Old Oct 28, 2012, 07:27 PM
Hasse.69 is offline
Find More Posts by Hasse.69
Hasse.69's Avatar
Sweden, Östergötland County, Linköping
Joined Jun 2011
In post #82 the answer is:
Originally Posted by Sailor Jerry
foam and tape, four quick questions:
1. What size are your props?
2. What battery are you using?
3. How much does that R/C tank weigh?
4. Where is your C/G?
larryross, thanks for creating and posting plans. I printed everything out and will start building as soon as my depron shows up.
the props are GWS 8060 SF
the battery is an 800-1300 mah 3S
the tank weighs about 6 oz
the CG is about 1/4 or 1/3 of the wing length, it usually changes as diffrent battery/cargo is loaded It dosen't seem to notice the changes.
Best regards , Hasse
Hasse.69 is offline Find More Posts by Hasse.69
Old Oct 29, 2012, 03:10 AM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
130%
Originally Posted by birdofplay View Post
Ya just cant please all the people all the time.
At least not without lots of options !
It's a great design that works at LOTS of different sizes.
Don't forget about the Larger sizes too 125% 150% 200% ...
Bob, hope your move went well.
Any interest at this time in exploring the possibility of doing a Twins Cargo 130% template in see temp?
BravoGolf is offline Find More Posts by BravoGolf
Old Oct 29, 2012, 06:34 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
The move is stalled as CLOSING is not until Nov 9.
Then I will have to get all my stuff organized in the house and shop.
I am still hoping for an Early Dec start up ( assuming everything traveled well.)
I have now spent 4 days driving across country
and the balance with 4 and 8 yr old grand kids.
SO , ummm , Refresh my memory ... Where do I get this template material ?
Bob
Hoosier Cutout SERVICE
and a bit later ...
OK I found it at seetemp.com !
I will still need to TEST the stuff for machineability.
My CNC is Router based Not Naser and it'll all depend on Speeds and Feeds.
Routers tend to melt some plastics rather than cut.
The result is a build up on the bit and loss of accuracy as the kerf grows.
I could just do an Ink or FINE permanent marker pass.
Or, spring some bucks for a swivel type Knife like some vinyl cutters use.
Or, I could just cut foam and you could make your own template from them
before putting the parts together.
Seriously If you are going into production with the templates I could
let you have a qty deal as an alternative to all the cutting labor.
Bob
Hoosier Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Oct 30, 2012, 05:01 PM
kees1991 is offline
Find More Posts by kees1991
Joined Oct 2012
Wel, my Twins was ready for her first fly... but it fell down like a brick :S Good thing I only dropped it from 20 cm from the ground, so nothing has broken
Still problem is my plane won't fly..
At the moment my plane lie by a friend, so I can see what kint of electric is in it, and what it weights. But I guess it is around 0.85 KG,I guess i have a 800-1300 lipo with 3 cells, 2 speedcontrolers and 2 brushless motors. I don't know what type and other details around te motors, only thing I know the are orange and they dond make my plane fly.
I don't know or it makes any difference.. but the motors and de speedcontroles were meant for a quadrocopter, so does that explain why my airplane didn't take ar?
the stupid idiot I am,I already ordered new motors before vigerend oud what kind of sc and battery I have, and or these motors will work on my plain.
So the new motors are from TurboJet and there are blue
C2822 Brushless Outrunner Airplane Motor 1400kv
Kv(rmp/v): 1400
Power(W): 160
Wire Winds: 25
Resistance: 352
Idle Current(A): 0.7
ESC(A): 15
Cells Ni-Cd/Ni-MH: 6-12
Cells Li-Po: 2-3
Prop: 7.5x3.5/8x4/9x5
Shaft diameter/mm: 3.175mm
L/mm: 23mm
Weight: 35g
and this is the prop I use
http://www.hobbyking.com/hobbyking/s...idProduct=5247
and of course there will be two of its. Wil this make my Twing fly?
kees1991 is offline Find More Posts by kees1991
Old Oct 30, 2012, 05:45 PM
maurice076 is offline
Find More Posts by maurice076
maurice076's Avatar
United States, MI, Warren
Joined Aug 2011
http://www.hobbyking.com/hobbyking/s...tor_shaft.html
You might want to order two of these to mount the props.
maurice076 is offline Find More Posts by maurice076
Old Nov 07, 2012, 03:28 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
FWIW, I use SeeTemp all the time for paint masks. Cuts just fine on my CNC router. I use a 1/16" fishtail bit. Router is fixed around 15K RPM. Feed rate is around 75ipm if I remember correctly. I'm sure I could tweak it, but it cut so darned well on the first try, I didn't changer anything. Point is, it isn't critical.
I do use a sheet of FFF as a spoiler board. Spray mount the SeeTemp to the spoiler board, ( I use a mist coat of Elmer's spray glue) and you don't need tabs when cutting the SeeTemp. Really nice when using as paint masks as no matter how neat you try to be cutting out the tabs, they show up in the paint job.
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 08, 2012, 07:45 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
rcav8r2: thanx for the Speeds and Feeds !
I have a custom adjustable Vac table , so no problems holding the stuff down.
Any clues as to "WHAT" See temp actually is ?
I'd sooner buy it in 4x8 sheets from a plastics supplier, now that I am back in the Midwest.
BTW: Home CLOSING Tomorrow and Moving this weekend. wheew, seems like forever
yet it's only been since mid Sept.
L8r
Bob
Old Nov 08, 2012, 08:55 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Not exactly sure, but it sure does remind me what we used to use as a back drop when filming product for TV commercials. It is frosted on one side (no glare when filming, or when laying over plans to make templates) and shiny on the other. That was so long ago I forget what it was called. We used to get it in big rolls and came in different colors and opacity. The long dimension of SeeTemp was about the width of the roll. We mostly used the clear as we lit through it for more even lighting. Also built giant light boxes for filming larger products.... Tents for Sears comes to mind as one of the larger boxes we built.
Maybe check with a photography studio, or TV studio?
Old Nov 08, 2012, 11:51 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Thanx rcav8r.
I'll check Laird or just surf for it.
On the other hand ...
I seems to me that
1. the thinner, more scribe and snap type of plastic is good for modelers who wish to make their own template. AKA seetemp
2. a thicker more resilient/tougher material might be better choice for a CNC template making operation.
End users would get a better more long lasting product.
Noting the ~.1" thick templates that draftsmen "used" to use. Of course those were molded.
Acrylic, polyester, mylar plastics all seem to be indicated from my searching to date.
Frosting is NOT necessary IMHO.
I would consider colored clear material as a compromise to the frosting.
Discussion ???
L8r
Bob
Old Nov 12, 2012, 03:12 AM
Blady Ady is offline
Find More Posts by Blady Ady
Joined Jun 2012
Hi Guys
I am eagerly awaiting the maiden flight of 'Magnus', my cargo plane.
I would like to thank Foam & Tape for a brilliant design. I have really enjoyed the build and hope he flies as well as all the others!
Here is a picture. What do you all think?
Blady Ady is offline Find More Posts by Blady Ady
Old Nov 12, 2012, 03:30 AM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
It looks just like the rest of them........AWESOME
foam and tape is offline Find More Posts by foam and tape
Old Nov 12, 2012, 08:43 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
+1 on that awesome. Great job.
Tom
carr52 is offline Find More Posts by carr52
Old Nov 12, 2012, 10:08 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
T
I seems to me that
Discussion ???
L8r
Bob
FWIW, templates that I made with SeeTEmp (the old fashion way with an Xacto ) have held up rather well. One of the first sets was for an RCM Hooker (Great flying plane BTW) and they must have built at least 10 planes in their life time. When I got them back a few years ago, they are still in great shape, and don't really show any signs of wear. The plans on the other hand are a different story...
Anything thicker (more ridged?) may be harder to roll to put in a mailing tube (cutting down shipping cost) The SeeTemp will roll nice and tight, and only have a slight curl after taking out of the tube. Certainly not enough to worry about when using them. I store the templates rolled up with the plans in a mailing tube with no problems.
Just my $0.02
Dave
Old Nov 12, 2012, 09:24 PM
BravoGolf's Avatar
Joined Oct 2010
Great looking Twins Cargo
Originally Posted by Blady Ady View Post
Hi Guys
I think it looks great, nice job! flight videos with landings and takeoffs are always welcome.
BG
Old Nov 12, 2012, 10:17 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
I forgot to ask. Do you have counter rotating props? Or are they both turning the same direction?
Tom
I've got a pair of these just waiting for a giant build.
http://www.headsuprc.com/servlet/the...h-10%29/Detail
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
