Old Oct 11, 2009, 11:34 PM
jetblack is offline
Find More Posts by jetblack
Joined Oct 2009
Server PS to Bench PS
Hi,
I've a Compaq server supplies 226519-001.(not PC PS), they use blade style connectors for the input/output current and small 4x5 pin connector(it look like our receiver pin) for the logic and sense.
It has 6set of blade on the left with the same side panel stamp N G L, I guess its the input but why 6 instead of only 3 is needed?
on the other side there is 4set of blade and 4x5 small pin in the center.
how to make it work? which sensing wire to short to turn it on?
Lionel
jetblack is offline Find More Posts by jetblack
Old Oct 12, 2009, 07:43 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
If I'm reading that label correctly, that has a 51.4 volt output and a 5 volt output, not very useful as a bench supply, is it?
dmccormick001 is offline Find More Posts by dmccormick001
Old Oct 12, 2009, 09:47 AM
jetblack is offline
Joined Oct 2009
Right, Its not for charger, its to power servo drive for CNC mill, its my new project, once its done I'll able to machine mould for canopy, 3D profile etc.Thanks
Old Oct 16, 2009, 12:40 AM
jetblack is offline
Joined Oct 2009
Hi,
If anyone need a high voltage server PS (51.2V 57A) , please take a look at this thread below. It can be turn by a JR plug with 3 wire twisted together.
Hope this help.
Regards,
Jetblack
http://www.rcgroups.com/forums/showt...3#post13357736
Discussion Server PS pin out dirtybird Batteries and Chargers 5 Dec 04, 2008 02:39 PM
Can I use External SCSI Enclosure PS for bench DC? buzzbee DIY Electronics 3 Apr 30, 2005 02:12 PM
