step is to start glueing the bird all together as i have already sorted out where all the wires are going through and also keeping spare wires for the afterburners going in. i still haven't got that front wheel to steer,well for the maiden it won't have a steerable nose then but i've got a slot for the servo and the lead already there too so when i get an illumination at least i won't have to worry about wires pics of the build and where i'm at so far will be uploaded soon...cheers rudy |
Weight
After finishing my f-100 I added about 9 oz just in the water putty/lightweight filler, decals and paint. My all up weight with 8s 4500 is 8 lbs 9 oz. Where I noticed the weight the most is on landing. I had to remember it will not float as well on landing in order to have good touch downs. Also all the obvious things that happen when the bird gains weight... Less vertical..... More energy used in turning.... Etc... The good thing is that it flies great and scale oh yeah and it looks great doing it.
Australia, VIC, Melbourne
Joined Nov 2006
Yep, for sure!!! If you fly it like a real plane is flown, more weight is totally fine!
And you also get flight BEHAVIOURS that mimic a real plane more realistically too. I am extremely 'physics based'... I "see" physics in motion just naturally all the time (eg anything I see 24/7).... so I don't know how many other people ever do - it seems very few. eg how you can "see weight", or weight and inertia, in any moving object, and thus tell if it is 'right' or not. Real objects (eg car, bike, plane) are obviously acting 'real', and then you can translate that into what you see a model do.... 'correct' behaviour? Or 'not correct' behaviour? 95% of models are too light... way too light... and thus do not show 'correct' behaviours across their flight envelope range. Too light can be 'made' to do some things apparently 'correctly' (eg when in smooth stable flight), but cannot do what weight/inertia makes the real plane do. I haven't finished, or flown (of course then), mine yet. But this is a BIG plane. It would need 4.0Kg PLUS to behave correctly. (at least 4.0Kg anyway). And that means BIG POWER if you also want to have the correct thrust to drive it appropriately too! But 3.0Kg thrust would be passable.... pref towards 3.5Kg. That 8.5lbs mentioned above sounds like the right area of weight if you want for this scale/size model that FLIES scale too! (Of course needs appropriate power levels too) |
I'm definitely with you on that, Peter... Besides, by the time I'm done, mine will likely weigh 10lb... My first three flights were at 8.5lb, and it really flew very scale. One of the turns in this video (see the turn left on 1:44) is so real that when I show it to people they think it's the full size plane in an air-show... Wait until I have Dionysus' paint scheme on mine... I never liked flying aerobatics (specifically 3D). You will never see me do a knife edge with a warbird...
Meanwhile--I'm sanding down the main wing, but I really like it now. It is so sturdy... Wednesday we will have "StyroSpray weather" again here, so I will paint the rest of the plane. Who know, I might be able to fly it again this weekend, and then paint it... |
![]() or did you![]()
Oh, yes I did... Post #1889. Quick link: http://www.rcgroups.com/forums/showp...postcount=1889 Best watched in HD (the camera was 720p).
Guaranteed to get you into Christmas mood... |
| Thread Tools | |
| Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· | Prop-er | Electric Ducted Fan Jet Talk | 71 | Feb 16, 2009 02:57 PM |
| Build Log - contest - Micro EDF30 F100 Super Sabre | metroidrc | Indoor and Micro Models | 119 | Feb 19, 2008 05:50 PM |
| F-100 Super Sabre | lebardemelon | Pusher Prop Jet Models | 5 | Apr 20, 2005 08:34 AM |
| F-100 Super Sabre | Tim H. | Electric Ducted Fan Jet Talk | 22 | Apr 28, 2002 08:26 AM |
| F-100 Super Sabre | Ed Couch | Electric Ducted Fan Jet Talk | 6 | Dec 30, 2001 10:12 AM |
