Old Sep 17, 2012, 04:42 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
I think that's funny.
alpea 41 is offline Find More Posts by alpea 41
Old Sep 17, 2012, 05:44 PM
CorruptDB is offline
Find More Posts by CorruptDB
Joined Mar 2012
Coro works OK
I just finished making a Twins-like plane and Coroplast is an integral part of my design. For most of the plane I used $tree foamboard. The nose is 2mm coro with foam on the outside, the wing wrap is also 2mm coro and I also used it internally for formers/spacers/shelves. There are also a couple of 4mm pieces used in the motor mount. Overall, I think you could probably build this design with 2mm but 4mm would probably be heavy enough that you would need to put on bigger motors and you would have higher wing loading. This is my first foamie (I have built several coro planes) and old habits die hard!
CorruptDB is offline Find More Posts by CorruptDB
Old Sep 17, 2012, 06:15 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Originally Posted by snipeworm View Post
I agree, but how majestic would it be to see the plane head in full throttle into a mound of dirt!
or use it for .410 bird gun practice... can I say that?
greedyg76 is offline Find More Posts by greedyg76
Old Sep 17, 2012, 08:03 PM
Irish Steve is offline
Find More Posts by Irish Steve
Irish Steve's Avatar
Ireland, Meath, Ashbourne
Joined Jul 2010
Corro works OK, that's great
Perfect in that I can get 2 mm here, and the largest is 10mm, with several sizes between, and I reckon that in parts of the twins, it will be helpful with rigidity, especially if I decide to go for the 250% machine, which is sorely tempting, as I could then use it as a glider launch platform for an old Cirrus that I have here and would like to get some airtime on.
Thanks for the feedback
Irish Steve is offline Find More Posts by Irish Steve
Old Sep 17, 2012, 08:33 PM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
Trap or Skeet.... Pull ,,,, Bang, gotchya. We've shot full auto air soft at a Stryker before it was a fun time.
Old Sep 17, 2012, 09:04 PM
atari7up is offline
Find More Posts by atari7up
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
Originally Posted by carr52 View Post
The wires on the esc that go to the Rx are brown tan yellow. They don't always have a red wire. When I get home I'll check and see what my esc's have. On the road at the moment. And yep I hate being on the road. All my toys are at home.
Tom
you can make sure it with mutitester...the wires must have bec (+5v)
atari
atari7up is offline Find More Posts by atari7up
Old Sep 17, 2012, 11:01 PM
keoki47 is offline
Find More Posts by keoki47
keoki47's Avatar
United States, WA, Puyallup
Joined Jun 2011
vid
The twins maiden (1 min 12 sec)
specs
4.7 lbs wet
100% build kmf2 airfoil
4x hk 9g servos and one hitec hs85 for elevator
4x hk blue 30 amp esc
2x aeo counter rotating motors
4x 8x4.5x3 gws props 650ish total watts @ wot
5000mah 40c lipo
does not like to climb and requires wot most of the flight or she becomes a brick
going with 2 eflite power 25 1250kv motors and 10x8 props a bit over kill but i dont want to have to do it again..
keoki47 is offline Find More Posts by keoki47
Old Sep 18, 2012, 12:20 AM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
Watch out for what they call diminising returns . As the weight gets higher the bigger motors become anchors dragging it back to Earth. I would think the popular park jet motors 22-12 06 2200Kv would do the job . But they only reccomend 6X4 props.... I don't know, What do you think Bob?
Old Sep 18, 2012, 07:05 AM
pecanpatch is offline
Find More Posts by pecanpatch
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Originally Posted by keoki47 View Post
http://www.youtube.com/watch?v=fljoAE7HU4s&feature=plcp
I found the effiecency on these props was pathetic. Put some apc 9 X 3.8'S on it and you will get 30-40% MORE POWER
pecanpatch is offline Find More Posts by pecanpatch
Latest blog entry: 6th Annual South Eastern FPV...
Old Sep 18, 2012, 09:01 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Poor efficiency props are deffinately a buzz killer :-)
I tend to agree with ALPEA re Diminishing returns with foamys.
Larger sizes tend to negate the whole reason for going foam, except cost.
Size => weight => power => more weight => cost ...
not that larger cant be done it's just going to be a different animal.
4.7# at that size is an accomplishment ! IMHO
Take a look at the Giant Foamys that Otto Diefenbach has been making.
They are all powered by BIG Scorpions and fly gracefully smooth and majestic.
ie YF-22, F15, Pitts, H1 ...
Bob
birdofplay is offline Find More Posts by birdofplay
Old Sep 18, 2012, 08:56 PM
keoki47 is offline
keoki47's Avatar
Joined Jun 2011
props
i agree cost is high with this setup but the time spent makes it worth wile! anoth 4 oz isnt gonna change much it flew nice and smooth just very little power i was wot just to keep her afloat. and the counter rotating setup wont alow a 2 blade prop due to the spinner
Old Sep 22, 2012, 11:47 PM
yendor is offline
Find More Posts by yendor
wheeler hts nsw australia
Joined Jan 2010
cargo seaplane
Thought i would post a pic of my 75% cargo. been modified a little, flys great off water but inverted is no good. Flys very scale like ,my favourite so far.
yendor is offline Find More Posts by yendor
Old Sep 23, 2012, 12:07 AM
snipeworm is offline
Find More Posts by snipeworm
Snipe the Skies!
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
Thats a pretty bird! I have always liked the idea of landing and taking off on water but lack the nerve. Have any video?
snipeworm is offline Find More Posts by snipeworm
Old Sep 23, 2012, 12:31 AM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I have two of these
http://www.headsuprc.com/servlet/the...h-10%29/Detail
And two of these
http://www.headsuprc.com/servlet/the...SC-with/Detail
Now to figure out what kind of twin I can build with them.
Tom
Also have a couple of these.
http://www.headsuprc.com/servlet/the...ushless/Detail
carr52 is offline Find More Posts by carr52
Old Sep 23, 2012, 12:37 AM
yendor is offline
Joined Jan 2010
Will see if i can do that next time i go to the lake ,just recieved a cheap $12 vid cam from hobbyking . Not counting on good quality but thought i would give it a go .
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
