Espritmodel.com Heli Air
Old Jan 28, 2013, 10:32 PM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
on a twin, you generally want 0 down and 0 right thrust. location does not matter, tho keep in mind diff thrust will be more effecitive if the motors are far out wards...
nemoskull is offline Find More Posts by nemoskull
Old Jan 29, 2013, 08:15 PM
Joined Jan 2012
thanks for input, yea I was concerned about being far enough out the wing for the diff thrust but not so far out to cause problems.Wasn't sure if there was some critical factor concerning placement, will probably place them about midway and see what happens.
Meach_in_GA is offline Find More Posts by Meach_in_GA
Old Jan 30, 2013, 07:33 PM
nemoskull's Avatar
Joined Sep 2009
mostly the problems occur for me with old brushed motors, one running better than the other. i would just say to get the same motors at the same time new. (same production run.)
maybe some one else can chine in on prop wash on the outer wings...
the tiwns work very well as a twin rudder, delete the center one. mostly cuz the prop wash.
must post pics!
Old Jan 30, 2013, 07:53 PM
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
You really want to keep them as close to the fuselage as practical. This will decrease any adverse affects of thrust mismatch for normal flight, minimize reduced roll response due to the increased outboard mass, and you will have more than sufficient turning authority with differential thrust in flight and on the ground with the motors inboard.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Jan 31, 2013, 01:38 PM
nemoskull's Avatar
Joined Sep 2009
yeah, forgot about mass. the father out the harder to roll. tho you might want that, it would help the plane resist rolling, like from the wind. but usualy thats not a very common thing to do.
Old Jan 31, 2013, 07:49 PM
Joined Jan 2012
must post pics!
Here is pic as it stands today.
Had heard that its best to place motor as close as allowable to fus., mine are about 35% out on the wing. Might make a new wing for other reasons after I give this one a go, and will prob put them in closer next time.
Using two new $6 motors from HK hoping they would match (have been using this motor on other projects and has taken a beating and has been great, currently on a Divinity 42" flying wing) if they do not match well hope to adjust using trim on diff. thrust.
Not using rudder, left the center vert stab. , might go back and add rudder later.
I've also added flaps, I wanted to try out using the 3 flap sw on my T. 9X
Still have landing gear to figure out, was waiting to see how my CG looked after intalling electronics.
Meach
Old Feb 01, 2013, 01:26 AM
nemoskull's Avatar
Joined Sep 2009
9x upgraded firmware? open9x can adjust the points for the 3 pos switch. nice. i really miss mine. got to get a new one...
looks like a nice twins. you might need some rudder, tho.
Old Feb 01, 2013, 07:52 AM
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Meach
That looks good. It should do just fine with that motor placement and no rudder. I would expect it to be very responsive to differential thrust so you might anticipate the need for a lot of expo. You also don't need a high percentage of rudder to throttle mix. On my full size twin with "normal" motor placement 35% mix is plenty for any ground or flight maneuvering.
More pictures and a flight report when you can.
Ted
Old Feb 03, 2013, 08:59 PM
Joined Jan 2012
Well here she is ready for flight except for some minor adjustments. Will fly as soon as weather permits. According to my wattmeter the two motors together are putting out in excess of 250 watts, I didn't push it to 100% but close, I don't like pushing these cheap components to their limits. AUW of plane is about 37 0z or 2.3 pounds so should have more that 100 watts/lb. so I should be able to add some cargo with no problem later like bombs, etc.
I'm anxious to see how my home made landing gear works out.
Old Feb 05, 2013, 09:21 PM
Joined Jan 2012
Flight Update
Was able to get out and fly today, hope to get out again tomorrow. Didn't get any video as I was alone, perhaps someone else available tomorrow to film.
Plane flew great, plenty of power, most of the flight today was only 25% of throttle or so. Takes off great but wants to fly to the left during sustained flight, tried doing some trimming today but going to work on it again tomorrow. Had a problem with front landing gear where I was using some wire which didn't hold up, made the front like the rear which worked great (see new front in photos). Didn't help that during one landing I landed on the curb along the parking lot where we fly, I don't have a lot of experience landing (several of the planes I have built were without landing gear, gliders, wings, etc.)
Flaps also worked great using the 3 position flap switch on the 9X. The main wing has a 7" cord with an additional 2" for ailerons & flaps.
My horizontal stabilzer may need some bracing, it flexes as rudder moves.
Meach
Old Feb 06, 2013, 08:12 AM
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Some day I will build an elevon twin pusher based on this general boxy design. I swear I will
BrownEyedFool is offline Find More Posts by BrownEyedFool
Old Feb 06, 2013, 05:42 PM
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
M ake it look like a Beechcraft Starship wida canard on the front.
alpea 41 is offline Find More Posts by alpea 41
Old Feb 06, 2013, 07:18 PM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Beech Starship
It would be a big stretch to transform the Cargo Twin into a Starship. I wished someone would come out with a reasonably priced model of the Beechcraft Starship. It is one my all time favorite designs.
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Feb 06, 2013, 08:07 PM
alpea 41's Avatar
Joined Oct 2007
There's only a few still flying . And if your not the guy I already told . I was lucky enough to see one of em climbing out from a departure outta John Wayne Air Port O C Ca. In Nov last year.
Old Feb 07, 2013, 08:24 AM
Joined Sep 2011
Kind of a starship but not that stretched beauty. Eagle 5 is what I've been quietly mulling in my head for months.
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
