Old Sep 21, 2012, 03:59 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Originally Posted by chevronflyer View Post
i got the jetfan 90 v2 in this week and also the het 700-68-1500kv...
i must say this jetfan 90v2 is freaking sweet looking. shroud is done up in a nice carbon fiber and the rotor hub and blades all look very strong. i cant wait to run it up.
Where do you buy the jetfan from?
ysolomon is offline Find More Posts by ysolomon
Old Sep 21, 2012, 09:16 AM
Lithonion is offline
Find More Posts by Lithonion
Have you seen my nut?
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
http://shop.ejets.at/OShop/ViewProdu...x?OShopLANG=en
It will take the VAT off when you check out. And they will also install and balance the whole set up for a small fee if you buy a motor from them as well.
Lithonion is offline Find More Posts by Lithonion
Old Sep 21, 2012, 10:13 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Thanks!
Old Sep 22, 2012, 04:56 PM
rush1 is offline
Find More Posts by rush1
rush1's Avatar
United States, CA, Palmdale
Joined Mar 2011
Ok Guy's I weighed mine today 7.52 LB I cant believe its that heavy and thats AUW using a gens ace 5300 mah 6s battery What a tank ! For Foam.
rush1 is offline Find More Posts by rush1
Old Sep 22, 2012, 05:13 PM
rush1 is offline
rush1's Avatar
Joined Mar 2011
I almost forgot to tell you guys I had to dead stick the f100 in today I was down to my last set of 5000mah 3s and one of my packs went dead Theres nothing there to read ,I hook my cell voltage reader to it and it counts the cells and then shuts off the packs only have two flights on them ! at least I was able to get it down in one piece , drop the nose and flair at the last second so no damage
Old Sep 22, 2012, 05:59 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Well, I was about to maiden mine. Taxied up and down the runway to get it all trimmed and ready to go. In fact , as I was doing a high speed taxi, I had a bit of an "accidental maiden", when the plane went up to the air for a couple of feet. I landed it immediately and taxied out (didn't even had the canopy on so I was not ready for real flight...). However, when I was about to take the real flight, I realized that I don't have enoug power. Checked the CC200 and found that it didn't go past 850W. The ESC probably blew an FET. So, I spent the rest of the day replacing the ESC with a Suppo 200A. It works now. Hope to maiden tomorrow...
Old Sep 22, 2012, 06:39 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
The latest ones are still good for 8s 120 amps without the shrink tubing on it...at least the one I got from HK.
erh7771 is online now Find More Posts by erh7771
Old Sep 22, 2012, 06:42 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Mine runs 6S at 140A. The funny thing is that when it "accidentally" got airborne, it didn't have more than 850W. I have a 3000W power system in it...
Old Sep 22, 2012, 06:58 PM
Joined Nov 2005
Hey Sol..., get some vids of the maiden if you can.
Now that I recall when I put 2800watts through mine it was really fast and sounded REALLY good due to that front cavity giving the white noise-ish whoosh sound a lot of frequency range.
Sounded really nice...
Old Sep 22, 2012, 11:18 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
I have my camcorder and a friend with me tomorrow for a second attempt at the maiden...
Old Sep 23, 2012, 09:30 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
140A! Unless you have some expensive batteries you will not get many cycles from them at 140A.
I think your motor may also succumb to the heat generated.
4stripes is offline Find More Posts by 4stripes
Old Sep 23, 2012, 12:20 PM
rush1 is offline
rush1's Avatar
Joined Mar 2011
Yep but it's going to look awesome doing it
Old Sep 23, 2012, 12:24 PM
chevronflyer is offline
Find More Posts by chevronflyer
"Takeoffs are optional"
chevronflyer's Avatar
United States, FL, Middleburg
Joined Feb 2007
Bought mine from performance-EDF.BIZ. great fast service and he is in the USA
chevronflyer is offline Find More Posts by chevronflyer
Old Sep 23, 2012, 03:33 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Maiden done!
This morning, with clear skies and no wind, I finally got the maiden flight out of the way, followed with two additional flights. What a sweetheart in the air! This plane is simply majestic. 3 batteries (Sky Lipo 6S 5000mAh 40-80C). 3:30 minute flights, and down with 14% left in the batteries...
Now it's back on the table to get filled and covered with Styrospray, followed by a camouflage paint scheme.
FlyFly F-100 Maiden flight (and two more) at NDRCC, 9/23/2012 (6 min 9 sec)
Old Sep 23, 2012, 04:40 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Thanks for sharing Yoram!
Congratulations on your successful maiden.
If you are looking for a slightly sharper intake, Parkflyer plastics has one that fits perfectly.
I have used their products on a couple planes and am happy with the results.
Cheers Eric
http://parkflyerplastics.com/cart/in...0de20257721115
Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· Prop-er Electric Ducted Fan Jet Talk 71 Feb 16, 2009 02:57 PM
Build Log - contest - Micro EDF30 F100 Super Sabre metroidrc Scratchbuilt Indoor and Micro Models 119 Feb 19, 2008 05:50 PM
F-100 Super Sabre lebardemelon Pusher Prop Jet Models 5 Apr 20, 2005 08:34 AM
F-100 Super Sabre Tim H. Electric Ducted Fan Jet Talk 22 Apr 28, 2002 08:26 AM
F-100 Super Sabre Ed Couch Electric Ducted Fan Jet Talk 6 Dec 30, 2001 10:12 AM
