Has any body hooked the airlerons and the tail plane together mechanicly on this bird? I have an f22 that way and it flys amazing you just set the radio up as a delta ? I personaly dont think the wing would work this way given the shape of it I was just curious if any body here was crazy enough to try it ?
I've set up several planes like this - Since I use Futaba radios what I do is use an aileron to elevator slave where you have the elevators on two channels and they get a percentage of aileron slave mixed into normal elevator commands too. Tailerons work great but even better if you use ailerons also - that way the roll command on the elevators are smaller and more efficient. It will allow smaller control movements hence a more efficient method of control but it is a lot more finiky to set up. Not really a good idea for the guys just looking to fly. But for those looking to learn something new about stability and control, or to optimize a setup, it's a viable option.
Latest blog entry: The Gas Turbine Engine (with images)
edit.. double post deleted
Neat idea. I'm sure there is a way to do it relatively hassle free if you mod both canopies enough... settle on a decent attach method, some good hardware, some elbow grease..
I'll post some pictures as soon as I get it done
| Thread Tools | |
| Alert ···SCOOP···RBCkits F-100 Super Sabre···SCOOP··· | Prop-er | Electric Ducted Fan Jet Talk | 71 | Feb 16, 2009 02:57 PM |
| Build Log - contest - Micro EDF30 F100 Super Sabre | metroidrc | Indoor and Micro Models | 119 | Feb 19, 2008 05:50 PM |
| F-100 Super Sabre | lebardemelon | Pusher Prop Jet Models | 5 | Apr 20, 2005 08:34 AM |
| F-100 Super Sabre | Tim H. | Electric Ducted Fan Jet Talk | 22 | Apr 28, 2002 08:26 AM |
| F-100 Super Sabre | Ed Couch | Electric Ducted Fan Jet Talk | 6 | Dec 30, 2001 10:12 AM |
