Old Jan 17, 2013, 11:13 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
okay, bravogulf, the plane heard you. it did not come back.
well what happened was it flies real nice like, but gets a nose up/waaay to much up elevator (not my doing). it did this a few time and the last time it did not recover. did a very nice half loop into the ground.
all in all, it was a very nice plane. i think the elevator linkage came undone.
got to build another one. the oversized wing was great!
right now im building a glider to tow behind it.
nemoskull is offline Find More Posts by nemoskull
Old Jan 17, 2013, 12:28 PM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
I applaud your work, I think you did a fine job.
Would love to see one in action some day.
BG
BravoGolf is offline Find More Posts by BravoGolf
Old Jan 17, 2013, 05:48 PM
nemoskull's Avatar
Joined Sep 2009
i got a 50% fuse hanging, i think im going to finshed it the same low wing. 1S, will need more than 2 motors, tho!
i think a 5 inch chord, 30 inc span should look good.
Old Jan 18, 2013, 08:16 AM
aero1960 is offline
Find More Posts by aero1960
Joined Sep 2010
This is my version of FT twin used to launch a shuttle. Noticed I redesigned the tail so that I can use it with ducted fan wing given it a "2fer1" transport. Only bad feature I found is the main gear is not wide enough to prevent tipping over when it is windy or gusty.
Built another transport based on FT having a swing wing to investigate STOL capabilities. That is a lot of fun to play with.
Rc Space Shuttle Launch (2 min 41 sec)
aero1960 is offline Find More Posts by aero1960
Old Jan 18, 2013, 08:39 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Great flights and Vid editing !
I especially like the T-Tail / Starlifter treatment.
Bob
Hoosier Cutout Service
birdofplay is offline Find More Posts by birdofplay
Old Jan 18, 2013, 09:29 AM
BravoGolf's Avatar
Joined Oct 2010
twins cargo shuttle lift
Bob
+1
I really enjoyed that. I was thinking c-17esque, at any rate the t-tail looked great!
BG
Old Jan 18, 2013, 10:38 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I've looked around the different threads and the use of counter rotating props doesn't seem to be something that is required. I'm wondering if having the props turn opposite each other is a requirement? Can they turn the same?
Tom
carr52 is offline Find More Posts by carr52
Old Jan 18, 2013, 11:57 AM
nemoskull's Avatar
Joined Sep 2009
counter rotating props (contra?) is mostly for torque roll and single engine flight. having a single prop rotate (one a twin with only one engine) a certain way helps to counter act the adverse roll when flying single engine and lets you have a greater power setting. (at least on the full scale planes)
many planes did not have this. IIRC british P-38 had same rotation, while american had counter rotation props. the Mossie had same rotation.
back to the twins...
the bigger ones seem to not need it.
i built a DD 25% with twin 44mm props with waaay over powered motors (1:1 or close) and i did have some torque roll, not bad, but noticable. this was a verry light plane, very small. other than that, ive never needed counter rotation, tho i have used it many times and many times without and it seems to me, at least at the 35% scale, to not need it.
i talk too much.
Old Jan 18, 2013, 12:19 PM
aero1960 is offline
Joined Sep 2010
Bob
The video was done by a member of our club whose does this for a living.
The T-tail was incorporated to duplicate the YC-14 turbofan that they experimented with. Here is the way I set this up.
Old Jan 18, 2013, 12:41 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
You mean like this one - taken at PIMA air museum in Tuscon ?
Old Jan 19, 2013, 08:36 AM
aero1960 is offline
Joined Sep 2010
Yes. My transport is a scratch built and is a cross between FT and Mikey's. This is an earlier picture of the set up using 64mm EDF's.
Only problem with T-Tail is you have to gather speed before it comes alive.
Old Jan 19, 2013, 09:03 AM
v22chap is offline
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
Aero 1960
Great job on the starlifter and shuttle ... I and another club member did one with balsa planes back in the early 90's ... We did the same shuttle lift off nose high the first few times and soon found out that it was better to let the mother ship go into a slight dive and then release the shuttle in a slight dive worked better so as not to stall out the shuttle right over the mother plane . Our heavy balsa shuttle could only make a 90 degree turn from 200 feet up and then it was pretty much time to land ... can anyone say flying brick
v22chap is offline Find More Posts by v22chap
Old Jan 20, 2013, 05:54 AM
WarbirdFan66 is offline
Find More Posts by WarbirdFan66
WarbirdFan66's Avatar
Germany, Berlin
Joined Feb 2012
...cool thing
Originally Posted by nemoskull View Post
on a happier note, i got my low wing twins done. ugly as sin, basher plane.
maiden tonight i hope!
edit: AUW is 69 grams, 5 lighter than the Pz mosquito, LOL. i built a piece of crap and its still lighter than the parkzone plane!
It might needs some refinement but it looks cool...a little bit of paint and you build yourself a very cool cargo version...nice work man
WarbirdFan66 is offline Find More Posts by WarbirdFan66
Old Jan 20, 2013, 12:22 PM
keoki47 is offline
Find More Posts by keoki47
keoki47's Avatar
United States, WA, Puyallup
Joined Jun 2011
Some landings
So this is my first flight since my first big crash! plane turned out better this time 2nd scratch ever. I redid my battery box to allow the use of 2x 5000mah 45c 3s batteries. close to 6 lbs this time lol flys very nice, slow flight is way cool high alfa flight is ok likes to wagg the wings. one vid has some flybys next has a landing and a very steep pull out.
twins landing (0 min 55 sec)
twins flyby (0 min 55 sec)
keoki47 is offline Find More Posts by keoki47
Old Jan 20, 2013, 02:25 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Ahhh, nothing reminds me of the NW more than a nasty man eating Blackberry lined road !
Nice landing BTW :-)
Bob
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
