Old Aug 19, 2012, 12:49 PM
BravoGolf is online now
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
Congrats Birdofplay
Birdofplay, congrats on selling the house, I remember seeing the ad for it when viewing your site, I know its been for sale for quite some time it seems. Good luck with the move to IN!
Also...
I'm not sure if I pm'ed you about this or not....are you willing or able to cnc templates of either the 100% version or a scaled up 130% version of the twins, maybe even a 150% version? I'm thinking with the STTTBP material. Thats See Temp Transparent Template Building Plastic from RCFOAM.COM.
I scaled up 100% version to 130% and had printed out at repographics place, but not real satisfied with having to compensate, make adjustments for the "foam thickness" dims that scaled up as well. Anyway not real thrilled about committing the dims that are off to my template material. Looking for a more precise solution. Thanks for your input.
@ s_mack, welcome to the twins cargo thread, it's curiously addicting. BTW: I'm really looking forward to getting my SmartieParts board into my 9X.
BravoGolf is online now Find More Posts by BravoGolf
Old Aug 19, 2012, 12:58 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
BG: I have given that some thought but never tried it.
Template materials are solid plastic and I HAVE had some issued with some plastics
tending to slightly melt and then build up on my router bits and as
a consequence ruining the part as the bit essentially GROWS in size.
I had that happen with Rtech type foams with low temp plastic skins.
The foam cut ok but the skins made a mess!
I remove the easy peel off skin on Pink and Blue 1/2 foams 1st B4 cutting
Since I am Fast Forward Mode I'd better leave that experiment until I get resettled.
Bob
birdofplay is online now Find More Posts by birdofplay
Old Aug 19, 2012, 01:48 PM
BravoGolf's Avatar
Joined Oct 2010
twins cargo templates
Bob
Thanks for the heads up, I suspected that may be the case with a move coming up and all.
BG
Old Aug 25, 2012, 11:08 AM
kkmalu is offline
Find More Posts by kkmalu
United States, MA, Lowell
Joined Jun 2012
Prop question
Hey guys,
This is my power setup:
2x hextronic 1300KV 24g motor (originally recommended by F&T)
1x 1500mah 3S battery
2x HobbyKing 12A BlueSeries Brushless Speed Controller
I was wondering what props (size, 2 or 3 blade, GWS or APC) would you guys recommend to get maximum performance out of this motor while still keeping all my electronics cool?
Can somebody also tell me how much thrust and amps are you guys getting out of this motor with your prop recommendation?
Thanks in advance
kkmalu is offline Find More Posts by kkmalu
Old Aug 25, 2012, 12:02 PM
Drezed is offline
Find More Posts by Drezed
Drezed's Avatar
United States, VA, Spotsylvania
Joined Jun 2009
Originally Posted by kkmalu View Post
Hey guys,
Thanks in advance
I pull 10-12 amps per motor, static with the same setup. I'm currently using GWS EP9050 props (I've tried the GWS 8x6 slow fly props, but they consume a couple of more amps). As for thrust, on a good battery (I'm using 1300mah 30-40C batteries), and cool air, my 850gram plane can climb(slowly) from a hover.
Jeff
Drezed is offline Find More Posts by Drezed
Old Aug 27, 2012, 12:27 PM
kkmalu is offline
Joined Jun 2012
Jeff
Thanks Jeff. But isn't the motor's max amp capacity 7.5amp? If it goes above that wont the motor be damaged?
Old Aug 27, 2012, 02:53 PM
Drezed is offline
Drezed's Avatar
Joined Jun 2009
I think 7-10 amps is safe(assuming you only run wide open for <10sec), and those figures are for static amps. The "true" running amps will drop when flying. I can say for sure that after a couple of dozen flights I've had no issues, but if you are concerned, a 8x4 may get you where you want.
Jeff
Old Aug 27, 2012, 07:39 PM
fathergoat is offline
Find More Posts by fathergoat
How do I land this thing?
fathergoat's Avatar
United States, IN, Warsaw
Joined Feb 2012
recall that my wing has ribs, is sheeted on the bottom, has a full length Center spar,
has a plywood cover in the center for the hold down screws to "work On"
and I usually fly with a 3000 3s pak :-)))
And it's still more like a trainer than most birds let alone twins !
I have the Differential thrust Switched so I can use it or not.
Like for steering on the ground and when I want to do Hammer heads !
Go with the Flow.
Let the Force be WITH you.
Be creative
Do it your own way
.................yada yada blah blah blah
L8r
Bob
I'm going to switch to the Turnigy L3010C in the hope of carrying a heavier payload. On my current config 20oz is my payload limit. I was wondering about the 3000mah batteries you are using.
Are you using one for both motors?
What kind of flight times are you getting?
What brand and C are they?
I figure there's no sense repeating what someone has already learned. I'm preparing for a large candy drop and will be building two more to go with. I also saw in one of your posts that you will(or may did) be moving to Indiana. I'm curious as to which city, but regardless welcome to the hoosier state.
fathergoat is offline Find More Posts by fathergoat
Old Aug 27, 2012, 11:22 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
a LITTEL HARD TO READ IN THE NACELLS
but Mine are 3010e I believe.
I was using a 3000mah Turnigy Blue not nano, but I always thought that a 4000 would be better.
I just could NOT get it to balance , @ 4000, with the current equipment placement.
Even with all that weight it would practically JUMP off the runway.
I never tested payload max as my runway was almost always lousy !
Depending on how hard it was flown doing POWER nose ups zooms and hover attempts
it could be flown easy with lots of touch and goes. for maybe 8-10 minutes.
Recall that My fuse got trashed and all I have now is the Wing.
It'll get rebuilt AFTER I get settled in Indianapolis.
Probably the SE quadrant SE of the city between 65 and 74 sorta kinda there abouts !
I worked in Elkhart until '02, retired, moved to WA state and then along came the grand kids.
I'm going back for them, mostly.
Old Aug 28, 2012, 06:49 AM
lennyboy is online now
Find More Posts by lennyboy
lennyboy's Avatar
Joined Oct 2009
Hey,
Is that Elkhart,wis. or Ind. I m close to Wis one maybe17 miles..
Small world welcome back anyways,,
Later,
Lenny
lennyboy is online now Find More Posts by lennyboy
Old Aug 28, 2012, 09:08 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Lenny,
I lived in Mich just across the border from Elkhart , Ind.
Worked in Elkhart too.
Check out my new morphing Logo
www.balsabuddies.com
Bob
Old Aug 28, 2012, 10:47 AM
lennyboy's Avatar
Joined Oct 2009
Lenny,
Bob
Jezzz,Bob,
Nice set-up ya got there..
Great selection and quality work..
Hard to find that around here.
I have a liking of some u don't have listed..
Like ,,,the Polaris, Polarcat, sr-71 blckbird{RCpowers} version, the NASA Shuttle,..
There are tons of them out there just waiting for some kinda glue,,he he !!
The latest I Noticed last night was that slow fly Bipe...
Some guy has started to go with it but just at Headsuprc .com//
go take a look at,,,,,,,,,,
www.slow bipe.com
I don't see any infridgement rights but he did say he didn't want to share the drawings.
Of course that wouldn't stop many reverse engineers out there..lolo
Well were close neighbors and I hope your move goes well..
rudder-up and wings level ,,
Till later,
Lenny
Old Aug 28, 2012, 02:52 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I am NOT into cutting OTHER designs unless I have permission.
Everything that I DO offer is OKY DOKY with the designers.
I was turned down on the Polaris, right off the bat.
I presume that similar designs are off the table too.
crxmanpat or Pat is doing the sr-71 although I do have a 125% version for myself.
My recent mod of Jim Waggoners' F-15 for Slide on Ground is available.
I like it and just flew it again this am ! :-)
That super slow Bip is another proprietary design.
I saw it at the Monroe Swap in WA state a couple of yrs ago.
Then it was on there site for a while then I saw it at HURC.
Too bad as I believe I could do it cheaper.
Oh well.
This is too small of a comunity to step on ANYBODY'S toes, ya know !
I wont be looking for anything new for a few months while
I am settling in at my new location.
L8r
Bob
Old Aug 29, 2012, 04:24 AM
atari7up is offline
Find More Posts by atari7up
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
Here is my twis cargo drop parachute video...
Twins Cargo Rc Plane Drop Parachute (1 min 15 sec)
atari7up is offline Find More Posts by atari7up
Old Sep 04, 2012, 07:15 AM
flylowfast is offline
Find More Posts by flylowfast
Joined Jun 2009
Originally Posted by alpea 41 View Post
Nothing sweeter than a successfull maiden flight on a scratch built.... Thank you Foam and Tape.
It was a big hit at our field too with 4 or 5 fellow flyers wanting one.
The 1st flight my son dropped a Jack In The Box antenna ball. And the maiden was cut short by a motor mount comming un-glued . But after a little more glue James flew it around 12 flights today.
The 180 watts was plenty and it flys wonderfully ... Lots of pics and vids comming but here's the maiden take off and ball drop
http://youtu.be/nLCIXGgiuho
Very nice.
Can you estimate how many hours of work it needed ?
Also, could you post the motors/ESC/props/servos/battery you used ?
Thanks in advance.
flylowfast is offline Find More Posts by flylowfast
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
