Old Sep 12, 2012, 12:15 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
mine was geared parkzone P51 motors. 5:1 gearing, 1S drawing 1.5 A (est.) AUW was 80 grams
nemoskull is offline Find More Posts by nemoskull
Old Sep 13, 2012, 09:41 AM
galanoulis is offline
Find More Posts by galanoulis
Greece, Attica, Athens
Joined Oct 2011
Almost done with the assembly of the aeroplane, but I have problem to synchronize the two motor (TowerPro BM2410-9T). I reset the Ecs but the one motors runs faster (both motors & Ecs are brand new).
They start together but in half throttle you can understand the difference.
galanoulis is offline Find More Posts by galanoulis
Old Sep 13, 2012, 10:01 AM
atari7up is offline
Find More Posts by atari7up
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
Try to calibrate the esc thortle range...hope that help the problem.
atari
atari7up is offline Find More Posts by atari7up
Old Sep 13, 2012, 11:34 AM
Drezed is offline
Find More Posts by Drezed
Drezed's Avatar
United States, VA, Spotsylvania
Joined Jun 2009
atari
and be sure to do them one at a time (disconnect one ESC, do the throttle calibration on the remaining ESC, then repeat for the second ESC).
Good luck,
Jeff
Drezed is offline Find More Posts by Drezed
Old Sep 13, 2012, 12:49 PM
Joined Oct 2011
First I reseted both Ecs and then calibrated each one. Then i made the mix throttle to Aux1 100%. The right motor starts first and the left motor second,
I synchronize them with the offset Dx7 menu option and the two motors start together (maybe this is my mistake ).
Old Sep 13, 2012, 01:13 PM
Joined Oct 2011
Yeap with offset 0 the right motor starts first (connected to throttle) the left starts second connected to Aux1), now it is better. Tomorrow I will borrow a blade tachometer from my friend to be sure that I have almost the same rpm in both motors.
Also I will try with Y connection to see the difference.
Old Sep 13, 2012, 02:36 PM
mrgizmo is offline
Find More Posts by mrgizmo
Joined Sep 2012
Most updated plans for the twins
Just wondering which page has the most updated plans for the twins 100% scale
Just starting building foamies and i'm totally addicted, built 3 allready and one on the go (waiting on cf) I'm in Canada so I've been making due with foamboard and extra reinforcement.
mrgizmo is offline Find More Posts by mrgizmo
Old Sep 16, 2012, 06:17 PM
fathergoat is offline
Find More Posts by fathergoat
How do I land this thing?
fathergoat's Avatar
United States, IN, Warsaw
Joined Feb 2012
I tested my twins with the L3010C. It has tons of power and flies fast. I've also tested it with a few pounds of candy on board. It flies a little sluggish loaded but it handles the load fine.
The Twins Cargo plane Turnigy L3010C (4 min 55 sec)
the little mishap at the end was me losing a prop. I guess lock nuts would be a good idea. the plane survived just fine.
fathergoat is offline Find More Posts by fathergoat
Old Sep 16, 2012, 06:37 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Told ya :-) !!!
I hope you built the wing strong.
Bob
birdofplay is offline Find More Posts by birdofplay
Old Sep 16, 2012, 07:09 PM
fathergoat's Avatar
Joined Feb 2012
I've got an armin wing with carbon fiber spar, zip tied to two carbon fiber rods attached to 1/4" ply gorilla glued to the fuse. I pulled some serous G's with it today, but wouldn't try that with a payload.
Old Sep 16, 2012, 10:31 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Heavy Duty Bomber, nice :-)))
I never bought into the flimsier approach.
Old Sep 16, 2012, 11:02 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I finally found this thread and how to do twin motors. Happy days. So all I have to do to run twin motor setup is to disconnect the red wire on one of the esc's. Is that right?
Tom
Forgot to ask about the batteries. Do I use two smaller batteries instead of a larger one? Hooked to the two esc's.
carr52 is offline Find More Posts by carr52
Old Sep 16, 2012, 11:17 PM
atari7up is offline
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
Tom
100% Right
i used one 2200 mAh in paralel for both of them.....about 10 minutes flight.
atari
Old Sep 17, 2012, 05:00 AM
atari7up is offline
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
My Twin Cargo get onboard video using HK HD Camera , put it on the top off Ruder.....the video had resize before upload to youtube...got a bad internet connection here...
Rc Twin Cargo Aerial Video.wmv (5 min 50 sec)
Old Sep 17, 2012, 05:24 AM
fathergoat's Avatar
Joined Feb 2012
yeah that wing is like a baseball bat
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
